		scottmschmidt(at)yahoo.co Guest
		AirMike
				 Posted: Mon Jan 12, 2009 7:58 am    Post subject: Nose Wheel Axle |
				Scott -  could you please explain in detail what the defect is with the OEM Vans parts and why the Matco axle resolves the issue
  _________________ See you OSH '18
Q/B - sold. |
		Lew Gallagher
				 Posted: Mon Jan 12, 2009 8:15 am    Post subject: Re: Nose Wheel Axle |
				Hey Mike,
 Here's the repost, Later, - Lew
 --> RV10-List message posted by: David Hertner <effectus>
 Hi Everyone,
 I want to share with you the permanent fix that I have come up with for
 the front axle spacer problems we have been having lately. We have seen
 everything from gouging of outer yokes to the bearing spinning on the
 axle due to the loss of bearing pre-load.
 I decided to take a real close look at the system to see what the root
 problem is and I found that the spacers provided with the kit, both the
 steel ones delivered with the kit initially and the aluminum ones sent
 out as a fix do not interface with the bearing properly. This is due to
 two issues.
 The first is that the mating surface on the bearing for the spacer is
 curved. I contacted Timken Bearing and they sent me the dimensioned
 cross section of that bearing which showed that the curved mating
 surface was a compound curve that melded two radii. This is not an easy
 surface to mate to.
 The second issue was that of the wall thickness of the aluminum spacers
 set out by Van's to replace the initial steel ones. The wall thickness
 of these aluminum spacers is .250in. The mating surface of the bearing
 is approx. .187in. This is the steel contact area inside of the rubber
 bearing seal. This meant that the spacer was pre-loading on the rubber
 bearing seal instead of the steel portion of the bearing. In many cases
 this has resulted in the loss of the pre-load as the rubber
 deteriorates. Consequently, there were bearings spinning, yokes being
 gouged and loose wheels which add to bearing wear and shimmy.
 I initially thought that I would take the same approach as Ross Farnham
 and machine profiles on the end of new steel spacers so that the
 interface between them and the bearing was close to identical. I called
 Ross and talked it over with him and he said that if he had more time to
 put into it he would have made one of the spacers adjustable. I asked
 him if I could run with that and he agreed it would be the best fix.
 So, what I have been able to design is a system where there is a perfect
 interface between the spacers and the bearings by utilizing the Timken
 specifications and the accuracy of CNC machining. I have also been able
 to design a robust and accurate adjustment mechanism into one of the
 spacers so that the pre-load can be adjusted without having to take the
 wheel apart.
 Integrated into the spacer design are notches that accept the heads of
 10-24 socket-head cap screws installed on the inner face of the yoke.
 These restrict the spacers from being able to spin on the axle. As well,
 you will now be able to accurately torque the front wheel bolt because
 it no longer has any relationship to the pre-load of the bearings.
 The screw adjustment ring is locked in place by two 1/4-20 socket-head
 cap screws that have drilled heads so they can be safety wired.
 All of these new components including the hardware is made from
 stainless steel for durability and corrosion resistance.
 I just finished installing a set in my front wheel assembly and it goes
 together and adjusts very easily. I will be offering these for sale
 through Mike Lauritsen at Cleaveland Tools. The kits will include all
 hardware instructions and the drill guide used to locate the
 anti-rotation screws.
 You can go to my Blog site and read about these and see pictures of the
 RV-10 as well as the RV6/7/8/9 components. It is located at the
 following address: http://www.kitaircraftmods.com
 I feel as though I have now installed a permanent fix to this problem
 and I hope that if you are interested in the kit I have put together you
 will go and visit the Cleaveland Tools site. The first 10 production
 kits of each variant will be available sometime in mid January but
 please leave your name with them if you are interested so we can get a
 handle on how many are going to be required.
 Many thanks for reading this long post.
 Dave Hertner
 RV-10 Builder #10164
 Effectus AeroProducts Inc.
  _________________ non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed ! |
		orchidman
  Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
				 Posted: Mon Jan 12, 2009 8:41 am    Post subject: Re: Nose Wheel Axle |
				I didn't wait for Van's to correctly solve the problem.  I have gone with the Grove nose wheel.
 Was very easy to install and I think it removes the original problem.
 http://www.groveaircraft.com/rvnose.html
  _________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
				 Posted: Mon Jan 12, 2009 8:54 am    Post subject: Nose Wheel Axle |
				I am a little confused about the different products ou tthere which address this issue. Matco C $60.00 or the axle Cleaveland is selling C $170.00 which I thought was marketed by an independant...Aircraft Mods blog guy. Then I recall there also was another person who made the YouTube videos or are these the same person. Which one is distributed by CLeaveland????
  JOhn G.
		Tim Olson
				 Posted: Mon Jan 12, 2009 9:05 am    Post subject: Nose Wheel Axle |
				I ordered a set from Matco this weekend.  It looks like a
 pretty workable and inexpensive solution...cheap enough that
 it would be nice to see it become a standard Van's part.
 Right now, it appears there is a sale price as well, and
 I paid $54.32.  It basically replaces the entire axle
 assembly and allows it to be preload adjustable.  After
 hearing from Scott how well it worked out, I decided to
 finally get rid of my setup.  I plan to take some photos
 like Scott did and document the process and give some
 feedback, and add it to my site.  This all has some
 similarities to Dave Hertner's setup which also looks
 real good.  His I know is stainless steel, which would
 help explain the cost difference.
 Lew Gallagher wrote:
  Hey Mike,
  Hi Everyone,
  two issues.
  surface to mate to.
  wheel apart.
  Dave Hertner
  non-pilot
  Painting when it's 60+ degrees!
  Piddling with wiring and avionics.
  http://forums.matronics.com/viewtopic.php?p 24230#224230
		msausen
  Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
				 Posted: Mon Jan 12, 2009 9:11 am    Post subject: Nose Wheel Axle |
				The one that Scott posted about is a new solution developed directly by Matco (manufacturer of our wheels) to address the short comings of how the wheels mount to our fork type RV’s.  The one that Dave Hertner is developing is very similar and will be sold by Cleaveland.
   Nothing against Daves fine work but given the one that Scott posted is actually developed by Matco and is 1/3rd the price I just ordered a Matco.
 Michael
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Gonzalez
  Sent: Monday, January 12, 2009 10:54 AM
  To: RV 10 group
  Subject: RE: Re: Nose Wheel Axle
 I am a little confused about the different products ou tthere which address this issue. Matco, $60.00 or the axle Cleaveland is selling, $170.00 which I thought was marketed by an independant...Aircraft Mods blog guy. Then I recall there also was another person who made the YouTube videos or are these the same person. Which one is distributed by CLeaveland????
  JOhn G.
  > Subject: Re: Nose Wheel Axle
  > From: Mikeabel(at)Pacbell.net
  > Date: Mon, 12 Jan 2009 07:58:49 -0800
  > To: rv10-list(at)matronics.com
  > --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>
  > OSH '08 or Bust (busted) be there in "09
  > Q/B Kit - wiring and FWF
  > http://forums.matronics.com/viewtopic.php?p=224223#224223
  >    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
		Tim Olson
				 Posted: Mon Jan 12, 2009 9:12 am    Post subject: Nose Wheel Axle |
				Cleaveland has Dave Hertner's (Aircraft Mods Blog) parts. Yes,
 they're about $170.  Matco is selling these direct, to help
 fix the inadequacies in Van's axles so that their own wheels
 don't get a bad reputation.  Matco's are about $60. (Currently
 less)
 John Gonzalez wrote:
  	  | Quote: | 	 		   I am a little confused about the different products ou tthere which
  CLeaveland????
  JOhn G.
   > http://forums.matronics.com/viewtopic.php?p 24223#224223
		Lew Gallagher
				 Posted: Mon Jan 12, 2009 9:32 am    Post subject: Re: Nose Wheel Axle |
				Hey Tim,
 Is this the Matco page?
 http://www.matcomfg.com/AXLEASSEMBLYA24125INCH-idv-3657-1.html
 Later, - Lew
		pascal(at)rv10builder.net Guest
				 Posted: Mon Jan 12, 2009 9:46 am    Post subject: Nose Wheel Axle |
				yep
 http://www.vansairforce.com/community/showthread.php?t=38336
 Sent: Monday, January 12, 2009 9:32 AM
		Tim Olson
				 Posted: Mon Jan 12, 2009 9:56 am    Post subject: Nose Wheel Axle |
				Ah yes, sorry I didn't include a link before.
 Also, Scott was asking on my behalf and here is an email that
 they sent via him, regarding what you need to order:
 "The WHLAXLE24 nose wheel axle is now linked on the home page
 of our website.  the address is http://www.matcomfg.com
 We are offering them at a very good price!  He will need two of the
 WHLA24SP spacers as well as the WHLAXLE24 (the spacers are the 0.325
 thick discs that go on each side of the axle) for the RV-10 installation
 <other misc. conversation snipped>
 George R. Happ
 MATCO mfg"
				 Posted: Mon Jan 12, 2009 10:00 am    Post subject: Nose Wheel Axle |
				The issue with the RV-10 started with Van's supplying steel spacers that would gall the aluminum fork.  This was then replaced with aluminum spacers which made the problem better.
 It was still difficult to keep the preload constant using the Van's design.  This part fixes the issue and locks the axle to the fork with a bolt.
 The two place guys felt that the stock Van's system was causing an oscillation along the axis of the wheel axle caused by an increasing and decreasing pre-load on the bearing and this was also a fix for them.  The two place guys have a nose gear that is not as strong as the -10 so they may have seen this. I actually believe that that wheel balance is 80% of the problem and the bearing pre-load is 20%.    But that is just my opinion.  I  know they tested this same design on a -9A and saw significant improvement in the vibration of the front wheel but the wheel was also balanced.
 It is basically just another part that replaces the Van's design to make something better just like the axle extensions on the mains and the angled bolt on the elevator trim.
 Mike, I hope that helps explain the issue a little better.
 Scott Schmidtscottmschmidt(at)yahoo.com
 Sent: Monday, January 12, 2009 10:11:39 AM
 Subject: Re: Re: Nose Wheel Axle
  --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
 less)
 [quote] I am a little confused about the different products ou tthere which address this issue. Matco, $60.00 or the axle Cleaveland is selling, $170.00 which I thought was marketed by an independant...Aircraft Mods blog guy. Then I recall there also was another person who made the YouTube videos or are these the same person. Which one is distributed by CLeaveland????
   JOhn G.
   > From: Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)
   > To: rv10-list(at)matronics.com (rv10-list(at)matronics.com)
   > --> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
   > Read this topic online [quote][b]
		capsteve(at)iflyrv10.com Guest
				 Posted: Mon Jan 12, 2009 11:21 am    Post subject: Nose Wheel Axle |
				John,
      I make the IFLYRV10.COM parts and  am also the one who tried to describe the problem in the youtube video .  Cleaveland aircraft tool has most of my stuff available in their catalog, but I  don’t think mike listed my version of the axle yet (its on my website (at)99$).  there are some great options for this fix, mine is based on a cessna axle style  with end cups instead of sleeves. As tim mentioned, matco has really stepped up  offering a nice setup at what seems to be nearly at cost to manufacture.
  steve dinieri
  Sent: Monday, January 12, 2009 11:53 AM
  To: RV 10 group (rv10-list(at)matronics.com)
 JOhn G.
