longg(at)pjm.com Guest
Posted: Mon Jan 12, 2009 7:30 am Post subject: Switch Combinations |
I am using Z13/8 with a dual EI (Lightspeed) setup. By default I have two ignition switches for L/R or front and back if you prefer. Since I am not using a keyway switch I am wondering if there is a way to wire a single switch to manage both EI’s? My design goal is to eliminate additional switches where they can otherwise be combined.
Glenn
frank.hinde(at)hp.com Guest
Posted: Mon Jan 12, 2009 8:00 am Post subject: Switch Combinations |
Maybe but why would you want to use a single switch..You now have a critical component that if it fails your engine will quit. I know that as the Plead is a ground lead that this is unlikely (assuming the Lightspeed switches the same way a mag does) but even so why do it for the sake of another switch?
FWIW.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of longg(at)pjm.com
Sent: Monday, January 12, 2009 7:28 AM
Subject: Switch Combinations
Glenn
ist">http://www.matronics.com/Navigator?AeroElectric-List
ics.com
.matronics.com/contribution
fvalarm(at)rapidnet.net Guest
Posted: Mon Jan 12, 2009 8:25 am Post subject: Switch Combinations |
Glenn, Frank beat me to it. Keep your ignitions systems separate as much as possible.
Bevan
Glenn
Posted: Mon Jan 12, 2009 9:19 am Post subject: Switch Combinations |
At 09:27 AM 1/12/2009, you wrote:
Quote: | I am using Z13/8 with a dual EI (Lightspeed) setup. By default I
way to wire a single switch to manage both EI's? My design goal is
Dual ignition offers true redundancy only
if they are completely independent of each
other. They should share a minimum amount
of hardware . . . especially switches.
( -Thomas Paine 1776- )
Posted: Mon Jan 12, 2009 9:50 am Post subject: Switch Combinations |
Thanks to all for your comments. Good points, they will remain separate.
Glenn
