Lynn Matteson
Posted: Tue Jan 13, 2009 10:19 am Post subject: Ski report...off topic |
First taxi test on my new skis went very well. Only snow flurries,
blowing snow, low ceiling, and wind of 14 mph and gusts higher kept
me on the ground. I was able to taxi at 30 mph, tail off the ground,
at about half throttle, so there was nothing that was going to keep
it from flying. The new skis float much better than the old
ones....this was apparent right from the time I started out. The snow
was a measured 8-11 inches. I measured my tracks, and the ski bottoms
were about 2 inches above the ground, meaning the skis are lifting
the wheels off the ground. Higher speed would have seen the skis
climb above the snow. It takes much less power to taxi than before,
but this is all related to snow conditions. We had a light mist
overnight so the snow was heavy on top. The Kitfox IV turns very
well, probably partly due to the ski bottoms being curved up for the
last 1.5 inches on each side. Also, the plane is much easier to drag
backwards into the hangar, as all trailing edges are curved upward.
It should only happen once a year, but after my initial installation
of the stub "axles", the ski installation took only 11 minutes for
the pair. Even adding the time to install the stubs, total
installation time would be under an hour.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire
ignition system;
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Float Flyr
Posted: Tue Jan 13, 2009 10:59 am Post subject: Ski report...off topic |
Ski reports on airplanes are hardly off topic.... when do we get to see
some pics???
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
msm_9949(at)yahoo.com Guest
Posted: Tue Jan 13, 2009 11:27 am Post subject: Ski report...off topic |
Sounds great Lynn. Post some pictures when you get the chance. Out to shovel some snow now, we got about 6-8" last night. Got that flow indicator in yet?
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
--- On Tue, 1/13/09, Lynn Matteson <lynnmatt(at)jps.net> wrote:
| Quote: | From: Lynn Matteson <lynnmatt(at)jps.net>
Subject: Ski report...off topic
Date: Tuesday, January 13, 2009, 1:18 PM
| Quote: | --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
First taxi test on my new skis went very well. Only snow flurries, blowing
snow, low ceiling, and wind of 14 mph and gusts higher kept me on the ground. I
was able to taxi at 30 mph, tail off the ground, at about half throttle, so
there was nothing that was going to keep it from flying. The new skis float much
better than the old ones....this was apparent right from the time I started out.
The snow was a measured 8-11 inches. I measured my tracks, and the ski bottoms
were about 2 inches above the ground, meaning the skis are lifting the wheels
off the ground. Higher speed would have seen the skis climb above the snow. It
takes much less power to taxi than before, but this is all related to snow
conditions. We had a light mist overnight so the snow was heavy on top. The
Kitfox IV turns very well, probably partly due to the ski bottoms being curved
up for the last 1.5 inches on each side. Also, the plane is much easier to drag
It should only happen once a year, but after my initial installation of the
stub "axles", the ski installation took only 11 minutes for the pair.
Even adding the time to install the stubs, total installation time would be
under an hour.
Lynn Matteson
Sensenich 62x46
flying again after engine rebuild, and new Electroair direct-fire ignition
system;
akflyer
Posted: Tue Jan 13, 2009 12:48 pm Post subject: Re: Ski report...off topic |
| Float Flyr wrote: | Ski reports on airplanes are hardly off topic.... when do we get to see
some pics???
Noel
X2 This is NOT off topic. Good to hear the new skis are gonna work for you, but then again, you never really had any doubts that they wouldn't did ya?
Finally warmed up at the house and they are calling for snow for the next week so hopefully I will get some time in on mine in and play in lots of powder. I will have the external video camera running if I do so i hope to get some good footage!
Pics of the finished ski's would be great!
I did not forget about getting you pics of the hydraulic wheel ski's, the guy was not in town last time. I know he is now so I will go over and get pics when I get in this time.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Tue Jan 13, 2009 1:41 pm Post subject: Ski report...off topic |
Not yet...been too busy with the skis....pics on the next post...
Lynn Matteson
Sensenich 62x46
ignition system;
also building a new pair of snow skis
On Jan 13, 2009, at 2:26 PM, Marco Menezes wrote:
| Quote: | Sounds great Lynn. Post some pictures when you get the chance. Out
Marco Menezes N99KX
ground, at about half throttle, so there was nothing that was going
to keep it from flying. The new skis float much better than the old
bottoms were about 2 inches above the ground, meaning the skis are
lifting the wheels off the ground. Higher speed would have seen the
skis climb above the snow. It takes much less power to taxi than
before, but this is all related to snow conditions. We had a light
mist overnight so the snow was heavy on top. The Kitfox IV turns
very well, probably partly due to the ski bottoms being curved up
easier to drag backwards into the hangar, as all trailing edges are
curved upward. It should only happen once a year, but after my
initial installation of the stub "axles", the ski installation took
only 11 minutes for the pair. Even adding the time to install the
stubs, total installation time would be under an hour. Lynn
Matteson Kitfox IV Speedster, taildragger Jabiru 2200, #2062, 600.2
hrs Sensenich 62x46 flying again after engine rebuild, and new
Electroair direct-fire ignition system; do not archive
_-
=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=
3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3
_-
N369LM |
Lynn Matteson
Thanks for remembering, Leonard....I am posting pics right now, on
another posting, including flight pics...yup, had to fly her!
Lynn Matteson
Sensenich 62x46
ignition system;
On Jan 13, 2009, at 3:48 PM, akflyer wrote:
> to see
> some pics???
> Noel
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
As done as any plane will ever be.... cause now the tinkeritis
takes over.
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p 24559#224559
N369LM |
jcrowder(at)lpbroadband.n Guest
Posted: Tue Jan 13, 2009 6:22 pm Post subject: Ski report...off topic |
Good report Lynn. I look forward to hearing more.
Jim Crowder
[quote] --
Lynn Matteson
Posted: Tue Jan 13, 2009 7:34 pm Post subject: Ski report...off topic |
You mean like how I measured the front cable distance in order to
triangulate the 25 degree pitch-down angle of the skis, and then cut
the cable too short, and had to make up two new ones because I was
hurrying to try to get a flight in yesterday? Or how I burned my left
hand while grabbing onto a red-hot section of weld that I had just
annealed/normalized?...and the two huge blisters still haven't popped
4 days later? Or how I hooked up one of the bungee cords, pulled it
to test it and the terminal ring popped loose, and I nearly fell on
my pratt...and a friend helping me did the same thing? (can't believe
that in two years since making the last set of skis that I forgot how
much those rings have to be tightened) Or......oh, that's enough for
now. : )
Lynn Matteson
Sensenich 62x46
New skis done and flying
On Jan 13, 2009, at 9:11 PM, Jim Crowder wrote:
<jcrowder(at)lpbroadband.net>
Jim Crowder
N369LM |
calvin(at)mlgc.com Guest
Posted: Wed Jan 14, 2009 7:10 am Post subject: Ski report...off topic |
Lynn, or who ever,
Since I get my Kitfox messages via list digest I never get any pictures. I am very interested in seeing the pictures of Lynns skis. Could somebody please send them to me at calvin(at)mlgc.com (calvin(at)mlgc.com). Since I am building a set also I'd really like to see them.
Cal Anderson
Paul A. Franz, P.E.
Posted: Wed Jan 14, 2009 9:50 am Post subject: Ski report...off topic |
On Wed, January 14, 2009 7:08 am, Cal Anderson wrote:
| Quote: | Lynn, or who ever,
at calvin(at)mlgc.com. Since I am building a set also I'd really like to see them.
Cal Anderson
The KF Forum is your friend!
Click this:
<http://forums.matronics.com/viewforum.php?f=8>
Now look in the topics column. Any topic that has a little paperclip icon in it has
attachments. Find a topic posted by Lynn Matteson then click it. For example here's
one:
<http://forums.matronics.com/viewtopic.php?t=53997>
Scroll through it and all the photos will be there for this topic. Open and optionally
download any that you want.
Enjoy!
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
