AMP CPC Series 2, HDP-20, D-sub machined pin crimper
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List
mcingari(at)gmail.com
PostPosted: Thu Jan 15, 2009 8:20 am    Post subject: AMP CPC Series 2, HDP-20, D-sub machined pin crimper Reply with quote
Does anyone know of a high quality crimper that will work with the AMP
CPC Series 2 (AMP part # 205089-1 & 205090-1),
HDP-20 d-sub machined pins and sockets?
Thanks for your help,
Mike
- The Matronics Avionics-List Email Forum -
http://www.matronics.com/Navigator?Avionics-List
hdwysong
PostPosted: Fri Jan 16, 2009 10:41 am    Post subject: AMP CPC Series 2, HDP-20, D-sub machined pin crimper Reply with quote
The most expensive and least complicated route is to buy a new AMP
601966-1 crimper and AMP 601966-5 positioner from any of the online
electronics shops (Mouser, Newark, Allied). That'll set you back
about $600. Ouch.
More complicated and less expensive routes require a cross reference
of the AMP part #'s to MIL spec #'s. Those are as follows:
205089-1 Pin is a M39029/64-369.
205090-1 Socket is a M39029/63-368.
We use DMC tools in our shop. Pics can be seen at
https://www.dmctools.com/store/catalog.asp. You have a few options
depending on what style of crimper you want. These can be verified
using DMCs online cross reference tool to the M39029 part #'s:
The AF8 crimper needs the TP585 positioner for these contacts.
The AFM8 crimper needs the K13-1 positioner for these contacts.
The MH860 crimper needs the 86-30-1 positioner for these contacts.
Buying these tools new from DMC will set you back about $250.
However, they regularly show up on eBay for around $150. We got lucky
and found our AFM8 and positioner at a local military/electronics
surplus shop for around $80 and they work like new.
Hope this helps,
D
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Avionics-List All times are GMT - 8 Hours
