ron.mcgann(at)baesystems. Guest
Posted: Fri Jan 16, 2009 9:17 pm Post subject: Aileron Rigging |
I have a feeling that this may have been covered before - forgive me if I am going over old ground.
I spent today doing the final rigging of the ailerons pending first flight. With the elevators in the neutral position, I managed to achieve a near perfect alignment of flaps, ailerons and wingtip on both sides, with the sticks both centered and bolt upright. I felt good.
With the wing trailing edges in alignment, I moved the elevator up and down and found that both ailerons would move up more than 1/4" when the elevator TE was dropped. Not much (if any) movement of the ailerons from neutral when the elevator TE is raised.
I don't think I have a problem, the ailerons move up only with full forward stick (not a condition I expect much) and both are deflected the same amount. Is it possible to achieve flap, aileron, tip alignment through all elevator positions?
cheers,
Ron
-187
gettin' nervous! [quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
Tim Olson
Posted: Fri Jan 16, 2009 9:52 pm Post subject: Aileron Rigging |
Sounds like you did a good job. No, it's not possible
to keep them all aligned throughout the entire elevator
throw.
McGANN, Ron wrote:
cheers,
Ron
-187
gettin' nervous!
"Warning:
your computer."
Posted: Sat Jan 17, 2009 5:59 am Post subject: Aileron Rigging |
Just like Tim said. You want them even with the flaps when the elevator is neutral. Because of the way the sticks are connected both to the elevator and ailerons, the angle changes on the aileron pushrods going from the sticks to the wingroot when the stick is moved fore and aft, pulling the ailerons up when at either side of neutral elevator. You did it just right.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jan 17, 2009, at 12:15 AM, McGANN, Ron wrote:
cheers,
Ron
-187
gettin' nervous! | Quote: | "Warning:
your computer."
