rwhunter(at)integra.net Guest
Posted: Fri Jan 16, 2009 9:04 am Post subject: Riveting |
Page 28-14 step 3. Rivet callouts are on page 28-12
Riveting the bottom flange of the Fwd Center Section Bulkhead to the F-1076 Center bottom skin and the F-1072. The outboard 7 rivets are to be double flush on my plans. How does one go about that. Do you counter sink the Bulkhead holes.
I noticed that the older plans don't call for the double flush rivets. My plans don't call for any prep of the holes for double flush rivets.
Just trying to prevent another screw up.
Thanks in advance,
Rob Hunter
40432
Fuselage
dogsbark(at)comcast.net Guest
Posted: Fri Jan 16, 2009 9:20 am Post subject: Riveting |
Rob,
Yes, you machine countersink to do this. If I remember correctly, the landing gear bracket has a flange that resides in that area. It will need to sit flush and the shop heads will interfere.
Sean Blair
#40225
For Sale
ricksked(at)embarqmail.co Guest
Posted: Fri Jan 16, 2009 9:55 am Post subject: Riveting |
YUP!!! Sean has it right...I missed it at first, seems the misses are easy to remember.
Rick S.
40185
egohr1
Joined: 17 Jan 2006 Posts: 38 Location: Oklahoma City
Posted: Fri Jan 16, 2009 10:08 am Post subject: Re: Riveting |
Be glad the plans show it now. My plans did not and I had to redo the rivets when fitting the landing gear brackets.
Make sure the rivet is flush with the bulkhead, otherwise the bracket will not fit right.
_________________ eric gohr
EGOHR86@alumni.carnegiemellon.edu |
Posted: Fri Jan 16, 2009 10:35 am Post subject: Riveting |
Thanks Guys!
Rob
