air.guerner(at)orange.fr Guest
Posted: Fri Dec 26, 2008 11:55 am Post subject: Mixture control |
Ron,
You will be adding a complicated system to an already complicated engine. I am afraid this will further reduce the reliability of your engine. Dealing with this sort of experiment on the ground (I mean on a car or a motorbike) is something. Doing it on an airplane is another story, especially if you want to use your bird as a reasonably reliable cross country machine.
Just my personal opinion.
Remi
| Quote: | >>>>>>>>>>N4211W not flying yet, but have and will install a mixture control on 914.
First off installed will be a Split Second mixture display that is driven
by a Bosch O2 sensor (will weld a bung on the muffler inlet just
downstream of turbo).
Slight different install on 914 because of Turbo compared to 912/s, but
will use a needle valve to leak pressure from normal airbox pressure side
of enrichment solenoid to manifold cross tube. The more I leak the leaner
the mixture will be.
This will require a run of hose to cockpit then to manifold cross tube, I
will use high temperature Viton tubing.
I will slight richen mixture on main jet and perhaps even jet needle, I
always like to run slight rich when you are making a lot of BTUs such as
100% power or in 914s case War emergency of 115%. It can also cool things
a little on a hot engine (including when stuck on ground).
Then will size a restriction on the controlled "leak" to manifold cross
tube so it will allow me to only lean to ~14.7 at 18K.
Then will have an emergency "rich" button that will allow me to activate
enrichment solenoid that could further richen mixture on less than War
emergency power if I wish. In addition the emergency "rich" button will
completely bypass all my additional plumbing.
For either a 912/S or 914 install, if you at cruise power if you pull
throttle without closing off your controlled leak, your engine is probably
going to quit. On the other hand, if you set mixture at lets say 60% power
and adjust mixture, if you increase power you will go richer than probably
desired.
Another problem is if you lean at altitude, when you come down things will
lean up further.
Having a Split Second display is a nice tool for this control, a EGT
(which I have one on each side of motor) is only semi useful.
HAC has or had a altitude adjusting bellows, I would rather have full
manual control.
I am a motorhead and feel very comfortable fiddling with carburation. If
you can't tune a lawnmower engine to perfection by ear, owned a hot 2
stroke cycle that you managed to run on the edge for long periods without
blowing up, probably not worth considering the controlled 'leak' method of
adjusting Type 64 constant depression carbs.
Ron P.>>>>>>>>>>>>
terrys(at)cisco.com Guest
Posted: Mon Jan 05, 2009 9:27 am Post subject: Mixture control |
Hi Remi,
We are members of the Experimental Aircraft Association who have built an 'experimental aircraft'. As such, among other things not included in our standard kit, we have installed a mixture control on our 912S which bleeds manifold pressure back into the carb bowl vents. Testing has shown that the standard rotax carb settings are actually lean-of-peak at sea level on the front two cylinders and that it (of course) gets richer with altitude, passing thru peak and on down the richer side of peak EGT with increasing altitude. It is our assumption that it is acceptable for them to run the engines this way (lean of peak at take off) because the heads are liquid cooled.
We believe it is then a fair assumption that we can run the engine lean-of-peak at altitude and <75% power, given that the factory settings run the engine lean-of-peak at full power/sea level. Of course we monitor our exhaust, head, water, and oil temps just to make sure everything is happy while leaning at altitude.
regards,
Terry Seaver
A135/N135TD
Monowheel XS, 912S, Airmaster prop
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Remi Guerner
Sent: Friday, December 26, 2008 11:53 AM
To: Europa-List Digest Server
Subject: Mixture control
Ron,
Remi
desired.
lean up further.
manual control.
Ron P.>>>>>>>>>>>>
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Tue Jan 06, 2009 3:00 am Post subject: Mixture control |
Hi Terry,
That interesting information. I am not surprised to learn that the engine is running lean of peak at sea level, even at full power, as this is consistent with the specific fuel consumptions advertised by Rotax.
I am interested in knowing more about your mixture control system.
My concern is about the reliability of this system as you are adding piping from the engine to the cockpit and a sort of tap to control the leak I suppose. What happens if one of the pipe connections leaks or breaks? What are the effect of advancing or retarding the throttle if you forget to enrichen first? Does that kill the engine?
Remi
| Quote: | >>>> We are members of the Experimental Aircraft Association who have
regards,
Terry Seaver<<<<<<<<<<<
Posted: Tue Jan 06, 2009 9:49 am Post subject: Mixture control |
Hi Remi,
As I recall, we installed the Green Sky HACman mixture control system, see their URL at;
http://www.greenskyadventures.com/bing/HACmandetails.htm
Since we already had manifold pressure (vacuum) behind our panel (for the MP pressure transducer) it was only one additional line back to the carb bowl vents to implement. My partner in the plane, Dave DeFord, is the one who did most of the installation and testing, so he knows it better than I do. We use the mixture control on longer trips at altitude. You would want to use the EGT on a front cylinder to set lean-of-peak mixture (since the front cylinders run leaner the the rear), although just leaning until the engine gets rough and then richening up a little also works just fine (like I used to do with the Cessna 152). It does work better with the throttle closed just a little, but may work some even at full throttle, I don't quite remember that part. The engine can be expected to run rough if you close the throttle and/or descend, but I don't ever remember it actually dying. Any aircraft will run rough if you descend without readjusting the leaned mixture, so this is really not all that different, and you are unlikely to close the throttle for any other reason than descending, are you?
I am not sure the leaning mechanism has enough 'authority' to actually kill the engine, I will check with Dave later tonight to see if he recalls testing for that.
regards,
Terry Seaver
Sent: Tuesday, January 06, 2009 2:58 AM
Hi Terry,
Remi
regards,
gregoryf.flyboy(at)comcas Guest
Posted: Sat Jan 10, 2009 9:09 pm Post subject: Mixture control |
Terry,
I like the idea of compensating the Bing carbs which would tend to run rich at high altitudes, anyway.
Are you flying yet? Ie: Have you flown this arrangement, to see how well it worked, or how much fuel was being saved?
Thanks in advance,
Greg Fuchs, A050
Hi Remi,
We are members of the Experimental Aircraft Association who have built an 'experimental aircraft'. As such, among other things not included in our standard kit, we have installed a mixture control on our 912S ……….snip….
regards,
Terry Seaver
Posted: Mon Jan 12, 2009 10:02 am Post subject: Mixture control |
Hi Greg,
We have been flying over 7 years, but only about one year since installing the mixture control. My partner, Dave DeFord did most of the testing, so he knows the specifics better than I do. As I recall, we can reduce fuel flow 5+%, at altitudes of 8000-10000 feet. It doesn't work well at full throttle, because it requires a pressure difference across the carb butterfly to work. This means it is less effective at very high altitudes where you would need full throttle to get to cruise power.
The device we used is the Green Sky HACman mixture control system, see their URL at; http://www.greenskyadventures.com/bing/HACmandetails.htm
regards,
Terry Seaver
A135/N135TD
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Greg Fuchs
Sent: Saturday, January 10, 2009 9:06 PM
Subject: RE: Mixture control
Terry,
Thanks in advance,
Greg Fuchs, A050
Hi Remi,
regards,
Terry Seaver
Posted: Mon Jan 19, 2009 12:56 pm Post subject: Mixture control |
Terry,
I am coming back to this subject as I am doing some maintenance on the engine and had to remove the exhaust system. I took this opportunity to look at the coloration inside the exhaust elbows. Here is what I found:
Cyl 1: black
Cyl 4: white
Cyl 2 and 3: light brown
So cyl 4 is the leanest on my engine. Cyl 1 is the richest and the other 2 are in between. My engine has 350 hours and no adjustment of the carb needles were done since new. I could adjust the right carb needle to run leaner on Cyl 1 and 3, but the two front cylinders (1 and 2) would still run richer than the rear ones. This is different from what you experienced with your own engine. Mixture maldistribution is obvious here and does not seem to be repeatable on all engines of the type (912 ULS).
Remi Guerner
F-PGKL
>>>>>>>Testing has shown that the standard rotax carb settings are actually lean-of-peak at sea level on the front two cylinders <<<<<<<<
Terry Seaver
Posted: Mon Jan 19, 2009 3:55 pm Post subject: Mixture control |
Remi Guerner wrote:
| Quote: | Terry,
Cyl 1: black
Cyl 4: white
Remi Guerner
F-PGKL
Remi
the inlet to the carbs can have a marked effect. Some friends were
struggling with a Jab6 installation, single Bing carb, the rear
cylinders were overheating. After many fruitless efforts with cooling
baffles over a frustrating year, the cure was to replace the nice smooth
elbow at the inlet with a square box. Courtesy of Tony Higgins experience.
Graham
Posted: Mon Jan 19, 2009 5:33 pm Post subject: Mixture control |
Hi Remi
First and foremost you don't want to be running lean when you are making "a lot" of BTUs.
Make sure your carb jets and passages are not clogged with "carb snot" and your diaphragm is not ripped or torn.
If your forward cylinders run a little rich at lower RPMs, so be it, but at take off power your real interest is you are not running lean at all. Best taint slight towards richer at full power. Rotax has you check older 914s and newer ones with intake modifications (intercooler is a intake modification for carbon monoxide content and list a minimum, in other words they want to make sure you are rich enough at higher power settings. Pay very careful attension that you are not lean at high power.
Then lower power settings, I am an advocate to run them to point where engine does not hesitate. After carbs are verified "OK" and you sync them, you can fool with airscrew adjustment, turning in richens mixture and out leans them up. Go a little at a time until engine hesitates then go a bit richer. This is only going to be in effect at idle and not much over. Black can accumulate from lower speed operations.
*Thus go over carbs and connections with a fine tooth comb
*Verify at 105% and at 85% you are not too lean on any cylinder, easier said than done, if you have EGTs you can temporarily turn off fuel and see if you ar rich of peak, if you don't get a rise, you may be lean or even lean of peak, running peak and lean of peak at high power settings goes against long engine life
*Cruise is where you spend most of your time, thus remember that running mogas does not give a very good inducation of mixture on plugs, run some 100LL and cruise and land as quick as possible and take a plug reading, see what things look at. You can take a plug reading then at taxi power settings and see what that looks like. A bit hard on motor but to take a good full power plug reading, you would need to have full power for a while, then turn off motor after not too long a cool down and take a reading. Unless a Tri or Mono glider you best not want to a deadstick on a Mono short wing?
Ron P.
Visit - www.EuropaOwners.org
Posted: Tue Jan 20, 2009 2:35 am Post subject: Mixture control |
Graham,
I agree that the inlet configuration is important. As I am using the Rotax 912 series optional airbox, this may be the cause of the different mixture distribution compared to the same engine type fitted with the Europa airbox.
Remi
Graham
Posted: Tue Jan 20, 2009 2:54 am Post subject: Mixture control |
Hi Ron,
Better too rich than too lean, I agree.
Remi
slight towards richer at full power<<<<<<<<<
Posted: Tue Jan 20, 2009 9:18 am Post subject: Mixture control |
Hi Remi,
It is quite possible that I got the front and rear mixtures mixed up. I will check my notes when I get home tonight to see if this is the case. The point I was trying to make was that;
1) the intake manifold does not feed all cylinders symmetrically, causing some to be leaner than others,
2) The evidence suggests that on our 912S, the lean cylinders start out lean of peak at see level.
We believe this lean of peak is acceptable because the heads are liquid cooled.
regards,
Terry
Sent: Monday, January 19, 2009 12:50 PM
Terry,
Cyl 1: black
Cyl 4: white
Remi Guerner
F-PGKL
Terry Seaver
