		thesupe(at)hotmail.com Guest
				 Posted: Fri Jan 23, 2009 8:36 pm    Post subject: leading edge cuffs |
				Hi all C  Just wondering if anyone has installed the leading edge cuffs (as used on a Kitfox 4 or newer) on a Kitfox 1-3 model with the undercambered wing C and if so was the wing's performance improved?  Perhaps a lower stall speed and better cruise speed from less drag????  Thanks C  Jim Chuk  Avid MK IV  Jabiru  MnWindows Live™ Hotmail®:…more than just e-mail.  Check it out.  [quote][b]
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		dholly
				 Posted: Sat Jan 24, 2009 11:41 am    Post subject: Re: leading edge cuffs |
				Hi Jim- I didn't link the source but I recall reading the cuff was designed specifically for the flat bottom rib profile. I also found a few user comments that there was no appreciable benefit when added to the under cambered Avid wings, at least not enough to justify the effort to retrofit. Since that airfoil is nearly identical to the early KF rib it might give you some food for thought. FWIW... I left them off my Mk-IV HH but I am adding them to the Avid+ long speed wings. Regards, Doug
  _________________ -Kitfox III 582 Blue/C Grove Spring / Aerocet 1100 Amphibs
-Airdale Avid+ (project) TD / W.I.B. Gear |
		benburb
  Joined: 01 Nov 2008 Posts: 7 Location: Jacksonville, FL
				 Posted: Sun Jan 25, 2009 7:12 pm    Post subject: Re: leading edge cuffs |
				I built & have been flying a Kitfox III/912ULS since '95- and never heard of leading edge cuffs.  I must have slept through that class.  I have always been disappointed that I can fly my Cherokee 180 just as slowly as I can my Kitfox (about 44mph indicated.)  Would cuffs make a difference? Are they still available- or at least in plans form?  Thanks for any input. Ben
  _________________ Kitfox III/IV. Rotax 912UL.  Warp Drive 2 blade. On and off Aerocet amphibs. |
