clemwehner(at)sbcglobal.n Guest
Posted: Fri Jan 23, 2009 12:23 pm Post subject: Flaperon painting |
Kitfoxers,
Can the flaperons be painted directly onto the aluminum, or do they have to be covered with fabric first?
tnx,
Clem
Oklahoma
Kitfox IV-912, under construction since 1991
815TL
Posted: Fri Jan 23, 2009 12:33 pm Post subject: Re: Flaperon painting |
Mine are painted right on the aluminum. I didn't build it, so I can't say if that is the correct way, but it seems fine on mine.
Andrew
815TL, Kitfox II, Rotax 582-C
john beirne
Posted: Fri Jan 23, 2009 1:42 pm Post subject: Re: Flaperon painting |
have never seen a kitfox with fabric covered flapperons
Guy Buchanan
Posted: Fri Jan 23, 2009 2:25 pm Post subject: Flaperon painting |
At 12:19 PM 1/23/2009, you wrote:
| Quote: | | Can the flaperons be painted directly onto the aluminum, or do they have to be covered with fabric first? |
Prime and paint. Don't cover them.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Deceased K-IV 1200
A glider pilot too. |
7suds(at)Chartermi.net Guest
Posted: Fri Jan 23, 2009 2:55 pm Post subject: Flaperon painting |
Clem,
This is how I painted mine, lightly scuffed the surface with a scotch brite pad or a 360 grit wet dry then cleaned with Alumiprep 33 an aluminum prepping agent. Then primed with a 2 part epoxy primer then used a standard automotive enamel color matched to my Polytone paint.
There are many other options for prep methods, primer and final paint, important thing is to make sure you prep, prime and then paint.
PS. No fabric needed.
Lloyd
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of clemwehner
Sent: Friday, January 23, 2009 2:20 PM
Subject: Flaperon painting
Kitfoxers,
tnx,
Clem
Oklahoma
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Checked by AVG.
1/23/2009 7:28 AM
Checked by AVG.
1/23/2009 7:28 AM
Lynn Matteson
Posted: Sat Jan 24, 2009 12:09 pm Post subject: Flaperon painting |
I painted directly on the aluminum....with Poly-fiber enamel, not
Poly-tone paint.
Lynn Matteson
Jabiru 2200, #2062, 600.2 hrs
Sensenich 62x46
New skis done and flying
On Jan 23, 2009, at 3:19 PM, clemwehner wrote:
| Quote: | Kitfoxers,
tnx,
Clem
Oklahoma
www.matronics.com/contribution _-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sat Jan 24, 2009 1:25 pm Post subject: Flaperon painting |
I followed the Polyfiber manual. Prime, let dry 48 hours, prime again
then shoot Polytone into the wet primer. Next Kitfox I build I'll take
care not to scratch the flapperons and just leave them shinny aluminum.
Vic Baker
S7 912S Warp
Phase 1 flight testing
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Float Flyr
Posted: Sat Jan 24, 2009 3:34 pm Post subject: Flaperon painting |
Then add polish... lots of polish and elbow grease. I polished a prop for
a fellow once...believe me paint is easier to take care of.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
