JetPilot
Posted: Fri Jan 30, 2009 1:39 pm Post subject: Video In High Definition: Flying My Kolb MK III Xtra |
Here is a High Definition video of my wife and I flying my Kolb MK III Xtra around South Florida. As always with You Tube, the stock quality is HORRIBLE, but if you click on " Watch in HD " which is in blue at the bottom right of the video, and then click on " Watch in Full Screen " the quality will be pretty incredible. Enjoy...
http://www.youtube.com/watch?v=hNNdSS7jcgY
Kolb MK-III Xtra, 912-S |
grantr
Posted: Mon Feb 02, 2009 12:59 pm Post subject: Re: Video In High Definition: Flying My Kolb MK III Xtra |
Mike,
I cant watch your video in HD it is choppy. Even when I pause and let the video load a bit it still is choppy.
BTW how did you get the video to upload in HD? I tried uploading a MPEG 4 a while back and it will not allow HD.
JetPilot
Posted: Thu Feb 05, 2009 10:43 am Post subject: Re: Video In High Definition: Flying My Kolb MK III Xtra |
Hi Grant,
To get your videos loaded into You Tube in the highest quality, when you edit the video, make the final video at a resolution of 1280 x 720 and upload it at that resolution. The video can be up to 1 Gigabyte in size, and it will take a long time to upload, but it will work. Even if your camera is not HD, uploading in this resolution will result in the best quality video from a normal camera.
The jerking if you are getting it is due to your computer slowing down. Make sure there is nothing else running when you watch HD video, it does take a pretty fast computer to watch HD smoothly.
