Ianrat
Joined: 31 Mar 2008 Posts: 43 Location: Brisbane AUSTRALIA
Posted: Mon Jan 26, 2009 3:57 am Post subject: Strobe Lights |
Apart from AveoEngineering & Aeroled is there any other wing flashers on the market.
I only need strobes no navigation lights.
Or are there any details on how to make my own.
Thank you
Ianrat
ckleman(at)charter.net Guest
Posted: Mon Jan 26, 2009 9:32 am Post subject: Strobe Lights |
That's a good question, and I'd like to piggyback that with another question/possible solution.
After looking into the pricing of the nav/strobe lights, I was wondering possible solutions for them pricey buggers, especially since I plan to have them enclosed in a plexiglass lens built into the wing tips. There seems to be two simple solutions, however I'm not sure how much of a stickler they might be on the inspection since it's "not an aviation approved part".
Nav Lights: http://www.attwoodmarine.com/products/parts.asp?productid=1004&path=navlights&category=3>ype=1&group=3&subgroup=0&categoryname=Navigation+Lighting&typename=Sidelight&headername=Navigation+Lighting
Strobe Lights: http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item 20326016266&sspagename=STRK%3AMEWAX%3AIT&viewitem=
Now with the strobes you would of course need an enclosure of some sorts in your case.. The strobe itself could be screwed to the wing tip with it's 2 provided holes, and I'm sure an enclosure could be thought up or modified (perhaps by just buying the lens assembly for an aircraft strobe?). However, in the case of putting one in the wingtip under a plexiglass lens what are peoples suggestions? Does the glass lens have any sort of amplifying qualities?
And what are people thoughts on the red/green sidelights? They almost look like they're made for aviation at least...
Christopher Kleman
Mustang-II #2397 Plans Building
http://www.mustangaero.com/
Thank you
Ianrat
http://forums.matronics.com/viewtopic.php?p 26830#226830
Dick Maddux
Posted: Tue Jan 27, 2009 6:46 am Post subject: Strobe Lights |
Hi,
I am new to this list as I decided to expand my information input.
In regards to The Aveo strobes,I have them on my Kitfox. The amp load is very low and that is why I bought them. I removed my Whelens and sold the set on EBAY. Now I wish I had them back. The Aveo's work well but they are no where near as bright as the Whelens.
Dick Maddux
Kitfox 4-1200
Rotax 912UL
Pensacola,Fl
From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
Description: |
Filesize: |
324.15 KB |
Viewed: |
790 Time(s) |
mlas(at)cox.net Guest
Posted: Tue Jan 27, 2009 8:52 am Post subject: Strobe Lights |
Dick,
I to have switched out my Whelen strobe system for the Aveo. I on the other hand really like the system vs. the standard strobe setup. First I would say the important issue is visibility in flight not on the ground. Our tests (not formal) show that a new Whelen strobe is a bit more visible then the Aveo. We also found that the Aveo is more visible then the Aeroflash system. Most importantly we noted that on three airplanes that had Whelen systems that were two years or more in age the Aveo was the same or more visible. The pros to the Aveo system: in most installations a 3 plus pound weight savings was achieved, a savings of 170 watts +/- 20 depending on which brand of strobe you installed( that's 14-amps on a 12v system), the Aveo does not put out high voltage and therefore is less problematic with RF noise, the Aveo light life has a 20,000 hours life and is virtually maintenance free, the Aveo unit takes up much less space, and most importantly, if you find the right dealer the price is half or more depending on which brand of strobe you purchased.
Just my take,
Mike Larkin
On Jan 27, 2009, at 7:39 AM, Catz631(at)aol.com (Catz631(at)aol.com) wrote:
[quote] Hi,
Dick Maddux
Kitfox 4-1200
Rotax 912UL
Pensacola,Fl
<Kitfox 038.jpg>[b]
frank.hinde(at)hp.com Guest
Posted: Tue Jan 27, 2009 9:53 am Post subject: Strobe Lights |
Its my take that strobes do very little in tems of making an aircraft visible..In fact I'm wondering why I fitted strobes to my second airplane when I was convinced of this fact from my first airplane.
Now what does make an incredible difference is wig wagging the landing lights..There is just something about that left-right pulsation that really stands out..At least from the front.
Frank
Completely electrically dependant IFR RV7a..Including fuel pumps
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of MICHAEL LARKIN
Sent: Tuesday, January 27, 2009 8:40 AM
Subject: Re: Strobe Lights
Dick,
raymondj(at)frontiernet.n Guest
Posted: Tue Jan 27, 2009 10:55 am Post subject: Strobe Lights |
Does anyone have any experience with wig wagging strobes? I am considering
doing it on mine.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
I wouldn't loose much sleep over it. Strobes as an
aid to collision avoidance is problematic. For EVERY
close encounter with another airplane I was aware of,
by the time I saw the airplane the event was nearly over.
Had I KNOWN that an airplane was approaching from a certain
quadrant and was watching for it . . . the strobes might have
helped me pick up the machine. However,(1) conditions
were so hazy at the time that even if I had seen the
airplane, I'm not sure I could have studied it long
enough to decide whether it was at the same altitude
or holding position on the windshield - i.e. collision
course or (2) didn't see the airplane until right overhead
or even passed my location and moving away. In the
later cases, the airplane's approach was out of line of
sight.
The notion that "lives will be saved" by having
n-times stronger strobe lights is a figment of
a bureaucrat's imagination and fondest wishes.
In the cases where the other airplane is looking
right at you, a strobe of about ANY light output
will be of some assistance. Without a doubt, wig-wagged
landing lights are several orders of magnitude more
attention getting but of course ONLY in the cone of
visibility forward of your aircraft.
( -Thomas Paine 1776- )
msausen
Posted: Tue Jan 27, 2009 4:42 pm Post subject: Strobe Lights |
Perhaps my ignorance is showing, but I am considering trying to have the
wingtip strobes fire in sequence something like a wigwag pattern. Maybe
I'm lacking some piece of info that would put an end to my speculation. I
am a novice in the aviation electronics arena. If there are things which
prevent this please educate me, that's what I'm here for.
Raymond Julian
Kettle River, MN
"Hope for the best,
rlborger(at)mac.com Guest
Posted: Tue Jan 27, 2009 6:19 pm Post subject: Strobe Lights |
Raymond,
There's no technical reason to prevent you setting up strobes to
alternate or flash in some time sequence. If you are working with a
commercial strobe system, some provide the ability to set the strobes
to flash simultaneously or in sequence.
I'm not at the airport with my head in the opening that goes back
behind the baggage bay where my Whelen strobe power-pack is located so
this is from memory. But, I think that the Whelen's can be set to
flash alternately by the way you plug in the lines to the external
strobe unit's sockets.
I just went to my on-line build diary and found a pic of the strobe
power-pack. If you go to the link in the signature block then click
on the album for "Year #3, Q1 2004" and when it comes up, go to page
2. There, about 1/3 of the way down, is a pic of the power pack. You
can see that there is output for up to three strobes. Output 1
alternates with outputs 2 & 3 which are in synch. First #1 flashes,
then #2 & #3 flash together. So, by powering one wing from #1 and the
other wing from #2 or #3, you can get alternating flashes on your two
wing units. I guess you could be really cool and power a strobe on
top of the fin with #1 and the wings with #2 & #3 for a 1 - 2 flash.
I hope this helps.
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(99.999% done) Essentially complete. Running Tests & Final Inspections.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
the wingtip strobes fire in sequence something like a wigwag
pattern. Maybe I'm lacking some piece of info that would put an
end to my speculation. I am a novice in the aviation electronics
arena. If there are things which prevent this please educate me,
Raymond Julian
Kettle River, MN
"Hope for the best,
Sam
Posted: Tue Jan 27, 2009 7:25 pm Post subject: Strobe Lights |
This one has all sorts of patterns, including Wig-Wag.
http://www.airplanegear.com/skybright.htm
Sam
On Tue, Jan 27, 2009 at 6:23 PM, raymondj <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)> wrote:
[quote]--> AeroElectric-List message posted by: "raymondj" <raymondj(at)frontiernet.net (raymondj(at)frontiernet.net)>
Perhaps my ignorance is showing, but I am considering trying to have the wingtip strobes fire in sequence something like a wigwag pattern. Maybe I'm lacking some piece of info that would put an end to my speculation. I am a novice in the aviation electronics arena. If there are things which prevent this please educate me, that's what I'm here for.
Raymond Julian
Kettle River, MN
"Hope for the best,
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Posted: Tue Jan 27, 2009 7:40 pm Post subject: Strobe Lights |
Raymond Julian
Kettle River, MN
Assuming that your strobes feature an external trigger mode,
what you've proposed can be done . . . and I might add that
it seems practical.
You would need to understand how the strobes talk to each
other for the purpose of making them flash together. Then
you need a "black box" that generates alternating strobe
pulses to achieve the "wig wag" appearance.
Dick Maddux
Posted: Wed Jan 28, 2009 4:20 am Post subject: Strobe Lights |
Mike ,
I totally agree with you in regard to the Aveo strobes. They are very light,compact,no power pack,and very low amp draw which I needed for my Rotax. Max continuous is supposed to be around 14 amps so I am trying to keep the strobe draw low as I have other equipment (all low draw). I just wish the Aveos were a little brighter. I ask the guys on the ground if they see them and they pretty much say no. I am going to keep them though.
I am looking into the new Kentzleman (sp) landing,taxi, recognition light. It is supposed to be 2 1/2 times brighter than a 55 watt halogen headlight and draws less than 1 1/2 amps ! Put a flasher on it (auto store) and you would look like Southwest with their flashing landing lights! The thing is only 3" x 1" It too uses high power LED's. Anybody have one? It's an expensive item (about $230 (at) Spruce)
I installed a Monroy 300 in the panel of my Kitfox for traffic alert. Now that little jewel works great and in this high traffic area it is handy to have! We have a large number of T-34C's and helo traffic from the Navy.
Dick Maddux
Kitfox 4-1200
Rotax 912UL
Pensacola,Fl
dennis.glaeser(at)eds.com Guest
Posted: Wed Jan 28, 2009 6:50 am Post subject: Strobe Lights |
My strobe power pack (from strobesnmore.com) has numerous flashing
patterns: which ones (by plug location) flash in unison or
alternatively, as well as single, double or quad flashes.
Dennis Glaeser
RV7A
Quote: | Perhaps my ignorance is showing, but I am considering trying to have
>Raymond Julian >Kettle River, MN
Posted: Wed Jan 28, 2009 7:49 am Post subject: Strobe Lights |
Raymond,
Both the Aveo and Whelen system offer alternate synced strobe flashing.
Mike
Raymond Julian
Kettle River, MN
"Hope for the best,
mikefapex
mprather(at)spro.net Guest
Posted: Wed Jan 28, 2009 1:46 pm Post subject: Strobe Lights |
I'd guess that the strobe visibility problem is due to the relatively
short "on" time compared to the "off" time. Does anyone know if this is
true? The rest of this message assumes it is..
I also suspect that strobes aren't terribly efficient at turning watts to
lumens in terms of total power consumed... Doing a little research seems
to support that:
http://www.birket.com/strobes/Library/Photometry%20of%20Strobes.htm
Strobes may seem efficient because they provide very bright light for not
too many continuous watts, but since they're "on" time is so short, they
aren't very good.
It's interesting that the FAA approves of the change from the old rotating
or flashing incandescent light to strobes. I suspect a study of relative
conspicuity might find that strobes (as installed) are in many ways
inferior to the old style of lights. At best, I find that strobes make me
aware of the presence of another airplane (or cell phone tower), but it
often takes me a moment of searching around to actually figure out where
the flash was coming from. I also think strobes often distract me from
identifying what the object they're mounted to actually is. I don't know
if this is a common experience...
I have found (and I think there are studies that show) that lighting
systems designed to attract attention should never be completely dark
while the system is operating. This is true for traffic signals. A
single flashing light is much harder to see than two flashing lights
wig-wagging, even if they are spaced relatively close to each other. In
normal vision, our eyes are constantly moving, using our fovea (the hi-res
portion of the retina) to paint a picture in our visual cortex (part of
our mind) of our surroundings. It's hard to see strobes because the "on"
time is so short that while the eye may become aware of the strobe's flash
because of the image showing up away from the fovea, the short "on" time
makes it difficult for the eye/head to get the fovea on target very soon.
I believe it's true that good alert lighting employs our vision system's
motion sensing capability (away from the fovea), but such a system is
easier to see also because there's essentially no "off" time.
Where I'm going with is that when I go shopping for anti-collision
lighting, I won't be looking at strobes. Instead I'll want some system
that might look to the eye more like the old incandescent lights, except
brighter, cooler running, and more reliable. LED's are the obvious source
of illumination, especially today with their remarkable efficiency.
I like the wig-wags on the front of the airplane - even incandescent, but
wonder if there's anything in the FAR's about additional lighting that
might be used. I know that they have a very specific description of the
required output of the navigation lights, and I'm not proposing to replace
those.. I'd like to add flashing wingtip and tail lights, mounted where
strobes often are, but setup to run such that while one light is off,
another one is always on. Viewed from ahead of the wingtip, the
wigwagging lights are visible, plus the flashing light on the near
wingtip. From aft of the wingtip, the wingtip light is still visible,
plus the tail light. In no case does the airplane present a view of just
one light flashing on and off.
I also know that the nav lights are allowed to flash (or were - my early
182's lights do that). I'd likely disable that feature if I installed LED
anti-collision lights. I see that some aircraft light companies (Aveo)
are appearing to mimic the strobe behavior using LED technology, but using
quite short "on" time. I propose that this might not be the highest
performance way of operating them.
Back to work.
Matt-
Quote: |
<nuckolls.bob(at)aeroelectric.com>
>Hi,
sight.
BobsV35B(at)aol.com Guest
Posted: Wed Jan 28, 2009 4:37 pm Post subject: Strobe Lights |
Good Evening Matt,
I totally agree with your analysis of the strobe light conspicuity.
I think a white rotating beacon would probably be better than a red one
I do NOT care for strobes for just the reasons you note!
Another comment if I may?.
I have not checked the regulations, but my memory thinks that the approval to use flashing running lights has been rescinded.
As I am sure you are aware, airliners and many corporate aircraft of the late forties and early fifties were equipped with an alternating system whereby the running lights were not flashing, but they did alternate between on and off. If my memory serves me correctly, the on portion was fairly long and the off portion was relatively short. I think a sailor may have called it an occulting light. There were also white lights mounted on top and bottom of the airplane. When the running lights were off, the white lights were on and vice versa.
That system was dropped when rotating beacons came into use.
Many light planes adopted a flasher that just flashed the position lights without having any white light on while the running lights were off. My recollection is that the FARs now require steady running lights.
Since the primary use of running lights is so we may discern the direction of flight, I think they should always be steady lights.
Whadda Ya Think?
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 1/28/2009 3:57:01 P.M. Central Standard Time, mprather(at)spro.net writes:
Quote: | I also know that the nav lights are allowed to flash (or were - my early
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
Posted: Wed Jan 28, 2009 5:32 pm Post subject: Strobe Lights |
Matt,
You've anticipated my nest question. I am considering the wig-wag
strobes to increase the likelihood that I will be seen from behind. My
aircraft will be low and slow and feel especially vulnerable to being run
down from behind because I must depend on the other pilot to see and avoid
me. I would consider any reasonable system which would increase my
visibility from the rear.
Thanks to all who wrote in this topic. I'll be keeping my eye out as
new systems as LED technology evolves. How about LED "strobes" wigwagged at
the appropriate frequency?
Raymond Julian
Kettle River, MN
"Hope for the best,
Kellym
Posted: Wed Jan 28, 2009 7:27 pm Post subject: Strobe Lights |
I don't know Bob. I had a Cessna 170B for years that came with a nav
light flasher, which had an AD on it. Compliance was to either remove
the flasher, or install a two position switch to allow full on or
flashing. Don't believe the AD ever changed.
Whadda Ya Think?
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
installed LED
using
*A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
KCHD |
