		jbonewitz
  Joined: 24 Jan 2009 Posts: 17 Location: Grapevine, Texas, USA
				 Posted: Thu Jan 29, 2009 7:08 pm    Post subject: Elevator Gap Seal Test Report |
				Today I spent about an hour fashioning a make-shift gap seal for my elevator. I decided to first make a temporary seal out of duct tape - I mean speed tape   to test its effectiveness. What I ended up with looked so good (even in silver) that I wish it weren't temporary.
 Installation was real easy. I attached about a half inch of the tape to the trailing edge of the stabilizer and folded it forward, laying it out on top of the stab, sticky side up. I then attached another piece of tape on top of the first, face down, forming a double thick layer. I then folded the tape back over the top of the elevator and pushed it through the hinge gap, attaching it to the bottom leading edge of the elevator, making sure the elevator was full up so it stretched the tape taught. I made up three strips for each half of the stab so I could stay clear of hinges and hardware.
 It looked good, but would it stay on in flight? I envisioned taking off and having the tower announce to the world that I had some sort of sliver streamer ("looks like duct tape") trailing behind my plane - That kind of embarrassment, like coming out of the men's room with a streamer of toilet paper stuck to your shoe. Fortunately, that didn't happen.
 After over an hour airborne all was well. But how did it handle? Well, one thing I learned is that even with as much experience as I have in this aircraft, detecting a small nuance of change is difficult (at least for me). In hindsight, I probably should have flown right before I made the modification. Today, the air was cold and the wind was light and variable - quite a change from what we normally experience in North Texas. It's difficult to compare this flight to the myriad of others I've made in drastically different conditions. I can't say it made a big difference, but I can say it sure didn't hurt. As I spend more time with it and get some 3-pointers-on-grass behind me, I should know more. The main point I'd like to pass on is that when you make a mod like this, fly the airplane right before you install it. You'll be glad you did.
 Question. What should I replace the duct tape with? One thought was to purchase some vinyl sign material (the stuff they cut letters out of to put on banners or vehicles) pre-cut to the width I need. Though not as thick as duct tape, it is strong and should hold up to the elements. Any other suggestions?
 John Bonewitz
 Kitfox 5
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		MDKitfox(at)AOL.COM Guest
				 Posted: Thu Jan 29, 2009 8:01 pm    Post subject: Elevator Gap Seal Test Report |
				John,
 Great to hear from you again and welcome home.  I'm enjoying your adventure with the gap seals.
 You asked about replacing the duct tape.  Well, if you did like the duct tape, as you suggest, why not go to the aviation aisle at home depot and get white duct tape (there are other colors available.)  I do know that as good as the 'high speed tape' is, after about a year in the sun it would be best to replace it.  (I think that holds true for most tapes.)  There is one tape, made by 3M, that I used for the stripes on my aircraft, that is available in auto parts stores that is somewhat resistant to the effects of the sun.  If your interested, I can get the name of it for you tomorrow when I get to my hangar.  One thing to be careful about, the vinyls tend to stretch, but I don't know if it's significant enough to be a factor or not.
 Good luck on the the adventure and please continue to keep us posted.
  Rick Weiss
 N39RW Series V Speedster, 912ULS
 SkyStar S/N 1
 Port Orange, FL
 On Jan 29, 2009, at 9:54 PM, John Bonewitz wrote:
  	  | Quote: | 	 		  Today I spent about an hour fashioning a make-shift gap seal for my elevator. I decided to first make a temporary seal out of duct tape - I mean speed tape   to test its effectiveness. What I ended up with looked so good (even in silver) that I wish it weren't temporary.
 John Bonewitz
 Kitfox 5
 =  [quote][b]
		jbonewitz
				 Posted: Thu Jan 29, 2009 9:46 pm    Post subject: Elevator Gap Seal Test Report |
				Thank you Rick,
 The only thing I worry about with the duct tape is how I've seen the silver separate from the adhesive backing and leave that crusty adhesive welded to the surface. But then perhaps I'm using cheap duct tape. Heck, I'd leave it on if I didn't think it would do that. The 3M tape sounds good. Does it come wide enough?
 John Bonewitz
 Series 5 Taildragger
 On Thu, Jan 29, 2009 at 9:41 PM, Weiss Richard <MDKitfox(at)aol.com (MDKitfox(at)aol.com)> wrote:
 [quote] John,
     Rick Weiss
 SkyStar S/N 1
 Port Orange, FL
		Fox5flyer Guest
				 Posted: Fri Jan 30, 2009 5:26 am    Post subject: Elevator Gap Seal Test Report |
				Great post, John.  This gap seal business has  been around since early times on the Kitfox List and it's good that every so  often it pops back up.  Be careful of that duct tape.  If you leave it  on there too long it dries out and gets very difficult to remove, leaving  residue that adheres like glue.  I don't know if it is still available, but  many of us used what is (or was) called Ski Saver tape.  It was about  4 inches wide, clear, and very heavy duty.  Its purpose was to provide a  layer of protection on downhill and cross country skis.  It was applied  using the same method you described.  Mine has been on since May of 2000  and still looks great and is pliable.  Then again, my airplane spends it's  idle time in a hangar so I don't know how well it would hold up to outside  storage.  I don't know if Ski Saver is still available, but some have used  with good results what is called Leading Edge tape which is very similar and  durable.  Also it's clear and nearly invisible once installed. I think  Aircraft Spruce sells it, as well as other vendors.
  Although the benefits are subtle and not always  noticeable, they're definitely there and worth the effort.
  Good luck and keep us posted on your  progress.
  Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP  402+ TT
 "The aim of an argument or discussion should not be victory, but  progress."
 - Joseph Joubert
  [quote]   ---
		Dick Maddux
				 Posted: Fri Jan 30, 2009 6:06 am    Post subject: Elevator Gap Seal Test Report |
				John,
   I used clear leading edge tape (from Spruce) for my gap seal tape. It is relatively thick but the adhesive is not all that great. My first ones started to peel off in this Fl heat so I took the stuff off. Well, I didn't like that much either. I could tell the difference in my elevator authority so I made some more gap seal and stuck it back on. This time only a tiny bit was coming up on the leading edge of the tape and I was able to stick it back down with Polytac.
    Spruce sent me a flyer advertising new 3M tapes but they are expensive. I have two rolls of expensive tape already and I certainly don't want to experiment with any more.
    At one time one of the members was talking about some type of ski tape that he was using and was working well. I tried to find that on the net but no joy.
     I too would like to find the perfect tape that works and looks nice. I don't really like having the stuff back there as it looks like a Band-Aid but it sure makes a difference in the elevator authority on landing. This is the only tail dragger airplane I have ever owned (it's number 14) that takes constant work to achieve a nice 3 point landing and is the only one where wheel landings are so easy.
    Maybe some other guys have got an idea of which tape to use.
                                                         Dick Maddux
                                                         Fox 4-1200
                                                         Rotax 912UL
                                                         Pensacola,Fl
  From Wall Street to Main Street and everywhere in between, stay up-to-date with the [url=http://aol.com?ncid=emlcntaolcom00000023 ]latest news[/url].
		tc9008(at)aol.com Guest
				 Posted: Fri Jan 30, 2009 6:35 am    Post subject: Elevator Gap Seal Test Report |
				Could you send some photos of your installation. I would like to try it.
  Travis
  Kitfox IV
		pwmac(at)sisna.com Guest
				 Posted: Fri Jan 30, 2009 7:14 am    Post subject: Elevator Gap Seal Test Report |
				John,
  If I was going to do this I would choose 3M #8674. ACS is offering free samples now. It is the same stuff used by auto detail shops for clear bras. They should have it for less cost than ACS.
   Duct tape is a real poor product. The adhesive will give up after a short time in the sun and rain. Then it will leave a residue that is very hard to remove. It is intended for very temporary use.
  Of course the  favorite tape per the list archives is ski tape . Used by sli shops to protect the top of snow skis.
  Paul
  At 06:54 PM 1/29/2009, you wrote:
  [quote]Question. What should I replace the duct tape with? One thought was to purchase some vinyl sign material (the stuff they cut letters out of to put on banners or vehicles) pre-cut to the width I need. Though not as thick as duct tape, it is strong and should hold up to the elements. Any other suggestions?
  John Bonewitz
  Kitfox 5
		kirkhull(at)kc.rr.com Guest
				 Posted: Fri Jan 30, 2009 7:46 am    Post subject: Elevator Gap Seal Test Report |
				Does anybody have pictures of the gap seal installation
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
  Sent: Friday, January 30, 2009 7:07 AM
  Subject: Re: Elevator Gap Seal Test Report
 Deke Morisse
  Mikado Michigan
  - Joseph Joubert
		Fox5flyer Guest
				 Posted: Fri Jan 30, 2009 8:48 am    Post subject: Elevator Gap Seal Test Report |
				Good post, Paul.  If anyone out there finds a  source for Ski tape aka Ski Saver tape, please let us on the list know about  it.  I gave up looking for more of it.  Today's snow skis have a very  tough gel coating on them and the product may have died for lack of  sales.
  Deke
  [quote]   ---
		lcfitt(at)sbcglobal.net Guest
				 Posted: Fri Jan 30, 2009 8:52 am    Post subject: Elevator Gap Seal Test Report |
				John,
 When I had my camera mounted on the lift strut, I used the 3M vinyl tape
 available at most big box and little box hardware stores.  It was replaced
 periodically as I serviced the unit, but it was on in some places for
 several years.  I never had an incident of peeling and when I had to remove
 it, the only residue was a line at the edge where the adhesive must have
 squeezed out and collected a bit of dust.  This came off with a bit of elbow
 grease.
 Lowell
		kerrjohna(at)comcast.net Guest
				 Posted: Fri Jan 30, 2009 9:57 am    Post subject: Elevator Gap Seal Test Report |
				I used adhesive clear shelf liner from the aviation department at Walmart.  The area was disquised as kitdhen wares.  the material was cut 1" strips, overlapped sticky surfaces facing about 1/2".  The assembled strip was then attached as described.  In 12 years it has never been replaced.
 John Kerr
		larry huntley
				I found that "Ski Saver" tape worked well and was  good for 2-3 yrs. It is used to cover the tops of Xcountry skis. I don't think  it is used any more,but - - -  Larry
  [quote]   ---
  _________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
		Paul A. Franz, P.E.
				 Posted: Fri Jan 30, 2009 10:06 am    Post subject: Elevator Gap Seal Test Report |
				On Fri, January 30, 2009 7:28 am, kirk hull wrote:
  	  | Quote: | 	 		   Does anybody have pictures of the gap seal installation?
 I too would be interested in seeing photos. I'm interested in details of shape,
 overlap and what happens to the slack when you run neutral or down elevator.
 Does the slack start to peel a tiny bit on either the stabilizer or the elevator with
 dirt and debris sticking to the small exposed bit of adhesive?
 Which way is better to put them on - leading edge on top or bottom of the stabilizer?
 I assume this is determined by which elevator position you want when the gap seal is
 tight and is determined by position.
 Pictures would really help me see what's being done too.
 Paul A. Franz
 Registration/Aircraft - N14UW/Merlin GT
 Engine/Prop - Rotax 914/NSI CAP
 Bellevue WA
 425.241.1618 Cell
  _________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
		rjdaugh
				 Posted: Fri Jan 30, 2009 10:15 am    Post subject: Elevator Gap Seal Test Report |
				John,
 A tape that I really like is sold for plastic covers or repairs on greenhouses.  It stays flexible, the sun doesn’t affect it at all as far as I can see and it is easy to take off.  I used it for gap seal and for covering the hole in the top of the wind screen where the front wing pivot pin comes out.
 Randy
 Series 5/7 912S Warpdrive taper tip
 From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of John Bonewitz
  Sent: Thursday, January 29, 2009 7:54 PM
  Subject: Elevator Gap Seal Test Report
  John Bonewitz
  Kitfox 5  0123456789
  _________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
		JetPilot
				 Posted: Fri Jan 30, 2009 12:18 pm    Post subject: Re: Elevator Gap Seal Test Report |
				Why not just use a piece of PolyFiber attached with Polytack to seal the gap ???  It would be permanent, easy to do, and look good !  Much better than tape.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		Guy Buchanan
				 Posted: Fri Jan 30, 2009 12:21 pm    Post subject: Elevator Gap Seal Test Report |
  	  | Quote: | 	 		  What should I replace the duct tape with? One thought was to
 I use clear heavy duty packing tape. You could also look on
 www.sailrite.com for colored sail repair tape. I found the gap seal
 made a significant difference, but in an insignificant configuration.
 When I 3-point full flaps I can't get the tailwheel on the ground
 first without the gap seal. With- it's easy.
 Guy Buchanan
 San Diego, CA
  _________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
				 Posted: Fri Jan 30, 2009 12:33 pm    Post subject: Elevator Gap Seal Test Report |
				Twelve years ago I installed gap seals using adhesive shelf liner from Walmart, following the same proceedure described of overlapping edges. I have had no lifting of the edges, deterioration or cracking.
 John Kerr
 Classic IV,912, 800 hours
		Lynn Matteson
				 Posted: Fri Jan 30, 2009 2:01 pm    Post subject: Elevator Gap Seal Test Report |
				If you really want to drive yourself nuts over this gap sealing
 issue, try the "X" method instead of the "Z" method. We  used the "X"
 method on our model planes.
 The "Z" method has been explained....from under (or over) the
 trailing portion of the hort. stab, to over (or under) the leading
 portion of the elevator, forming a "Z" when view from the side. The
 "X" method is just alternating the placement of lengths of 2" wide
 tape, over and under, then under and over, etc., until the gap is
 sealed. In the "X" method, you make strips of tape that go, say, 2"
 wide and from front to back, instead of the "Z" method where you run
 the tape from side of elevator to hinge, then hinge to hinge, and so on.
 The jury is still out on whether this is a good method or not...how
 'bout some thoughts?
 As an aside, when this method is used in model planes, no hinge is
 needed, as the plastic covering material itself is used for the "gap
 seals" and in using the "X" method, the elevator operates freely
 without the use of hinges...not recommended for "live-in" airplanes.
 Lynn Matteson
 Jabiru 2200, #2062, 600.2 hrs
 Sensenich 62x46
 New skis done and flying
 On Jan 30, 2009, at 12:53 PM, Paul Franz - Merlin GT wrote:
  <paul(at)eucleides.com>
  details of shape,
  elevator.
  the elevator with
  of the stabilizer?
  Paul A. Franz
  Bellevue WA
  425.241.1618 Cell
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		jbonewitz
				 Posted: Fri Jan 30, 2009 2:26 pm    Post subject: Elevator Gap Seal Test Report |
				Permanent, yes, but I'm not sure how easy it would be to do. For starters I'd need some fabric. Haven't seen any of that laying around for about nine years. I would also have to paint it. No, I think tape will do the trick. I just need something more durable than duct tape.
 John
 On Fri, Jan 30, 2009 at 2:18 PM, JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:
 [quote] --> Kitfox-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
  Mike
  http://forums.matronics.com/viewtopic.php?p=227727#227727
  st" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
  MS -
  e -
		msm_9949(at)yahoo.com Guest
				 Posted: Fri Jan 30, 2009 2:30 pm    Post subject: Elevator Gap Seal Test Report |
				Hey John,
  I used "Storm-King" weather proof tape from local hardware. Comes clear in 2" width, applied by overlapping 2 pieces (sticky side up against sticky side down) 1" and installed in an "S" configuration. It's made to be used outdoors so it lasts and lasts. 3 years in, no sign of cracking or drying out.
  Marco Menezes N99KX
  Model 2 582-90 C-Box 3:1 w/ clutch
 --- On Thu, 1/29/09, John Bonewitz <bonewitz(at)gmail.com> wrote:
   	  | Quote: | 	 		  From: John Bonewitz <bonewitz(at)gmail.com>
 Date: Thursday, January 29, 2009, 9:54 PM
 John Bonewitz
 Kitfox 5
