UVTReith(at)aol.com Guest
Posted: Sun Mar 26, 2006 3:08 pm Post subject: Mono Brake fittings |
As all these threads are NPT threads, it's usual to use PTFE tape or PTFE
paste.
Best Regards,
Bruno Reith /UVT Reith
Monowheel XS/smart-Brabus engine/Woodcomp 3-blade fix (to start with)
scrimm
Joined: 09 Jan 2006 Posts: 81 Location: Gilbert, SC SC99
Posted: Sun Mar 26, 2006 3:31 pm Post subject: Mono Brake fittings |
I was wondering if Teflon tape would work, sounds like it will, makes the
job much easier.
Steve
_________________ Steve Crimm
N42AH |
NevEyre(at)aol.com Guest
Posted: Sun Mar 26, 2006 11:07 pm Post subject: Mono Brake fittings |
Loctite 638 works well, no chance of tape getting into the lines.Fitting can
be removed with heat later, if needed.
Cheers,
Nev.
M.Grass(at)comcast.net Guest
Posted: Mon Mar 27, 2006 7:54 am Post subject: Mono Brake fittings |
All Airplane A&P's advise against tape. Some can come of and cause a
blocking. The advise is to use Teflon (PTFE) paste instead.
Michael Grass
A266 TriGear
Detroit
