Whelan white position light
shempdowling(at)gmail.com
PostPosted: Fri Jan 30, 2009 1:40 pm    Post subject: Whelan white position light Reply with quote
Just wondering if anyone knows if the rear white light bulb on the
whelan wingtip combo strobe/position light is a standard bulb or do I
have to pay 18 bucks for the thing.
tia
Jeff Shemp Dowling
Bruce(at)glasair.org
PostPosted: Fri Jan 30, 2009 4:03 pm    Post subject: Whelan white position light Reply with quote
I believe it's non-standard.
Bruce
www.Glasair.org
n8zg(at)mchsi.com
PostPosted: Fri Jan 30, 2009 7:52 pm    Post subject: Whelan white position light Reply with quote
Shemp -
This one looks remarkably similar to an automotive turn signal / marker
light.
It's marked:
SYL
ERC
Or maybe it's
SYL
ERG
The receptacle is marked: TP20 - (bulb type?)
Neal
tia
Jeff Shemp Dowling
 Filesize:  869.76 KB
 Viewed:  237 Time(s)
gyoung
PostPosted: Fri Jan 30, 2009 9:23 pm    Post subject: Whelan white position light Reply with quote
If you've got a strobe in the tail (combo strobe & white tail light) it's
non-standard. If the strobes are only on the wing tips the tail & wing nav
lights use a standard bulb.
Greg Young
[quote] --
carl.froehlich(at)cox.net
PostPosted: Sun Feb 01, 2009 4:51 pm    Post subject: Whelan white position light Reply with quote
I tried one of these. It is much dimmer than the grossly over priced
replacement bulb that I ended up buying anyway.
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
