A gentle suggestion.
ggower_99(at)yahoo.com
PostPosted: Mon Feb 02, 2009 12:51 pm    Post subject: A gentle suggestion. Reply with quote
I cant believe what I am reading... So, you dont have there, what is known as free will? You have to ask your lawyer about any thing you are going to talk or write or think?
Here could happen only with the wife, if you cant "handle" her Smile Smile Smile
Do not archiove... Even if it does not work Smile Smile Smile
Saludos
Gary Gower
Flying from Chapala, Mexico.
El hombre es arquitecto de su propio destino - Amado Nervo. (1870- 1919)
(man is the architect of its own destiny)
--- On Mon, 2/2/09, roger lambert <n601ap(at)gmail.com> wrote:
Subject: A gentle suggestion
Date: Monday, February 2, 2009, 9:04 AM
The level of discourse on this website would be greatly enhanced if the following statement was never seen or heard again:
I have not reviewed the plans or specifications of(fill in the blank), nevertheless it is my opinion that (fill in the blank) is better, stronger, swifter , etc. than (fill in the blank).
All of you should be aware that merely putting in "do not archive" does not remove those comments from the web, and that all of these pithy little statements are being stored and may be retrieved for later use against you. Please consider the following scenario after you have an incident where person or property are injured or damaged:
Plaintiff's attorney:
Mr. Zenith builder/flyer, did you advise your passenger that you considered this airplane to have a design defect before the flight?
Mr. Zenith builder/flyer, did you deviate in any way from the plans and specifications from those provided to you by the professional aeronautical engineer that designed the aircraft?
Mr. Zenith builder/flyer, did you advise your passenger of those changes or deviations prior to the flight?
Mr. Zenith builder/flyer, what educational and/or experience qualifications do you have to gauge those changes and/or engineering analysis did you do after making those changes?
Now it really won't matter what you say because the attorney will have your email exchanges to impeach you with; or if you don't survive the crash, to use in the suit against your estate and deprive your wife and/or children of their inheritance.
And, by the way, unless you fully advise your passenger of all those items, a waiver or release of liability is ineffective in most states.
So, let's all think before we type and realize that words and actions can have consequences beyond getting flamed on the web or defaming some one's profession and character..
