		timrvator(at)comcast.net Guest
				 Posted: Sat Jan 31, 2009 1:02 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
				Tru Trak's RV-10 roll servo installation diagram is at
 <http://www.trutrakap.com/documents/RV10RollInstallation.pdf>.
 In the first photo, item "F" is the servo stop plate.  That stop plate
 is held on by two little 6-32 screws, 1/4" long, which only engage about
 one thread (!) into the servo body (due to the short  1/4" length of the
 screws and the AN960-10 washer spacer called out in step F).  I'm not
 very comfortable with this arrangement.  Only a single thread engagement
 (1 turn of the screw) leaves me feeling there's risk of the screw
 stripping and/or backing out and leaving the stop plate not properly
 attached.  I don't like the picture of the stop plate rattling around
 where it can jam the aircraft roll control.
 For those who have installed this system and gotten it flying, do you
 find that the stop plate is needed, or does the RV-10's aileron stop
 system keep the servo arm from running up to the stops provided by the
 servo's stop plate?   Have others taken steps to better secure the stop
 plate?
 Tim Lewis -- HEF (Manassas, VA)
 RV-6A N47TD -- 1000 hrs
 RV-10 #40059 under construction
		ninepapa(at)bendbroadband Guest
				 Posted: Sat Jan 31, 2009 6:22 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
 Thanks for mentioning this.
 I just checked mine and I got two turns on those screws.
 Another 1/8" or 1/4" would be better.
 As I understand it, the stop plate is there to prevent any part of the
 linkage from going "over center".
 This would cause the servo to lockup when it reverses, Not a Good Idea.
 Check with Tru Track they might have longer screws.
 John H
		LarryRosen
				 Posted: Sat Jan 31, 2009 7:43 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
				Tim,
 I cannot answer your question, but I looked at my installation (not yet
 flying) and I do not have the roll stop installed.  If you look at Tim
 Olson's installation and he also does not have the roll stop
 <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html>,
 but Deems does
 <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html>
 Also, I do not have the stop installed on the pitch servo, but Tim Olson
 does
 <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html>,
 but the Tru Trak RV-10 installation photos do not show it.  Deems does
 not have the pitch control stops installed
 <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html>
 Now I am even more confused than usual.  I guess a call to Tru Trak on
 Monday is called for.
 Larry Rosen
 #356
 Tim Lewis wrote:
  about one thread (!) into the servo body (due to the short  1/4"
  length of the screws and the AN960-10 washer spacer called out in step
  F).  I'm not very comfortable with this arrangement.  Only a single
  thread engagement (1 turn of the screw) leaves me feeling there's risk
  of the screw stripping and/or backing out and leaving the stop plate
  not properly attached.  I don't like the picture of the stop plate
  rattling around where it can jam the aircraft roll control.
  stop plate?
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		Tim Olson
				 Posted: Sun Feb 01, 2009 2:22 am    Post subject: Tru Trak (RV-10) roll servo stop plate |
				Keep in mind that the photos on that first link are from 2004...2
 years before I flew.  Somewhere in early Feb 2006 you should see an
 update where I added the stops, as the new kit of parts came out.
 Either right before or right after first flight, I had to redo the
 aileron servo linkages with new parts because the added the stops.  I
 think they had incidents of jammed aileron servos due to linkage
 travelling to far, so they made length changes and hard stops.  I
 would absolutely add the stops.  Although, I don't remember the screw
 length being an issue at that time.  I'd call them and ask how long
 you can use and then report back here for your RV10 buds.
 On Jan 31, 2009, at 9:18 PM, Larry Rosen <N205EN(at)gmail.com> wrote:
  Tim,
  yet flying) and I do not have the roll stop installed.  If you look
  at Tim Olson's installation and he also does not have the roll stop <http://www.myrv10.com/N104CD/wing/20041231/RV200412310044.html
  but Deems does <http://www.deemsrv10.com/album/Sec%2020%20Bottom%20Wing%20Skin/slides/DSC02106.html
  Olson does <http://www.myrv10.com/N104CD/upgrades/20060816/RV200608160109.html
  >, but the Tru Trak RV-10 installation photos do not show it.  Deems
  does not have the pitch control stops installed <http://www.deemsrv10.com/album/Wiring/slides/DSC03209.html
  on Monday is called for.
  Larry Rosen
  #356
  Tim Lewis wrote:
 > Tru Trak's RV-10 roll servo installation diagram is at <http://www.trutrakap.com/documents/RV10RollInstallation.pdf
 > plate is held on by two little 6-32 screws, 1/4" long, which only
 > engage about one thread (!) into the servo body (due to the short
 > 1/4" length of the screws and the AN960-10 washer spacer called out
 > in step F).  I'm not very comfortable with this arrangement.  Only
 > a single thread engagement (1 turn of the screw) leaves me feeling
 > there's risk of the screw stripping and/or backing out and leaving
 > the stop plate not properly attached.  I don't like the picture of
 > the stop plate rattling around where it can jam the aircraft roll
 > control.
 > you find that the stop plate is needed, or does the RV-10's aileron
 > stop system keep the servo arm from running up to the stops
 > provided by the servo's stop plate?   Have others taken steps to
 > better secure the stop plate?
 > Thanks,
 > Tim
				 Posted: Sun Feb 01, 2009 6:29 am    Post subject: Tru Trak (RV-10) roll servo stop plate |
				It looks like Tim Olson used the hardware from
 <http://www.trutrakap.com/documents/RV-710RightWing.pdf>.  This setup
 doesn't use the "RV-10 Attach Plate" called out in step "c" of
 Alex De Dominicis told me the RV-10 Attach Plate is essentially a torque
 enhancer for more autopilot authority in rough air.
 Larry Rosen wrote:
  Tim,
  yet flying) and I do not have the roll stop installed.  If you look at
  but Deems does
  Olson does
  Larry Rosen
  #356
 > in step F).  I'm not very comfortable with this arrangement.  Only a
 > control.
 > the servo's stop plate?   Have others taken steps to better secure
 > the stop plate?
 > Thanks,
 > Tim
		Tim Olson
				Here is a link to just before first flight time, when I changed the
 linkage and added the stops...they had just come out that week
 I think.
 http://www.myrv10.com/N104CD/finishing/20060208/index.html
 Larry Rosen wrote:
  Tim,
  but Deems does
  does
  Larry Rosen
  #356
 > stop plate?
 > Thanks,
 > Tim
		kdbelue(at)charter.net Guest
				 Posted: Sun Feb 01, 2009 9:23 am    Post subject: Tru Trak (RV-10) roll servo stop plate |
				I think it is very important to install the servo stop plates. The
 servo is capable of driving itself too far and get in a position that
 will lock the controls if the plates are not installed. I didn't think
 they were important when I watched the linkage and moved the controls
 to the stops, but when I moved the servo arm itself, I could get it
 into a locked position. Be careful!
 Kevin Belue
 RV6A
 RV10 flying
  Tim,
  Larry Rosen
  #356
 > control.
 > Thanks,
 > Tim
				 Posted: Sun Feb 01, 2009 12:49 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
				Thanks for all the replies.  Good info.
 I sent an email to Tru Trak asking about longer screws.  I'll let you
 know what I hear.  The screw max length will be a consideration, due to
 the moving pieces inside the servo that are right behind the screw
 holes.  You can actually see movement of an interior servo part through
 the screw hole.
 Tim Olson wrote:
 > Tim,
 > but Deems does
 > Olson does
 > Larry Rosen
 > #356
 >> control.
 >> stop system keep the servo arm from running up to the stops provided
 >> by the servo's stop plate?   Have others taken steps to better
 >> Thanks,
 >> Tim
		Tim Olson
				 Posted: Sun Feb 01, 2009 1:11 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
				And again, just so people don't get confused, no, when I built it
 BEFORE flying by a couple years, there hadn't been such a torque
 enhancing plate.  But, the week or so before I flew, they sent me
 the parts and it all got changed out.  So yes, today, and ever since
 first flight, I've had the torque enhancing plate.  That's the
 problem with reading a book....if you don't read to the end, you
 don't know what totally happened.
 Shows the day I modified the aileron servo:
 I've never had the opportunity to fly without it.
 Tim Lewis wrote:
		Tim Olson
				 Posted: Sun Feb 01, 2009 1:39 pm    Post subject: Tru Trak (RV-10) roll servo stop plate |
				One thing to consider if they won't let you go with longer screws
 is  using loctite on them once you fix it in a position you are
 happy with.  It would be better than having it come apart.
 Tim Lewis wrote:
  the screw hole.
		LarryRosen
				 Posted: Tue Feb 03, 2009 10:12 am    Post subject: Tru Trak (RV-10) roll servo stop plate |
				I spoke with Zack from Tru Trak today.  The control stop is not
 necessary on the RV 10 pitch servo because of the way the torque
 enhancer works.  You will not be able to lock up the servo.
 However, it is part of there recommended install for the roll servo.
 They do want the screws to be as short as practical.  If they are too
 long they will ride against a gear inside the servo.  But, one thread is
 too short.  The screw is a 6-32.
 I will need to look through my parts bins to see if I have the control
 stop for the roll servo.  Otherwise TT will send one out to me.
 Thanks everyone for bringing up this topic.  I will now know of a
 mistake that I can easily correct.  Better now than when it is to late.
 Larry
 Tim Olson wrote:
 > to the moving pieces inside the servo that are right behind the screw
 > through the screw hole.
 > Thanks,
 > Tim
#40356
N205EN (reserved)
<http> |
