Phil.Perry(at)netapp.com Guest
Posted: Tue Feb 03, 2009 9:00 am Post subject: Attach the Tail Feathers? |
This morning I woke up early and finished the tailcone (Section 10).
Now I'm waiting for the QB fuse to arrive in April!!! Apparently the facility in the Philippines was relocated and that has greatly increased the lead times from 3 months to at least 5+ months.
So I'm looking for something to do. I wasn't planning on completing section 11 until after the tailcone is attached. But given my scenario, I'm temped to go ahead and press on with Section 11 and just leave the Elevators and Rudder off the plane. (I'll need the depth in the garage later)
Anyone have any thoughts on completing section 11? I'm guessing it'll be much easier to attach the tailcone to the QB fuse without the hassle of the tail feathers.
Phil
daveleikam(at)wi.rr.com Guest
Posted: Tue Feb 03, 2009 9:28 am Post subject: Attach the Tail Feathers? |
I would start the section and get everything done you can. There are some steps you would wait until final assembly for like installing the trim cables or fairings and this is obvious.
Dave Leikam
RV-10 #40496
N89DA (Reserved)
Muskego, WI
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Feb 03, 2009 9:36 am Post subject: Re: Attach the Tail Feathers? |
| Phil.Perry(at)netapp.com wrote: |
Phil |
I would do Section 11 for sure and probably start on much of Section 12. You then take everything apart and hang them from the ceiling or on the walls until you start the final assembly.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
drfred(at)suddenlinkmail. Guest
Posted: Tue Feb 03, 2009 10:51 am Post subject: Attach the Tail Feathers? |
Don't forget to put some tie wire/coat hangar/string thru the hole where
the trim cables run. It will save you 45 minutes (at least) when trying
to install the tail feathers. (don't ask me how I know )
Dr Fred.
Perry, Phil wrote:
| Quote: | This morning I woke up early and finished the tailcone (Section 10).
the garage later)
Phil
