Deems Davis
Posted: Fri Feb 06, 2009 4:49 pm Post subject: Aileron rigging - Reflex ? |
I have the flaps and ailerons mounted to the wing and the wing is
attached to the fuse. (I don't have the wing tips on yet). It's pretty
straight forward to align the ailerons with the trailing edges of each
flap. However, I recall somewhere seeing/hearing about a 'reflex'
position where the ailerons were rigged 'up' 2-3 degrees on each side.
IIRC correctly this increased performance. What's the experience/advice
from those who are flying?
Deems Davis # 406
'Its all done....and it's almost put together.....'
http://deemsrv10.com/
Kelly McMullen
Posted: Fri Feb 06, 2009 4:56 pm Post subject: Aileron rigging - Reflex ? |
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1233967990-424-648&browse=airframe&product=reflex
talks about it, so I assume it exists. Wondering if this unit is
preferable to the flap positioning system.
On Fri, Feb 6, 2009 at 5:47 PM, Deems Davis <deemsdavis(at)cox.net> wrote:
I have the flaps and ailerons mounted to the wing and the wing is attached
to the fuse. (I don't have the wing tips on yet). It's pretty straight
forward to align the ailerons with the trailing edges of each flap. However,
I recall somewhere seeing/hearing about a 'reflex' position where the
ailerons were rigged 'up' 2-3 degrees on each side. IIRC correctly this
increased performance. What's the experience/advice from those who are
flying?
Deems Davis # 406
A&P/IA, EAA Tech Counselor
KCHD |
drfred(at)suddenlinkmail. Guest
Posted: Fri Feb 06, 2009 8:35 pm Post subject: Aileron rigging - Reflex ? |
Deems;
Put the flaps up in the reflex position and then line up the ailerons.
You really have to have the wingtips on before you can set the
ailerons. The cruise position is to have everything in the "reflex"
position.
Alex D. taught me to drop the flaps from the reflex to the neutral on
downwind. It helps slow you down.
Fred
Cant wait to see you get done.
Deems Davis wrote:
pretty straight forward to align the ailerons with the trailing edges
of each flap. However, I recall somewhere seeing/hearing about a
'reflex' position where the ailerons were rigged 'up' 2-3 degrees on
each side. IIRC correctly this increased performance. What's the
experience/advice from those who are flying?
Deems Davis # 406
Dick Sipp
Posted: Sun Feb 08, 2009 6:32 pm Post subject: Aileron rigging - Reflex ? |
Deems:
I use the flaps in trail or 1st position down with the prepositioning switch
mod for takeoff and again entering downwind. The limiting airspeeds are in
section 5 of the text. As you get used to the airplane you can definitely
feel the effect of the flaps moving into or out of the reflex or full up
position.
Dick Sipp
N110DV
Deems Davis
Posted: Sun Feb 08, 2009 6:54 pm Post subject: Aileron rigging - Reflex ? |
Thanks Dick, what I was missing is that when the flaps are fully
retracted they are in the 'Reflex' position. I'm going to mount the wing
tips tomorrow, and then I'll 'final' rig the ailerons.
Deems Davis # 406
'Its all done....Its just not put together'
r
