mclayton(at)rochester.rr. Guest
				 Posted: Sat Feb 07, 2009 11:18 am    Post subject: Kitfox-List Digest: 36 Msgs - 02/06/09 |
				I am still working on rebuilding my KF II and am starting to think about the engine I will need.  The old Rotax 532 that was on it suffered a severe prop strike, and given the problems with 532 crankshafts, plus uncertainty over the number of hours actually on the engine, I have decided to look for alternatives.  I wondered if anyone has had experience with the AeroVee conversion.  It is heavier than the Rotax, with a dry weight of 161 lbs, and so, given that the original installation was on the order of 130lbs, I would add at least 30-40 lbs to the empty weight, and will have to do some homework on a new weight and balance calculation to see if it is even doable.  The useful payload would also be reduced.  However, the price is attractive, and the 80 HP rating is also attractive.  Fuel burn should not be too bad with a light aircraft like the Kitfox II.
 Can anyone help with info?
 Thanks!
  Mike
 mclayton(at)rochester.rr.com (mclayton(at)rochester.rr.com)
 Spencerport, NY 14559
 N16AF (KF II  Rebuild in Progress)
 EAA Chapter 44
 On Feb 7, 2009, at 2:59 AM, Kitfox-List Digest Server wrote:
 [quote]*
 Today's complete Kitfox-List Digest can also be found in either of the
 two Web Links listed below.  The .html file includes the Digest formatted
 and Message Navigation.  The .txt file includes the plain ASCII version
 of the Kitfox-List Digest and can be viewed with a generic text editor
 HTML Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2009-02-06&Archive=Kitfox
 Text Version:
     http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2009-02-06&Archive=Kitfox
                            Kitfox-List Digest Archive
                      Total Messages Posted Fri 02/06/09: 36
 Today's Message Index:
      1. 03:38 AM - Re: Re: Brake line fittings question...  (Larry Huntley)
      2. 05:16 AM - Re: Re: Snowshoes on struts  (Lynn Matteson)
      3. 07:22 AM - Re: Snowshoes on struts  (Guy Buchanan)
      4. 07:37 AM - Re: Snowshoes on struts  (Noel Loveys)
      5. 08:07 AM - Re: Snowshoes on struts  (Lynn Matteson)
      6. 08:17 AM - Re: Snowshoes on struts  (akflyer)
      7. 08:28 AM - Re: Re: trailering your LSA - skip the trailer  (Lowell Fitt)
      8. 08:33 AM - Re: Snowshoes on struts  (Lowell Fitt)
      9. 08:51 AM - Re: trailering your LSA - skip the trailer  (akflyer)
     10. 09:32 AM - Re: Re: Snowshoes on struts  (Lynn Matteson)
     11. 09:32 AM - Re: Re: trailering your LSA - skip the trailer  (Lynn Matteson)
     12. 09:40 AM - Re: Re: Snowshoes on struts  (John W. Hart)
     13. 09:56 AM - Re: posting photos - best way...  (akflyer)
     14. 10:14 AM - Re: Getting a replacement airworthiness  (akflyer)
     15. 10:20 AM - Re: posting photos - best way...  (Paul A. Franz, P.E.)
     16. 10:30 AM - Re: Re: posting photos - best way...  (Lynn Matteson)
     17. 10:39 AM - Re: posting photos - best way...  (akflyer)
     18. 11:33 AM - Re: Snowshoes on struts  (fox5flyer)
     19. 11:33 AM - Re: Re: Snowshoes on struts  (Noel Loveys)
     20. 12:01 PM - Re: Re: Getting a replacement airworthiness  (Cudnohufsky's)
     21. 12:17 PM - Re: Getting a replacement airworthiness  (akflyer)
     22. 12:17 PM - Re: Snowshoes on struts  (Noel Loveys)
     23. 12:36 PM - Re: Re: posting photos - best way...  (Lynn Matteson)
     24. 12:46 PM - Re: Snowshoes on struts  (Lynn Matteson)
     25. 01:03 PM - Re: posting photos - best way...  (JetPilot)
     26. 01:08 PM - Re: Snowshoes on struts  (fox5flyer)
     27. 01:30 PM - corn harvest  (Paul Franz - Merlin GT)
     28. 01:39 PM - Re: corn harvest  (JetPilot)
     29. 02:23 PM - Re: Re: Getting a replacement airworthiness  (Noel Loveys)
     30. 02:33 PM - Re: Re: corn harvest  (Noel Loveys)
     31. 03:27 PM - Re: Re: corn harvest  (Lynn Matteson)
     32. 05:02 PM - Re: Re: corn harvest  (Noel Loveys)
     33. 05:30 PM - Forward: Annual Desert Fox Squadron and Friends Fly-in on March 27th, 28th and 29th.  (Pete Christensen)
     34. 05:59 PM - Problem with FLUTTER ? ! ? !  (WurlyBird)
     35. 06:37 PM - Re: Problem with FLUTTER ? ! ? ! Must fix  (Aerobatics(at)aol.com (Aerobatics(at)aol.com))
     36. 06:46 PM - Re: Problem with FLUTTER ? ! ? !  (Dee Young)
 ________________________________  Message 1  _____________________________________
 Time: 03:38:10 AM PST US
 From: "Larry Huntley" <asq(at)roadrunner.com (asq(at)roadrunner.com)>
 Subject: Re: Re: Brake line fittings question...
 John McBean has lots of them and they are inexpensive. I just bought some
 tube and fittings for mine.   Larry Huntley
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
