Posted: Sat Feb 14, 2009 7:17 am Post subject: AGM Battery & charger info |
battery & charger info:
Posted: Sun Feb 15, 2009 8:24 am Post subject: AGM Battery & charger info |
Charlie
Great information.
The battery maintainer I have on my airplane is the unit you mentioned.
http://aeroelectric.com/Pictures/Battery_Chargers/Schumacher_Chargers/1562.jpg
It has a adapter that I attach permanently to my battery with a keyed plug
that allows quick easy attachment without having to worry that it is
connected backwards. I notice when I attach the charger to the plane it will
go into charging mode even after a long flight. When I taxi back to my
hanger the planes charging system goes into discharge due to low RPMs. I
think I can detect a slightly increased power level after being hooked to
the battery maintainer than without. Any way after multiple batteries with
and without the battery maintainer the batteries last longer when kept on
the maintainer. The biggest longevity improvement is likely from attaching
the battery through the 3-4 months in the winter when the plane doesn't fly.
For the rest of my vehicles (cars, boat and tractor) that are left in
storage for some times 9 months at a time I have had very good luck
attaching a float charger. I used to disconnect the batteries but now I just
connect the float charger. Yes I fog the engines and change the oil. The
float chargers I use are:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=42292
Rick Neilsen
Redrive VW powered MKIIIC
