		agibeaut
				 Posted: Tue Mar 31, 2009 5:11 pm    Post subject: Speaking of Nose Gear |
				I am really struggling with the friction level of my nose strut on my 701. It just seems too tight even after trimming a couple of times. Top bearing alone is fine, and the friction levels rise after I tighten lower bearing bolts. Is there some comparative advice anyone can give me?
 Art Gibeaut
 Erie, IL
 CH 701
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		NYTerminat(at)aol.com Guest
				 Posted: Tue Mar 31, 2009 6:34 pm    Post subject: Speaking of Nose Gear |
				Art,
  We have all been there, put a small amount of oil on it and go fly. It will  loosen up on it's own after some use. It is moved by your feet which have a lot  of strength and when in the air it will be easier to move than on the ground. By  the time you fly off your hours it will be fine.
  Bob Spudis N701ZX / 174 hrs
  In a message dated 3/31/2009 9:15:32 P.M. Eastern Daylight Time,  aagibeaut(at)yahoo.com writes:
   	  | Quote: | 	 		  I am    really struggling with the friction level of my nose strut on my 701. It just    seems too tight even after trimming a couple of times. Top bearing alone is    fine, and the friction levels rise after I tighten lower bearing bolts. Is    there some comparative advice anyone can give me?
 Art Gibeaut
 Erie,    IL
 CH 701
  A Good Credit Score is 7001372437/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps!
		lgold(at)quantum-associat Guest
				 Posted: Tue Mar 31, 2009 9:03 pm    Post subject: Speaking of Nose Gear |
				Art's comment got me thinking (a rear event). I was told that the plane with
 the nose gear that collapsed used the 1080 heavy duty bungee on it (this is
 heavier than the normal "1080"). Does Zenith ship the kit with the normal
 strength or the heady duty bungee? Could a heavy duty bungee have
 contributed to the gear failure?
 Les
				 Posted: Wed Apr 01, 2009 6:36 am    Post subject: Speaking of Nose Gear |
				Hi Art,
 Having the nylon bushing, I assume you've got a tight fit there, but if
 it slides at all, it should wear in better if that's all the contact
 friction is about.
 If you've metal dragging on any of  the strut surface, you'd best clear
 that part with some emery cloth or a round file. Perhaps the bearing is
 being
 brought out of parallel with the diameter of the strut when it's
 tightened down and that would also cause increased friction.
 Use some ink marker on the strut and see where the most marker collects
 on the bearing and near surfaces. Also check the strut for shine and
 ink removed to check where the rub is concentrated.
 If the action is smooth, the friction is not a problem as it will ease
 up eventually providing a good bearing alignment. Better than being loose.
 agibeaut wrote:
  Art Gibeaut
  Erie, IL
  CH 701
  http://forums.matronics.com/viewtopic.php?p 37141#237141
		n85ae
				 Posted: Fri Apr 03, 2009 6:03 am    Post subject: Re: Speaking of Nose Gear |
				On my CH801, I noticed a high amount of friction with the nose gear when
 all the parts are bolted together. What I eventually discovered is that when
 everything is installed the lower bearing plate is not quite at 90 degrees
 to the gear leg. So when you tighten everything the bearing is not quite
 aligned right. The fix in my case is to resurface the bottom of the bearing
 slightly to correct the alignment on the shaft. It is a slight amount (about
 .020) but enough to make the gear leg really tight. It is probably that the
 lower plate is not bent quite enough. An easy fix, but also easy to miss.
 Hope this helps.
 Jeff
