		ggower_99(at)yahoo.com Guest
				 Posted: Tue Mar 31, 2009 9:20 am    Post subject: Weak 701 Nose Gear ? |
				Hello All,
  I think that the tube axle has his reason to be,  There are parts in any machinery and electric devices that act as a fuse,  I am sure that that axle is one of the several "fuses" in the airplane.
  Someone that is doing his landings on the front wheel first (in a regular basis), even if the pilot bends or not the axle or  the nose gear,  is going to end wheels up eventually.
  We all need to practice all of our landings on the mains, and keep the front wheel in the air as much as the elevator keeps it up.
  In fact, about a 100 hrs ago, we were having some little problems with the fine touch of the elevator at landing,  our Instructor was able to keep the 701 on the mains only, when landing,  for more that 600 ft to prove us it can be done.  So for this training we installed a little "office seat"  wheel in the tail tie down ring and practiced gently to make  "wheelies".
  A few hours later we could stop the plane as a tail dragger, on that little wheel;  then we applied power and managed to take off without the front wheel touching...  Was lots of fun and gave us a great feeling of the elevator, and better knowledge of our great airplane.
  Saludos
  Gary Gower
  Flying from Chapala, Mexico.
  Learning to fly the 701 is lots of fun.
 --- On Mon, 3/30/09, Larry <lrm(at)skyhawg.com> wrote:
   	  | Quote: | 	 		  From: Larry <lrm(at)skyhawg.com>
 Subject: Re: Zenith701801-List: Weak 701 Nose Gear?
 Date: Monday, March 30, 2009, 8:45 PM
  	  | Quote: | 	 		  --> Zenith701801-List message posted by: Larry <lrm(at)skyhawg.com>
 It bothered me when I built my 701 that the nose wheel axle was made of thin
 wall 4130 tubing with nuts welded in each end.  I threw it away and built a new
 one out of solid solid stainless steel.  A little more weight, but so what!!  It
 will not bend.  Larry, N1345L
 Tony Sim wrote:
  	  | Quote: | 	 		   To all,
          recently had an event with a 701. Touched down on mains and when
 the nosewheel lowered in a light to moderate manner the aircraft started to veer
 to the left . Right foot had no effect and the rate of turn increased resulting
 in the left wheel lifting and the right wing leading edge slat contacting the
 ground
  I was concerned that I may have applied right foot to the left rudder
 pedal on the other side which could be a danger with the peddals so close
 together, but wondered if that was the case why this had not happened before
  We dicovered shortly after buying the aircraft that the nosewheel axel was
 bent and I am now tending to think that the veering off to the left was due to
 failure following a prevous incident or number of incidents.
  Any thoughts or theories welcomed . Heck of a feeling when you put an
 imput into the controls that you have done for many years and hours and have no
 response.
  Tony
  Date: Mon, 30 Mar 2009 16:56:36 -0400
  Subject: Re: Weak 701 Nose Gear?
  Les,
  I can tell you that it was a very hard landing. Just look at the axle on
 the nose gear, it takes a lot to get that to bend. My guess is that it was
 either porpoised in and got out of control or it did not hit the mains first and
 hit the nose gear first.
  	  | Quote: | 	 		   Recently a learned about a new (~30 flight hours) 701 that had its nose
 gear
  	  | Quote: | 	 		   collapse on landing, causing considerable damage and was able to obtain
 two
  	  | Quote: | 	 		   pictures (see attached).  The gear tube buckled and bent back just above
 the
  	  | Quote: | 	 		   lower bearing, which bent the lower bearing and firewall. The wheel bent
  against the fus and deformed the lower structure behind the gear. The
  radiator was pushed up into the exhaust and holed, and the bottom cowling
  was damaged. The prop, and possibly the engine were also casualties of
 this
  	  | Quote: | 	 		   collapse.  The wheel axle was bent up with the bolts holding the axle to
 the
  	  | Quote: | 	 		   fork still in place. The fork was bent and the tire pushed upward into the
  fork so that the tire tread was cut by a bolt on the inside of the fork.
 The
  	  | Quote: | 	 		   upper gear tube and upper bearing did not appear to be affected. I was
 able to find out that the plane was not overweight and the pilot and
  	  | Quote: | 	 		   passenger were not injured. The pilot said the plane was built to Zenith
  specs. She was making a, admittedly "hard", short field landing
 on a paved
  	  | Quote: | 	 		   strip at a high angle of attack when it happened. The main gear touched
  first and was not damaged.
  Like most of us, I have made some awful hard landings in my 701 but have
  been relieved to find little or no gear damage. Until I learned about this
  failure I thought that 701 gear was very resilient. Now I am beginning to
  wonder. Have any of you seen or experienced a similar collapse or
 speculate as to
  	  | Quote: | 	 		   its cause? Les
  A Good Credit Score is
 7001372437/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62">
 See yours in just 2 easy steps!
  All your Twitter and other social updates in one place
  Checked by AVG - www.avg.com
  |  | - The Matronics Zenith701801-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		randy(at)rjhebertassoc.co Guest
				 Posted: Tue Mar 31, 2009 9:56 am    Post subject: Weak 701 Nose Gear ? |
				True Gary
 Also if the axle fails, the wheel does not turn and increased force of the wheel dragging along can put undue stress in the thin tube.
 Don’t you guys love being armchair quarterbacks.
 DO NOT Archive
 Randall J Hebert
 Randall J Hebert & Associates, Inc
 Consulting Engineers
 Ph 337-261-1976  Fx 337-261-1977
 From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Gary Gower
		n801bh(at)netzero.com Guest
				 Posted: Tue Mar 31, 2009 3:48 pm    Post subject: Weak 701 Nose Gear ? |
				Ya know, I really like the way Gary thinks. He is a true diehard experimental pilot and wants to learn all about the plane he flies. One day I hope to meet him in person..
 Ben Haas
 N801BH
 www.haaspowerair.com
