cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Thu Feb 12, 2009 8:09 pm Post subject: gel battery |
I am thinking about a new battery. The one that came with the plane when I bought it has a (overflow?) drain on the side of it and has made a mess. I suppose I could try to catch what comes out but I don't know what with or how secure I could make it.
Saw this battery on aircraft spruce, but it's a little pricey isn't it?
http://www.aircraftspruce.com/catalog/elpages/gellcellbatt.php
A fellow airport bum who is rebuilding a wrecked Titan bought a 12 volt 26 amp sealed acid battery from Interstate Batteries store.
Could I go with that or should I spend the extra for the gell cell? Or perhaps I could keep using the one I have... just keep it from making a mess somehow?
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
rlaird
Posted: Thu Feb 12, 2009 8:32 pm Post subject: gel battery |
Cristal --
I recently got a new Odyssey PC680 Battery for my MkIII from Quality
Power for about $120... it's got more than twice the cranking amps as
the Centennial, and is smaller.
But regardless of which you buy, definitely dump the old, spillable
battery and get a gel cell battery!!! And, yes, they are more
expensive than sealed lead-acid, but you get what you pay for.
-- Robert
On Thu, Feb 12, 2009 at 10:09 PM, cristalclear13
<cristalclearwaters(at)gmail.com> wrote:
Cristal Waters
Kolb Mark II Twinstar
Rotax 503 DCSI
http://forums.matronics.com/viewtopic.php?p 30051#230051
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Thu Feb 12, 2009 8:45 pm Post subject: gel battery |
This one from Aircraft Spruce will get the job done.
BATTERY 18 AMP SEALED BT021 $56.25
http://www.aircraftspruce.com/catalog/elpages/powersonic.php
I use a 545 Odyessey 15 Amp with the 912uls. Shouldn't have any problem
turning the 503 with 18 amp.
_________________ John Hauck
Titus, Alabama |
cristalclear13
The BaronVonEvil
Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
Posted: Thu Feb 12, 2009 9:55 pm Post subject: gel battery |
Hi Cristalclear,
What did you do to resolve your fabric/tube problem? Did you repair it or
did you do a complete recover?
Just curious...
Carlos G.
aslsa.rng(at)gmail.com Guest
Posted: Fri Feb 13, 2009 5:59 am Post subject: gel battery |
Cristal, et al, You do not want a gel cell. What you want to get may be known variously as an Absorbent Glass Mat (AGM), Starved Lead Acid (SLA), or Recombinant Gas Battery (RGB). It doesn't matter which of the three names you use, they're all the same. A gel cell is something completely different. It's more expensive and inferior in all aspects of battery performance to the AGM, SLA, RGB batteries.
Rick
On Thu, Feb 12, 2009 at 10:44 PM, John Hauck <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)> wrote:
[quote] --> Kolb-List message posted by: "John Hauck" <jhauck(at)elmore.rr.com (jhauck(at)elmore.rr.com)>
I use a 545 Odyessey 15 Amp with the 912uls. Shouldn't have any problem turning the 503 with 18 amp.
" target="_blank">http://www.matronics.com/Navigator?Kolb-List
MS -
e -
-Matt Dralle, List Admin.
Posted: Fri Feb 13, 2009 7:54 am Post subject: gel battery |
Cristal
Kind of interesting some of the advise we get. You get what you pay for.
It's like money in the bank. Or my personal favorite... cheep is $49 a year.
If you don't have unlimited funds the best advice is, Pay extra for NEEDED
features, quality is always good but don't pay for marketing hype.
What is your battery for? If it fails it is nothing that will kill you or
cause a forced landing, so why does it need to be aircraft grade or
expensive. Yes I know freak things can happen but they can happen to the
expensive stuff too.
I use the lightest battery I can find. Light planes fly better than heavy.
Besides I put enough weight in the pilot's seat I don't need any more
ballast. I use a 12 volt 12 amp riding lawn mower battery. The greater the
amp rating the heaver they are. Why not use just enough to start your
engine? I have tried the more expensive brands and they don't seem to last
any longer than the cheep ones so Wal-Mart brands are my batteries of
choice. My batteries get stressed pretty bad so initially they didn't last
more than a few years. About 6 years ago I started hooking a battery
maintainer to the battery between every flight and more importantly all
winter. The last battery was four years old and still going strong but I
didn't want to risk getting stranded at Oshkosh so I bought a new one. After
all it didn't cost much. If you have a expensive battery would you tend to
keep it till it let you down?
My battery is a wet cell so I have a vent line that extends out the bottom
of the fuselage. I never noticed any mess. All wet cells need to be vented
outside anyway due to their corrosive and explosive gasses.
Rick Neilsen
Redrive VW powered MKIIIC (the plane is in Michigan while I'm in Florida for
the winter)
by0ung(at)brigham.net Guest
Posted: Fri Feb 13, 2009 8:16 am Post subject: gel battery |
Cristal Waters
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Cristal
This is the type of battery I use in my MKIII to start my 912
http://www.arizonabattery.com/?page=shop/flypage&product_id=58&category_id=b
291dca6cea297f2a41f49052a63d38d&
If the link does not work go to http://www.arizonabattery.com and search
all batteries, pick 12 volts and scroll down it is a 18 amp hour. And
has a better price than the one you had found.
I have ordered from Arizona battery before and the product is on your door
in3 or 4 days.
Then if you are not in a hurry,,, the last one I ordered was from harbor
freight as a replacement battery for one of their jump starts. Seems like
the cost was around 18 dollars and 4 or 5 dollars for freight so I ordered
2 and the freight remained the same.... now the not being in a hurry bit,
it took 4 or 5 months, and I am nearly sure it was put on a container ship
from china.
Boyd young
Kolb MKIIIC
Posted: Fri Feb 13, 2009 8:18 am Post subject: gel battery |
Richard, I vote for cheap, too. The new 20 AH AGM battery I bought for the trike last year was $38 from the local battery shop. It starts the HKS with its 11.3 to 1 compression ratio like a champ. My buddie Wayne has the Oddysey 680 in his LongEZ with a 200 horse IO-360. Vrooom.
Rick
On Fri, Feb 13, 2009 at 9:53 AM, Richard & Martha Neilsen <NeilsenRM(at)comcast.net (NeilsenRM(at)comcast.net)> wrote:
[quote] --> Kolb-List message posted by: "Richard & Martha Neilsen" <NeilsenRM(at)comcast.net (NeilsenRM(at)comcast.net)>
Cristal
Kind of interesting some of the advise we get. You get what you pay for. It's like money in the bank. Or my personal favorite... cheep is $49 a year. If you don't have unlimited funds the best advice is, Pay extra for NEEDED features, quality is always good but don't pay for marketing hype.
What is your battery for? If it fails it is nothing that will kill you or cause a forced landing, so why does it need to be aircraft grade or expensive. Yes I know freak things can happen but they can happen to the expensive stuff too.
I use the lightest battery I can find. Light planes fly better than heavy. Besides I put enough weight in the pilot's seat I don't need any more ballast. I use a 12 volt 12 amp riding lawn mower battery. The greater the amp rating the heaver they are. Why not use just enough to start your engine? I have tried the more expensive brands and they don't seem to last any longer than the cheep ones so Wal-Mart brands are my batteries of choice. My batteries get stressed pretty bad so initially they didn't last more than a few years. About 6 years ago I started hooking a battery maintainer to the battery between every flight and more importantly all winter. The last battery was four years old and still going strong but I didn't want to risk getting stranded at Oshkosh so I bought a new one. After all it didn't cost much. If you have a expensive battery would you tend to keep it till it let you down?
My battery is a wet cell so I have a vent line that extends out the bottom of the fuselage. I never noticed any mess. All wet cells need to be vented outside anyway due to their corrosive and explosive gasses.
Rick Neilsen
Redrive VW powered MKIIIC (the plane is in Michigan while I'm in Florida for the winter)
Posted: Fri Feb 13, 2009 12:03 pm Post subject: gel battery |
At 08:09 PM 2/12/09 -0800, you wrote:
Cristal Waters
Rotax 503 DCSI
Cristal,
Due to weight constraints, I use an ULTRASTART-RED BATTERY - 11-00375 -
$89.95 from http://www.aircraftspruce.com/catalog/elpages/atphighpwr.php. It
weighs 4.4 pounds. I am on my second battery. See below - sent to the List
July 5, 2008.
To get by with such a small battery, I always prime the engine, and pull the
propeller through two compressions to move the charge into the case and
cylinder. Then I rotate the propeller backwards against compression to give
the starter a full run against compression in the forward direction. This
approach minimizes battery current capacity. In my case the Victor 1+ never
fails to hit on the first time over. The only time it will fail to remain
running is if I remove the choker too soon.
FWIW
Jack B. Hart FF004
Winchester, IN
Kolbers,
No July fourth flyby this year. A couple months ago I had trouble getting
the engine started after the FireFly had set in the hangar for a couple of
weeks. I put a trickle charger on the battery to bet the engine started.
When I got home I ordered a new ultrastart-red battery. To keep flying I
connected the trickle charger to the battery to keep it topped off while it
was in the hangar. The battery was back ordered and it came two days ago.
I did not bother to install it as I had been having no trouble with
starting the engine. But yesterday, the battery died, and so I did not get
to make my flyby.
I checked out my log. The battery started the engine for 467 flights over a
period of six years and two months. At current battery cost, it figures out
to 21 cents per flight to keep from pulling a rope or hand propping.
