herbgh(at)nctc.com Guest
Posted: Wed Feb 11, 2009 11:39 am Post subject: Poly Fiber & pop rivet holes, plus some US Military photos |
Drill holes first...then burn through fabric
after tautening...then reinforcement tapes..more
burning...rivets,,,poly brush etc... Herb
At 01:21 PM 2/11/2009, you wrote:
Kolb guys,
I have a question regarding the pop rivets on the fabric on the wings.
Is there a proper way to drill the holes? What
I mean is, should I drill all the holes in the
ribs FIRST, and then melt the holes through the
finished faric, with a soldering iron? Or,
would it be better to do all the fabric,
reinforcing tapes, etc, and then drill through a final layers?
It would seem to me the better way would be
to drill all the holes in the ribs first. The
reason I think this is because I can make a
nice 90* drilling jig, to insure the holes are
centered on the top of the rib. I'm afraid if
I try to drill the holes after the fabric and
tape is on, I run the risk of off-centered holes...making a lop-sided rivet.
Anybody? Anybody?
Mike Welch
MkIII finally (!!!) putting fabric on
flaps. So far, Poly Fiber on ALL tailfeathers,
fuselage, both ailerons, & one flap. One more
flap, and then the wings!! It's about time!!
I just received an email from my step-father, a WW II retired Lt Commander.
He forwarded to me an email of some of the
most awesome military photographs I've ever seen.
(mostly flying photos)
If you want to see them, I absolutely
guarantee you'll be amazed, send me an email,
and I'll forward them on to you. They WILL be
worth your time, unless you're a tree hugging hippie!
Windows Live™: Keep your life in sync.
http://windowslive.com/howitworks?ocid=TXT_TAGLM_WL_t1_allup_howitworks_022009
Posted: Wed Feb 11, 2009 12:34 pm Post subject: Poly Fiber & pop rivet holes, plus some US Military photos |
| Quote: | after tautening...then reinforcement tapes..more burning...rivets,,,poly
brush etc... Herb
Herb:
I burn once.
Put a tick mark beside each rivet hole to help line up after the reinforcing
tape is on.
If hole location is questionable, can use a pick to help locate.
Saves another operation.
_________________ John Hauck
Titus, Alabama |
