Tim Olson
Posted: Thu Feb 12, 2009 4:47 am Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
I'd like to see a picture of why the wheel change fixes all of these
issues and is so great. I don't understand....it seems that Matco
now fixed the Axle, and that it's just Van's that chose the wrong
wheel. So if a builder has the correct wheel and the Matco axle,
wouldn't they be perfectly happy too? I need some photos to know
why the Grove gets praise in the situation...does the axle design
not allow it to spin or spacers spin?
Also, with the Matco axle, even with the old Matco rims that aren't
the "right" ones, the valve stem should clear fine from the looks
of it...and that's with the cap.
Don McDonald wrote:
[quote] Ditto Rick. I believe all 4 RV10's in this area have gone to the Grove
wheel. At least the 2 in Lincoln for sure. One had all the problems
from the beginning with the stock wheel, and since the switch, no
problems at all. We did do some work prior to flight to insure the axle
stayed locked. Once I get flying, I'll comment further.
Don McDonald
--- On *Wed, 2/11/09, ricksked(at)embarqmail.com
/<ricksked(at)embarqmail.com>/* wrote:
From: ricksked(at)embarqmail.com <ricksked(at)embarqmail.com>
Subject: Re: Matco RV-10 Nosewheel Axle replacement
write-upMatco RV-10 Nosewheel Axle replacement write-up
To: "Rv" <rv10-list(at)matronics.com>
Date: Wednesday, February 11, 2009, 8:19 PM
FWIW, as a late post on my part, I bought the Grove wheel and
axel...only thing I can say is it's really nice to have a complete
engineered WORKING assembly with no valve stem, bearing preload or
spacers to deal with....I hope that this is the final answer to what
equates to a very simple engineering solution...the nose wheel never
should have generated this much trouble...I knew there would be a
point in my life I would regret not getting my P.E. Stamp...
Rick Sked
40185
Oh so close
Sent via BlackBerry by AT&T
*From*: John Gonzalez
*Date*: Wed, 11 Feb 2009 19:49:50 -0800
*To*: RV 10 group<rv10-list(at)matronics.com>
*Subject*: RE: Matco RV-10 Nosewheel Axle replacement
Okay. I am about to put the nose whell on the plane C but I am
ordering th= e SS axle. If I stick with the current wheel C I know
it will work with th= e SS axle C but i will not be able to put the
valve stem cap on...is this = correct.=A0
If I call Matco and ask for the other half o= f the rim C will it
work with the SS axle???
I am= inclined to leaving the valve cover off. Talk about making
thing complicat= ed...Good grief Charlie Brown!
What else am I miss= ing?
> From: pascal(at)rv10builder.net > To: rv10-list(at)matronics.com
> Subject: Re: Matco RV-10 Nos= ewheel Axle replacement
write-upMatco RV-10 Nosewheel Axle replacement wri= te-up
> Date: Wed C 11 Feb 2009 18:34:36 -0800
> --> RV10-List= message posted by: "pascal"
<=3Bpascal(at)rv10builder.net>
> yep!<= br>>
> WHLNW511.25 C just in case
> P
> From: "RV Builder (Michael Saus= en)" <=3Brvbuilder(at)sausen.net>
> Sent: Wednesday C February 11 C 200= 9 5:39 PM
> To: <=3Brv10-list(at)matronics.com>
> Subject: RE: RV10-Li= st: Matco RV-10 Nosewheel Axle replacement
write-upMatco
> RV-10 Nosewh= eel Axle replacement write-up
>= > Don't recall off hand but they know as soon as you say RV-10.
>>= michael
kdbelue(at)charter.net Guest
Posted: Thu Feb 12, 2009 6:12 am Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
I believe the Matco and Grove wheels are both workable solutions to
the nose wheel issues. I installed the Grove wheel and like it better
than the Matco because the wheel should spin freely with the nose
wheel held off the ground. The Grove wheel spins freely, but the Matco
won't because it has more drag due to the bearings/seals. The Grove
bearings/seals are the same as the main gear wheel bearings and don't
drag. My hanger entrance has a slight incline and I could not push the
plane in by myself with the Matco wheel, but I can now that I have the
Grove wheel installed. I really like the Grove axle because there are
no adjustments- put it on and it works. The spacers have pins that
prevent them from spinning.
Kevin Belue
RV-6A
RV-10
> Grove wheel. At least the 2 in Lincoln for sure. One had all the
> problems from the beginning with the stock wheel, and since the
> switch, no problems at all. We did do some work prior to flight to
> insure the axle stayed locked. Once I get flying, I'll comment
> further.
> Don McDonald --- On *Wed, 2/11/09, ricksked(at)embarqmail.com /<ricksked(at)embarqmail.com
> what
> never
> Rick Sked
> 40185
> Oh so close
> know
> the
> John
> replacement
> > yep!<= br>>
> > P
> replacement
> write-upMatco
> Sausen)"
> RV-10.
> >>= michael
ricksked(at)embarqmail.co Guest
Posted: Thu Feb 12, 2009 8:43 am Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
Tim Olson
If you have a Matco nosewheel axle for them, you shouldn't have
a problem running a valve cap on the stem, regardless of the wheel
you use. With the "right" wheel you'll have tons of clearance,
with the "wrong" wheel it'll still work fine. Just note that
I've had all versions of axles/spacers from Van's, And the
Matco Axle setup, and I've always had the "wrong" wheel, and
I STILL have always been able to always run a valve cap. I
just didn't have as much clearance in the past as I do now, now
that I have the Matco Axle setup. For that matter, even if
something weren't yet perfect, it could be fixed easily by
shaving a 1/16" off of the spacer on one side of the
axle, and adding a large flat washer on the other side.
But I hesitate to even say that because that's going to an
extreme that is probably way unnecessary.
Also, if you order the grove nosewheel, I don't think you want
the Matco axle assy, from what it sounds like...although I've
never seen a grove axle assembly picture.
Bob and Karen Brown wrote:
[quote] OK, earlier this week, I ordered the Matco nosewheel axle for both the
RV7A and the RV10. Here’s my question, does that mean I still have to
order the Grove nosewheel if I want to put on the darned valve stem
cap? If I order just the Grove nosewheel, do I still NEED the Matco
nosewheel axle assy? Call me confused…
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*ricksked(at)embarqmail.com
*Sent:* Wednesday, February 11, 2009 8:20 PM
*To:* Rv
*Subject:* Re: Matco RV-10 Nosewheel Axle replacement
should have generated this much trouble...I knew there would be a point
Rick Sked
40185
Oh so close
Okay. I am about to put the nose whell on the plane C but I am ordering
th= e SS axle. If I stick with the current wheel C I know it will work
with th= e SS axle C but i will not be able to put the valve stem cap
If I call Matco and ask for the other half o= f the rim C will it work
with the SS axle???
I am= inclined to leaving the valve cover off. Talk about making thing
> --> RV10-List= message posted by: "pascal" <=3Bpascal(at)rv10builder.net>
> yep!<= br>>
> P
write-upMatco
>>= michael
pascal(at)rv10builder.net Guest
Posted: Thu Feb 12, 2009 9:35 am Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
From what I know $299 at Grove gets it all axle, rim etc..
If you already have the Matco rim, send it back to Matco and get the "right" one. I needed to verify that I had an issue first so I was charged as a used rim, even at that price it turned out to be less expensive than the Grove would have been.
Sent: Thursday, February 12, 2009 8:42 AM
Subject: Re: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-10 Nosewheel Axle replacement write-up
----- Original Message -----
From: "Bob and Karen Brown" <bkbrown(at)minetfiber.com (bkbrown(at)minetfiber.com)>
Sent: Thursday, February 12, 2009 8:12:37 AM GMT -08:00 US/Canada Pacific
Subject: RE: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-10 Nosewheel Axle replacement write-up
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);}
OK, earlier this week, I ordered the Matco nosewheel axle for both the RV7A and the RV10. Here’s my question, does that mean I still have to order the Grove nosewheel if I want to put on the darned valve stem cap? If I order just the Grove nosewheel, do I still NEED the Matco nosewheel axle assy? Call me confused…
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com
Sent: Wednesday, February 11, 2009 8:20 PM
To: Rv
FWIW, as a late post on my part, I bought the Grove wheel and axel...only thing I can say is it's really nice to have a complete engineered WORKING assembly with no valve stem, bearing preload or spacers to deal with....I hope that this is the final answer to what equates to a very simple engineering solution...the nose wheel never should have generated this much trouble...I knew there would be a point in my life I would regret not getting my P.E. Stamp...
Rick Sked
40185
Oh so close
Date: Wed, 11 Feb 2009 19:49:50 -0800
To: RV 10 group<rv10-list(at)matronics.com>
Okay. I am about to put the nose whell on the plane=2C but I am ordering th= e SS axle. If I stick with the current wheel=2C I know it will work with th= e SS axle=2C but i will not be able to put the valve stem cap on...is this = correct.=A0
If I call Matco and ask for the other half o= f the rim=2C will it work with the SS axle???
I am= inclined to leaving the valve cover off. Talk about making thing complicat= ed...Good grief Charlie Brown!
[quote] From: pascal(at)rv10builder.net
Subject: Re: Matco RV-10 Nos= ewheel Axle replacement write-upMatco RV-10 Nosewheel Axle replacement wri= te-up
Date: Wed=2C 11 Feb 2009 18:34:36 -0800
yep!<= br>>
WHLNW511.25=2C just in case
P
Sent: Wednesday=2C February 11=2C 200= 9 5:39 PM
Subject: RE: RV10-Li= st: Matco RV-10 Nosewheel Axle replacement write-upMatco
> --> RV10-List message posted by: = "RV Builder (Michael Sausen)"
>= michael
Posted: Thu Feb 12, 2009 10:02 am Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
Although one may argue that the cap is not necessary, with my finishing kit
and following the instructions to a "t" there is no way I would have been
able to work a solution to allow me to keep a cap on the valve. I had close
to 1/8th overlap with the cap and 1/16th without, even moving spacers and
such would not have worked for me.
I simply want to let many know that in this case what may not work for me or
Tim may or may not work for someone else. Given the chance get the right
tool for the job, in this case the right rim, you can do what I did and see
if it's going to impact you and if it does replace it or you can just do as
many have said, tell Van's to keep the "wrong" rim and order the right one
directly either Grove or Matco.
I ended up ordering a new rim with the axle, I could have tested the new
axle and seen if that solved the gap issue before possibly needing to
replace the rim but I'm okay with having replaced it with the "right" piece.
Pascal
Sent: Thursday, February 12, 2009 8:43 AM
> *From:* owner-rv10-list-server(at)matronics.com
> *To:* Rv
> Rick Sked
> 40185
> Oh so close
> with the SS axle???
> John
> > yep!<= br>>
> > P
> write-upMatco
> >>= michael
gengrumpy(at)aol.com Guest
Posted: Thu Feb 12, 2009 7:03 pm Post subject: Matco RV-10 Nosewheel Axle replacement write-upMatco RV-1 |
I'm with Tim on this one........
grumpy N184JM and flying
> further.
> what
> never
> Rick Sked
> 40185
> Oh so close
> know
> the
> John
> replacement
> > yep!<= br>>
> > P
> replacement
> write-upMatco
> Sausen)"
> RV-10.
> >>= michael
