Affixing an Engine Ground
longg(at)pjm.com
PostPosted: Fri Feb 13, 2009 7:51 am    Post subject: Affixing an Engine Ground Reply with quote
I have a new IO-360 and I am at a loss as to the best place to bolt the ground wire. Do any of you have a suggestion? A picture may be valuable here.
Along the same lines, my craft is fiberglass and I am wondering if it’s smart to have two such ground running from the firewall to the engine.
Glenn
PostPosted: Sat Feb 14, 2009 4:55 am    Post subject: Affixing an Engine Ground Reply with quote
valuable here.
it's smart to have two such ground running from the firewall to the engine.
One is sufficient. Assemblies on airplanes held together
with big bolts are generally considered failure free if
assembled per instructions.
Even if the airplane is metal, the engine sits on
non-conductive shock mounts. Some designers have
called for conductive bonding straps around the
shock mounts for the purpose of electrically
connecting the engine to the engine mount and
ultimately to the airframe at the firewall.
But if you plot out all the series and paralleled
connections in such an array of conductors, it
becomes apparent that the most effective and
simple process is the fat-wire or braided
ground jumper from the crankcase to a high-quality
ground on the firewall, i.e. forest-of-tabs
or equal.
I'd be pleased to have photos of good connections
to the crankcase on various engines. I'll publish
them on the website.
( -Thomas Paine 1776- )
