bobmeyers(at)meyersfamily Guest
Posted: Wed Feb 18, 2009 8:47 pm Post subject: Z-11 with a permanent magnet alternator |
Hi Bob,
I love this list and how active you are on it.
I am trying to finalize my electrical plan for my Aerovee powered
Sonex. I used Z-11 as my starting point but I have one remaining issue.
Since the 20 amp alternator on the Aerovee is a permanent magnet type,
I do not need to wire up the alt field as I would with a regular
alternator. The problem I have then is how do I kill the alternator if
I want to kill the master bus?
Do I need to? I would think so. With the master off and the battery
disconnected by the contactor, the alternator would still be powering
the master bus. Should I put a relay or contactor on the DC output
from the supplied regulator? I could connect the DC output to the
battery directly, which would allow the master bus to be killed by the
battery contactor but the alternator would still be live.
What are your thoughts?
Bob Meyers
Building Sonex 982SX Web Site Index http://meyersfamily.org/Sonex982.html
Posted: Thu Feb 19, 2009 8:25 am Post subject: Z-11 with a permanent magnet alternator |
At 10:43 PM 2/18/2009, you wrote:
Quote: |
<bobmeyers(at)meyersfamily.org>
Hi Bob,
If you have a small, PM altenrator, then Z16 is the more appropriate
architecture.
Quote: | Do I need to? I would think so. With the master off and the battery
Yes, that is a feature of Z-16 and other designs that
feature alternators with no external control over the
field.
( -Thomas Paine 1776- )
Posted: Thu Feb 19, 2009 11:23 am Post subject: Z-11 with a permanent magnet alternator |
Thanks Bob,
With the word Rotax in the title I never even looked at Z16. My
apologies.
Having looked at it and Z17 as well, Z17 shows a voltage regulator
with three leads - two AC in and one DC out - which looks like the
configuration of the regulator supplied with my Aerovee. It seems Z16
is specific to the regulator supplied with the Rotax.
Unless I am missing something, the Z17 configuration is what I will
look at.
Thanks again.
Bob Meyers
On Feb 19, 2009, at 10:23 AM, Robert L. Nuckolls, III wrote:
> Hi Bob,
> issue.
> type,
> if
architecture.
field.
