FamilyGage(at)aol.com Guest
Posted: Thu Feb 19, 2009 3:34 pm Post subject: engine stoppage |
Gentlemen:
Several comments that I did not include in a recent e-mail.
The engine stoppage will occur any time or place that one aggressively brings the throttle back to idle. This will occur in the air when practicing maneuvers, or on the ground when another plane or object will cause one to close the throttle rapidly. Think ahead and be gentle with the engine.
We also had a problem with a loss of up elevator feel during short landings and practicing stalls. Purchased the Ray Allen electric elevator trim from Lightning, and this made a major change in the control inputs. Should you have this situation, this is a good investment.
Ray Gage
83TW
You can't always choose whom you love, but you can choose how to find them. Start with AOL Personals.
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
Clive J
Posted: Fri Feb 20, 2009 1:02 am Post subject: engine stoppage |
Ray, what you describe below shouldn't happen you should be able to
'smartly' close the throttle without the engine stopping.
Smooth control aside you should be able to make reasonably aggressive
throttle reductions without it stopping.
Check the idle mixture and idle settings again. Read the Bing section of
the Jabiru manual, it's all there.
If it still happens check with your dealer.
Just MHO!
Regards, Clive
pete(at)flylightning.net Guest
Posted: Fri Feb 20, 2009 6:11 am Post subject: engine stoppage |
I know we’ve covered this topic before but without a throttle stop to prevent excessive force at the carb throttle arm a strong pull on the throttle will actually bend the throttle adjustment screw on the carb. There is a metal tab attached to the carb that holds the idle rpm adjustment screw. This is a stamped piece of steel but there is more than enough force that can be applied, especially with our throttle arm extension, to bend this stamped piece.
A throttle stop applied as Nick detailed in previous emails will prevent excess force from bending this metal piece. If you do not have a throttle stop installed then you should do so soon to prevent bending the idle adjustment tab or bending the cable attach bracket on the carb.
Pete
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of FamilyGage(at)aol.com
Sent: Thursday, February 19, 2009 5:31 PM
To: lightning-list(at)matronics.com
Subject: engine stoppage
Gentlemen:
Ray Gage
83TW
You can't always choose whom you love, but you can choose how to find them. Start with AOL Personals. Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum You cannot attach files in this forum You cannot download files in this forum
