Dick Maddux
Posted: Fri Feb 20, 2009 4:51 am Post subject: new bush landing gear |
I recently purchased a new landing gear for my aircraft and installed it the last two days.It is the "Bush" gear offered by [url=Highwing LLC]Highwing LLC[/url].
My aircraft had the original narrow landing gear and it has worked fine since I bought the aircraft about a 1 1/2 years ago. I had read about some of the possible problems with the original gear such as hard landings cracking tubes,side loads folding the gear,etc.. The bungee changing every year or so was also going to be a pain in the butt. Now my gear has been fine with no problems but when I saw the new bush gear that Lowell and Mark were working on,I had to have it ! I had previously installed the retro elevator trim kit that his company offers (as well as the radiator shutters,throttle bug,etc) so I knew the quality would be first class.
I had considered the Grove gear which I know is a fine gear,but I would have to go thru the expense of changing my axles,brakes and wheels. This would be a bit sporty in the money department !
I talked to Lowell and he said he would build me a "bush" gear which would fit my original axles,wheels etc and would bolt right on to my fuselage (ie: plug and play) He also offered to build super deluxe fairings to cover the gear legs. I agreed and I now have the gear.
It was indeed a bolt on unit . The quality of the welds and design is fantastic! And those aluminum fairings,WOW !
The old gear legs weighed 13.2 lbs. The Grove gear is advertised at 24 lbs and this gear with fairings and all weighs 9 lbs !!! and the best part is that it fits my old axles,brakes and wheels so it saved me a lot of money ! I have no intent of landing on rocks,logs old cars ,etc so I don't want the larger axles or 26" wheels.( I am using the Nanking (sp) smooth tires) I will use the aircraft to land at my grass strip,and airport bum at local airports. Now I could take this gear off airport as it is certainly very stout !
Here is the bad part. I have a few pictures of the installation but my main computer is in for repairs and it has the picture program. I will get it back today and send in some pictures.
In the mean time I have to install longer brake lines and do some other work prior to flying so it will be a few days before I have a flight report. It sure does look nice on the aircraft ! Can't wait to fly it!
Dick Maddux
Fox 4-1200
Rotax 912UL
Pensacola,Fl
Need a job? Find an employment agency near you.
henrysfork1(at)msn.com Guest
Posted: Fri Feb 20, 2009 5:16 am Post subject: new bush landing gear |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> How about a picture of the new gear?
Lynn Matteson
Posted: Sat Feb 21, 2009 7:56 am Post subject: new bush landing gear |
This might be a bit late in coming, but when I went to a Grove gear,
I didn't have to change the brakes or the wheels...axles, yes, which
came with the gear package...probably at some small extra cost. But
the brakes and wheels are the same as when I bought the unfinished
plane, and they are a direct bolt-on. Yes, you do have to order the
gear specific for those brakes and wheels, but this is all spelled
out on the Grove site, or if ordering from John McBean (I think he is
a dealer) tell him what you have.
This is not to diminish what Lowell is building and selling, just to
set the record straight from my perspective about what is involved
with going to a Grove gear.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
New skis off last week...5 minutes, and probably back on this week...
10 minutes, as it's snowing right now.
On Feb 20, 2009, at 7:43 AM, Catz631(at)aol.com wrote:
(snip)
| Quote: | I had considered the Grove gear which I know is a fine gear,but I
(snip)
Dick Maddux
Fox 4-1200
Rotax 912UL
Pensacola,Fl
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sat Feb 21, 2009 8:36 am Post subject: Re: new bush landing gear |
Alright, I am curious enough and like to know what aftermarket parts are available for my toy so I will ask. I checked the website and saw some cool stuff but I did not see the gear, so how much did it cost? I definitely plan on going "off roading" so bigger, sturdier gear would be nice.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
tc9008(at)AOL.COM Guest
Posted: Sun Feb 22, 2009 5:09 am Post subject: new bush landing gear |
How do I get in touch with Lowell. Sounds like a go idea.
Travis
Kitfox IV
