Posted: Tue Feb 24, 2009 10:25 am Post subject: FireFly Stall Pre-Buffet |
Kolbers,
Before I offset the thrust line, the FireFly would stall/mush straight
ahead. After I lowered and offset the thrust line to get more air over the
horizontal tail surfaces and to center the ball without a tab on the rudder,
things changed. The thrust line has been moved to the left. This gives the
left wing a little more lift than the right. At idle and pulling the stick
slowly back the FireFly right wing will buffet lightly and then falls off to
the right. With power on, the buffeting is much more pronounced. It gives
an early warning, to not pull the stick further back. If you do, it will
continue to buck with increasing amplitude until the right wing stalls
continuously and over you go.
This is the disadvantage of an off set thrust line to trim out the FireFly
at cruise. Use of a rudder trim tab instead of offset thrust line would
solve this problem.
Jack B. Hart FF004
Winchester, IN
