AirMike
Posted: Sat Feb 28, 2009 5:55 pm Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
Ugg - what an ugly job. My 2 cents worth. First read the instructions like it says in vans instruction kit. The diagrams suck, so you have to read them and look at them several times. Also read Tim Olsen's excellent post on this item - it has a lot of good info. You kind of have to work on all of the parts together but start on the nose extension early. The whole process requires that you put on and take off the cowl about 50 times.
1. I think that the reason that Tim had trouble on the alignment is that the box is twisted as it comes from Vans - it is not straight.
2. I fitted my upper aluminum part of the box to the nose to get the length right and the alignment. It seemed to work out well. Not so great on the length, but great on the alignment. I cut off too much of the nose extension and had to glue it back on.
3. Do not overlook DLM's post on reinforcing the alt air system. Do not want to suck anything into your nice engine. Essentially, he says to put a reinforcement ring INSIDE the FAB to reinforce the flimsy fiberglass so that your rivets do not get sucked into the engine. His glass box failed at the rivets at 100 hrs. Thanks for the heads up Dave
4. Finally, spend a bit of time getting the cut out right for the mixture lever. It is a bit difficult to get the cut out just right on the pilot side of the box, and you do not want to have to redo it.
5. Be mindful of the orientation of everything especially the recessed aluminum top to the FAB and the dimple direction
Any other hint on this ugly job will help all
Good luck on an ugly job. If you need pics or anything leave me a message
_________________ OSH '10 or Bust
Q/B - finally done |
Tim Olson
Posted: Sat Feb 28, 2009 6:16 pm Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
Mike, I wasn't sure which thing you were talking about that
I wrote...is this the page?
http://www.myrv10.com/N104CD/engine/20051127/index.html
It's been so long that I don't remember as much about it
as I should, other than that glassing the nozzle on the cowl
was a pain in the butt, building the FAB was a pain in the
butt, and the directions kind of stunk. It really wasn't
THAT bad, but by the time you're at this step, building
and fiberglass is starting to get old. I have yet to put
the reinforcement ring inside mine, but thanks for bringing
it up again...I need to remember to do that next time the
cowl is off.
There are definitely more fun parts of the plane to build.
I was just thrilled that being an IO-540, I didn't need
to install carb heat.
AirMike wrote:
Dave
message
-------- OSH '08 or Bust (busted) be there in "09 Q/B Kit -
wiring and FWF
http://forums.matronics.com/viewtopic.php?p 32536#232536
AirMike
Posted: Sun Mar 01, 2009 12:07 am Post subject: Filtered Air Box - Copy of DLM post of 1/10/08 |
dlm46007(at)cox.net
Posted: Mon Nov 10, 2008 8:44 pm Post subject: Air box and alternate air door
Just pulled the cowl for first 100 hours inspection. Found the galvanized ring (VA192A) of the alternate air door partially pulled from the bottom of the air box. the rivets had pulled through the glass and the nut plate for the door pivot was holding it there. To fix this I fabricated an aluminum ring for the inside and match drilled the ring and galvanized ring. I cleaned the bottom with a scotchbrite pad and grinder and put two additional layers of glass on the bottom. I will epoxy putty the VA192A and the fabricated ring to the box and rivet (1097s) after cure. I will then add small dabs of RTV on the rivet buck tails on the inside to ensure that even if a rivet breaks, nothing will enter the injection system.
Jim Berry
Posted: Sun Mar 01, 2009 10:13 am Post subject: Re: Filtered Air Box - FAB (Filtered air BITC..... |
No one seems to enjoy making the air inlet nozzle on the lower cowl. I used a different method that was easier and resulted in a very smooth transition to the air box.
Instead of carving a hole in the foam with a hacksaw and trying to create a smooth contour, I reversed the process. I cut a piece of foam thick enough to fill the gap from the back of the existing cowl inlet to the front of the air box. Reach through the cowl inlet and press the foam into the air box, so that the air box leaves an indentation in the aft side of the foam. While holding the foam in this position, hot glue the forward side of the foam to the cowl inlet. Remove the cowl, being careful not to knock the foam loose. It is now very easy to shape the foam to the indentation on the aft side of the foam and the existing cowl inlet on the fore side. Lay up the fiberglass on the outside of the foam plug and you will have a perfect contour from the cowl to the air box. No messing around with trying to lay glass inside a female form. No messing with balloons. When the glass is cured carve out the foam, and you will have an interior surface that needs very little cleaning up.
Jim Berry
40482
N15JB
AirMike
Posted: Wed Mar 04, 2009 2:38 pm Post subject: Filtered Air Box - FAB fitting |
Any suggestions on fitting the baffle seal between the FAB & the inlet?
Jim Berry
Posted: Wed Mar 04, 2009 3:28 pm Post subject: Re: Filtered Air Box - FAB (Filtered air BITC..... |
I thought this was going to be a chore, but it turned out not to be. I have a 1/2" gap between the aft edge of the inlet and the forward edge of the FAB, so I made the baffle strips 1" wide. Installed them so they were in plane with the top, sides and bottom of the FAB. The material is flexible enough that it adjusts to any minor misalignment. It may have been pure luck, but it worked out well.
Jim Berry
40482
N15JB
Posted: Wed Mar 04, 2009 6:21 pm Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
I may get flamed for this, but I have seen this done and tried it
myself and it works great and saves a bunch of work, as well as making
the cowl easier to get on/off. Spruce sells rolls of rubber baffle
seal that is thicker and stiffer than the Van's supplied material.
This seal material can cover a 1"+ gap from the FAB to the cowl inlet
and the cowl can remain as it comes from Van's. I will look for some
pictures, but I don't think I have any close at hand.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On Mar 4, 2009, at 5:38 PM, AirMike wrote:
inlet?
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 33230#233230
ricksked(at)embarqmail.co Guest
Posted: Wed Mar 04, 2009 7:08 pm Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
No reason to flame Jesse, I've seen quite a few FAB to cowl inlets without any seal...I think a good stiff seal mounted on the FAB and cut to fit up close on the non-tubed inlet is a great idea. Its not like the air won't flow right into the FAB...of course it only applies to non cold air induction ala Deems and other "Hotrods".
Rick S
40185
Sent via BlackBerry by AT&T
Deems Davis
Posted: Wed Mar 04, 2009 7:11 pm Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
I'm not sure if this will work for the FAB to Cowl, but here's how we
did on on the Will James cowl.
http://deemsrv10.com/album/Final%20Assembly/slides/DSC07042.html
It's a simple piece of neoprene, that is glued into a cylinder glue, and
then clamped to the cowl inlet. This is the process used for connecting
the cooling intakes for the James cowl as well.
Deems Davis # 406
DAR is showing up on Fri!!!!!
Jesse Saint wrote:
AV8ORJWC
Joined: 13 Jul 2006 Posts: 1100 Location: Aurora, Oregon "Home of VANS"
Posted: Thu Mar 05, 2009 6:17 am Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
No flames intended but a lot of information exists to supporting its reduction. Look for Fred Moreno's five part series "Homebuilt Aircraft Drag Reduction = January 2009. Part One is a pdf file of 1.06 mb. Pages 13,14 &15 address the consequences of casual cooling air & leakage air flows, baffle material, plenums,etc. Ideal case = no leaks. Interesting counter point.
Mike, contact me off list. Not interested in flaming, jousting or tying up Matt's wonderful list or I would have attached it.
John Cox
Sent: Wed 3/4/2009 2:38 PM
Subject: RV10-List: Re: Filtered Air Box - FAB (Filtered air BITC.....
[quote]--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net> Any suggestions on fitting the baffle seal between the FAB & the inlet? -------- OSH '08 or Bust (busted) be there in "09 Q/B Kit - wiring and FWF Read this topic online here: http://forums.matronics.com/viewtopic.php?p=233230#233230
AV8ORJWC
Posted: Thu Mar 05, 2009 6:25 am Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
Fred's other four parts were
Two - Reduced cooling leakage/drag for already flying aircraft
Three - Reduced airframe drag for already flying aircraft
Four - Advanced methods for reducing cooling drag in aircraft still under construction.
Five - Advanced methods for reducing airframe drag in aircraft still under construction.
See you at Osh '09
John
Subject: Re: Filtered Air Box - FAB (Filtered air BITC.....
jayb
Posted: Tue May 26, 2009 8:37 am Post subject: Filter Bypass Door Install |
My airbox pretty much follows the plans wrt to the location of retainers and filter. After drilling holes and test fitting, it's obvious that the control cable nutplate that holds the adel clamp interferes with the air filter. It would be smack dab in the middle of the filter.
The cable pulls the VA-192B plate OPEN, right? If so, the nutplate can't be moved inboard. It would have to be moved out further which would cause it to be close to the curve of the airbox... and the cable would then rub against the fiberglass.
What have others done? Maybe ditch the nutplate/adel clamp and glass in a tube?
Thank goodness I don't have a carb as the door fab doesn't look fun at all!
Jay
Tim Olson
Posted: Tue May 26, 2009 9:00 am Post subject: Filtered Air Box - FAB (Filtered air BITC..... |
I can't remember very well, but I did just look at mine,
and I think my adel clamp is out towards the outer rear edge
on the bottom. I agree with you...for a variety of reasons
I'm glad I have fuel injection, one of which being that
I really am glad I just had the one alternate air door to
make.
Tim Olson - RV-10 N104CD
jayb wrote:
of the filter.
in a tube?
at all!
Cheers, Jay
http://forums.matronics.com/viewtopic.php?p 45405#245405
AprilZer
Posted: Wed Jun 03, 2009 6:02 pm Post subject: Re: Filtered Air Box - FAB (Filtered air BITC..... |
I got some information that I really need here in this discussion.,I am so relief that I found this site.
Aprilaire
