jkreidler
Joined: 13 Feb 2008 Posts: 77 Location: Sheboygan Falls WI
Posted: Thu Mar 05, 2009 12:18 pm Post subject: Leaning For Taxi |
We started writing out checklists (POH) and have noticed that a few samples have the operator lean the engine after start and before taxi. What are the reasons for leaning during taxi? Upsides, downsides? Is this just a fuel savings measure, does it prevent fouling?
Just getting ready to dump in oil and fire it up!!
Thanks, Jason Kreidler
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner [quote][b]
_________________ Jason Kreidler
4 Partner Build - Sheboygan Falls, WI
Tony Kolar, Kyle Hokel, Wayne Elser, Jason Kreidler
N44YH - Flying - #40617 |
rene(at)felker.com Guest
Posted: Thu Mar 05, 2009 12:41 pm Post subject: Leaning For Taxi |
I operate out of Ogden UT ~4500 feet. Need to lean for takeoff and the plugs will foul during the taxi if I don’t. With the new engine (before first flight) I could not get from the hanger to the runup area without a little fouling. But, other than the first flight, it was manageable.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jason.kreidler(at)regalbeloit.com
Sent: Thursday, March 05, 2009 1:16 PM
Subject: Leaning For Taxi
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner | Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Tim Olson
Posted: Thu Mar 05, 2009 12:51 pm Post subject: Leaning For Taxi |
You will foul your plugs real bad if you run anything over
what's necessary to run the engine while on the ground.
So, the fix is lean real aggressively. So far that you
can't even get 2000RPM out of it during taxi. If
you do this, you won't forget to richen it before
takeoff (also if you use your checklist), because
the engine will just bog if you add throttle.
So it's just for keeping your plugs clean (and it
saves fuel as a bonus) while running at lower power.
Plugs won't foul so easily once you add power.
jason.kreidler(at)regalbeloit.com wrote:
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
ron.mcgann(at)baesystems. Guest
Posted: Thu Mar 05, 2009 1:37 pm Post subject: Leaning For Taxi |
This is an intriguing thread. I've never heard of leaning during taxi.
(A sheltered life I guess!) Looking forward to some more opinions on
this one - will be doing some taxi tests this weekend and bedding the
brakes.
Now VH-XRM on the Australian register. No longer a kit!!
Ron - can almost taste it!!
drfred(at)suddenlinkmail. Guest
Posted: Thu Mar 05, 2009 1:49 pm Post subject: Leaning For Taxi |
Jason;
Just pulled my plugs and cleaned them at 80 hrs because I didn't lean on
the ground. Another lesson learned. Started having asymmetrical mag
drops. As the other posts have said. Lean out aggressively once you
get the engine started.
Let us know when you fire it up!
Dr Fred.
#40617 N44YH
Sheboygan Falls, WI
(4) Partner Build
Jason Kreidler
Kyle Hokel
Tony Kolar
Wayne Elsner
Kelly McMullen
Joined: 16 Apr 2008 Posts: 409 Location: Sun Lakes AZ
Posted: Thu Mar 05, 2009 2:00 pm Post subject: Leaning For Taxi |
The safe way to do it with any aircraft engine is lean till the engine
almost quits while you are taxiing. That way any advance of the
throttle will make the engine stumble, so you don't forget as you take
the runway.
On Thu, Mar 5, 2009 at 2:47 PM, Fred Williams, M.D.
<drfred(at)suddenlinkmail.com> wrote:
Jason;
Just pulled my plugs and cleaned them at 80 hrs because I didn't lean on the
ground. Another lesson learned. Started having asymmetrical mag drops. As
the other posts have said. Lean out aggressively once you get the engine
started.
Dr Fred.
> #40617 N44YH
> Sheboygan Falls, WI
> (4) Partner Build
> Jason Kreidler
> Kyle Hokel
> Tony Kolar
> Wayne Elsner
A&P/IA, EAA Tech Counselor
KCHD |
Tim Olson
Posted: Thu Mar 05, 2009 2:17 pm Post subject: Leaning For Taxi |
That sounds familiar.
Also, another step that helps with the plugs that I've heard
over the years is that before you shut the engine down, you should
run it up to at least 1200RPM (or was it 1800?) for about 15-20
seconds while leaning it as far as possible...trying to get
the EGT's back up a bit and burn off any lead right before
you kill the engine. Then power down to idle, lean to cut-off,
and that helps keep things clean too.
Kelly McMullen wrote:
the runway.
> Jason;
> started.
> Dr Fred.
>> #40617 N44YH
>> Sheboygan Falls, WI
>> (4) Partner Build
>> Jason Kreidler
>> Kyle Hokel
>> Tony Kolar
>> Wayne Elsner
jump2(at)sbcglobal.net Guest
Posted: Thu Mar 05, 2009 2:32 pm Post subject: Leaning For Taxi |
Did everyone forget about running their engine at 1100-1200 rpm on the ground?
Tell them why Tim.
Patrick Thyssen
One day I will fly.
--- On Thu, 3/5/09, McGANN, Ron <ron.mcgann(at)baesystems.com> wrote:
[quote]From: McGANN, Ron <ron.mcgann(at)baesystems.com>
Subject: RE: RV10-List: Leaning For Taxi
Date: Thursday, March 5, 2009, 3:34 PM
[quote]--> RV10-List message posted by: "McGANN, Ron"
brakes.
Posted: Thu Mar 05, 2009 4:07 pm Post subject: Leaning For Taxi |
And if you still have a problem with fouling plugs put REM 39s in the
lower holes.
Linn
Tim Olson wrote:
Kellym
Joined: 10 Jan 2006 Posts: 575 Location: Sun Lakes AZ
Posted: Thu Mar 05, 2009 7:38 pm Post subject: Leaning For Taxi |
Don't think I have seen such an animal. Champion doesn't list such a
heat range. REM38E is the recommended, REM40E is okay. They don't
mention for the Comanche 260(same engine as RV-10) the REM37BY extended
nose plug, which I know is approved for the same cylinders in the O-360
and IO-360. Other than fine wire plugs, it would be the most resistant
to fouling.
linn wrote:
And if you still have a problem with fouling plugs put *REM 39s* in
the lower holes.
Linn
> Tim Olson - RV-10 N104CD - Flying
KCHD |
Tim Olson
Posted: Thu Mar 05, 2009 7:56 pm Post subject: Leaning For Taxi |
I did switch to fine wires at something just under 200 hours.
They work well. The massive electrode ones ran well for me.
With aggressive leaning, I've never had to miss a takeoff for
fouled plugs. But, the fine wires stay cleaner. The others
were fine although they don't last as long.
to fouling.
> the lower holes.
> Linn
Posted: Thu Mar 05, 2009 8:12 pm Post subject: Leaning For Taxi |
Thanks Kelly! My Alzheimer's must be getting worse. It's the REM37BY that I was thinking of!!!!
Linn
do not archive.
Kelly McMullen wrote: [quote]--> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com> (kellym(at)aviating.com)
Don't think I have seen such an animal. Champion doesn't list such a heat range. REM38E is the recommended, REM40E is okay. They don't mention for the Comanche 260(same engine as RV-10) the REM37BY extended nose plug, which I know is approved for the same cylinders in the O-360 and IO-360. Other than fine wire plugs, it would be the most resistant to fouling.
linn wrote:
| Quote: | --> RV10-List message posted by: linn <pitts_pilot(at)bellsouth.net> (pitts_pilot(at)bellsouth.net)
And if you still have a problem with fouling plugs put *REM 39s* in the lower holes.
Linn
Tim Olson wrote:
| Quote: | --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com> (Tim(at)myrv10.com)
Tim Olson - RV-10 N104CD - Flying |
Checked by AVG - www.avg.com
| [b]
jcumins(at)jcis.net Guest
Posted: Fri Mar 06, 2009 12:52 pm Post subject: Leaning For Taxi |
I do agree with leaning during taxi. But also spend the big bucks and get a
set of fine wire plugs they will last almost the full life of the engine and
are not as apt to fowl if you forget to lean. Once we did that in the
IO540K series engine we have had perfect run ups with and with out leaning.
When I do the engine on the 10 it will for sure have the fine wire p[lugs in
it. I also like the looks of the g3 mfd electronic ignition system that
will work on either bendix or slick mages.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
