Fuel Flow DisplayFuel Flow Display
Dick Maddux
PostPosted: Sat Mar 07, 2009 5:40 am    Post subject: Fuel Flow DisplayFuel Flow Display Reply with quote
Noel,
Here is a picture of my oil cooler. I have Lowell's shutters attached to the front of the cooler which I use for temp regulation. This is a file picture taken awhile back .If you need more,let me know.
        Dick Maddux
        Pensacola,Fl
Need a job? Find employment help in your area.
 Filesize:  366.36 KB
 Viewed:  1811 Time(s)
Float Flyr
PostPosted: Sun Mar 08, 2009 6:00 am    Post subject: Fuel Flow DisplayFuel Flow Display Reply with quote
Thanks Dick
When I got my engine the oil cooler was mounted to the side of the filter T think I can improve the airflow down between the cylinder banks if I mount it as you have. I was looking to see how you accomplished your mounting. I think I see.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Catz631(at)aol.com
Sent: Saturday, March 07, 2009 10:09 AM
Subject: Re: Fuel Flow DisplayFuel Flow Display
Noel,
        Dick Maddux
        Pensacola,Fl
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
