Tim Olson
Posted: Sun Mar 08, 2009 11:43 am Post subject: Wingtip Nav question |
In the Bob archer antenna install guide, it says that:
"If two VOR receivers are being installed one antenna
should be installed in each wing tip and each antenna
connected to a receiver. This type of installation
would produce twice as much signal into each receiver
and this much signal increase would mean an increase
of about 25% increase in VOR range."
Can someone explain how this could be so? Currently
I have one in a wingtip and one on the tail, but due
to some new antenna needs I may be moving my tail
antenna. I don't understand how having one in each
wingtip would affect performance, considering they're
being connected to separate receivers, and each receiver
may be tuned to whole separate VOR's.
I just don't get how it could be.
Tim Olson - RV-10 N104CD
retasker(at)optonline.net Guest
Posted: Sun Mar 08, 2009 12:13 pm Post subject: Wingtip Nav question |
What it is saying is to use two antennas (one per receiver), rather than
one antenna with a splitter.
Dick Tasker
Tim Olson wrote:
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
etienne.phillips(at)gmail Guest
Posted: Sun Mar 08, 2009 12:42 pm Post subject: Wingtip Nav question |
2 antennae on one receiver and transmitter is not as easy as it seems.
You need to match the distance between the antennae to the frequency,
and direction you expect to be receiving from...
The length of cable inbetween the antennae is also important. Not for
the faint of heart... Best case is a signal strength that is about
80% as good as 1 antenna from all directions. Worst case is that it's
twice as potent in one direction, and completely dead 90 degrees out.
Unless you're trying to make a directional antennae array in which
case the best and worst cases swap around!
For navigation, I like non-directional antennae
With this in mind, I have no idea what the install guide is referring
to. It may be that placing two non-connected VOR antennae right next
to each other causes them to interfere with one another, and by
mounting them as far apart as possible (on either wingtip) the
detrimental effects are halved.
On 08 Mar 2009, at 10:10 PM, Richard E. Tasker wrote:
<retasker(at)optonline.net>
than one antenna with a splitter.
Dick Tasker
Posted: Sun Mar 08, 2009 3:03 pm Post subject: Wingtip Nav question |
At 02:43 PM 3/8/2009, you wrote:
I think he's trading off the options for numbers
of antennas installed versus the number of radios.
One antenna and a splitter drops energy to both
radios by 50% which translates into approximately
30% drop in range for BOTH receivers.
Each receiver having its own antenna recovers that
drop in range.
Having said that, know that under controlled flight
using the airways, VORs used and prescribed
changeover points along those airways insures a
healthy signal to the radios . . . irrespective of
relatively small losses in range alluded to by Bob's
statement.
| Quote: | Can someone explain how this could be so? Currently
Everything we do in life is ultimately grounded in the
economics of energy management. Assuming all other
things equal, two antennas will deliver 2x the energy
to each radio versus one antenna and a splitter.
In real life, antenna patterns around the aircraft
will have more profound effects on range than numbers
of antennas versus radios. Wing-tip mounted antennas
cannot even come close to the overall performance of
a clear-field antenna either for gain or patterns.
In practice, they work just fine for the increasingly
rare instances that VOR navigation is truly useful.
Haven't turn a VOR receiver ON since I wrote this article
for Sport Aviation Article almost 12 years ago:
http://www.aeroelectric.com/articles/nailgun.pdf
( -Thomas Paine 1776- )
Posted: Sun Mar 08, 2009 4:55 pm Post subject: Wingtip Nav question |
They are VOR antennas for NAV radios. Last I knew the only VOR/NAV
transmissions come from the ground...
Dick Tasker
Etienne Phillips wrote:
<etienne.phillips(at)gmail.com>
the faint of heart... Best case is a signal strength that is about 80%
> Dick Tasker
Please Note:
Posted: Sun Mar 08, 2009 9:08 pm Post subject: Wingtip Nav question |
You are correct - but when dealing with aerials and radiation
patterns, it doesn't matter if you're talking about transmitting or
receiving...
As a side-note, if you have a DME instrument then you do transmit,
but it's a completely different frequency range (and therefore I'm
guessing has it's own antenna).
I agree with Bob Nuckolls though, having a single antenna, mounted in
a clear spot, is by far the best way of improving signal quality!
Good luck with your installation...
On 09 Mar 2009, at 2:54 AM, Richard E. Tasker wrote:
Dick Tasker
Tim Olson
Posted: Mon Mar 09, 2009 10:13 am Post subject: Wingtip Nav question |
Well thanks guys for clearing up the wording in the install
guide. It makes perfect and obvious sense that using 2
antennas for 2 NAV's would be way better than 1 antenna
for each.
Now for a follow-up that's a bit tougher maybe...
I need to mount an ADS-B shark fin antenna...978mhz,
putting out 50W (similar to a transponder but those
crank out more like 150W).
If I have the choice of:
A) Move a perfectly working NAV Antenna in an ideal location
to a wingtip where I know the performance won't be as good,
and putting the ADS-B in place of it.
or
B) Mounting the ADS-B antenna about 2' from the NAV antenna
and leaving everything as-is.
or
C) Moving the Marker Beacon antenna to within a few inches
of the NAV antenna, and then putting the ADS-B antenna right
where the MB currently is.
Which one seems most reasonable? I know you generally want
to keep those powerful transmitters away from other stuff,
with being on totally separate freq's, how bad is it to
have a 978mhz transmitter 2' from the NAV. Will the SL-30's
circuitry filter well enough to not be a problem do you think?
Tell you what, if you're building a kit, take the time to
come up with locations for all the possible antenna types
you could ever have, because squeezing one in can be a chore
if you want to still live by the book.
You are correct - but when dealing with aerials and radiation patterns,
it doesn't matter if you're talking about transmitting or receiving...
As a side-note, if you have a DME instrument then you do transmit, but
it's a completely different frequency range (and therefore I'm guessing
I agree with Bob Nuckolls though, having a single antenna, mounted in a
> Dick Tasker
AV8ORJWC
Joined: 13 Jul 2006 Posts: 1100 Location: Aurora, Oregon "Home of VANS"
Posted: Mon Mar 09, 2009 10:55 am Post subject: Wingtip Nav question |
Tim, your closing paragraph is invaluable. Most builders start with a
really rough Build budget, then throw caution to the wind after all the
"Golly Gee" stuff comes online. The antennas always seem to get the last
portion at the decision table.
A really progressive builder lists the avionics and their best possible
antenna needs, then conceptually generalizes antenna placement along the
ground plane or concealed under the surface. Once the antenna and its
location are known, building an AC43.13 compliant doubler makes the
plans built process even easier. The answer to this question will be
Well Watched.
I have always used you as the example of great cockpit inventory and
diverse functionality sprinkled with Midwestern practicality.
John C.
BobsV35B(at)aol.com Guest
Posted: Mon Mar 09, 2009 12:00 pm Post subject: Wingtip Nav question |
Good Afternoon Tim,
I would probably change the location of many of your antennas, but we all have different ideas as to where things should stick out from our aircraft.
However! Of the choices given, dump the marker beacon!!
I know of no situation where a marker beacon is of any use at all as long as you have an IFR approved GPS.
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 3/9/2009 1:16:07 P.M. Central Daylight Time, Tim(at)MyRV10.com writes:
| Quote: | --> AeroElectric-List message posted by: Tim Olson <Tim(at)myrv10.com>
for each.
or
or
| Quote: | --> AeroElectric-List message posted by: Etienne Phillips
> --> AeroElectric-List message posted by: "Richard E. Tasker"
> Dick = Use lities y - MATRONICS WEB FORUMS =========================< - List Contribution Web Site ; =========================
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
n8zg(at)mchsi.com Guest
Posted: Mon Mar 09, 2009 6:10 pm Post subject: Wingtip Nav question |
Tim -
Option C.
Marker beacon and nav are both receive-only. They should be perfectly happy
side-by-side.
neal
LarryRosen
Posted: Tue Mar 10, 2009 6:20 am Post subject: Wingtip Nav question |
Tim,
Why don't you put the marker beacon antenna in the wing tip, just use a
40" piece of wire, and then mount the ADS-B antenna in the current
marker beacon location.
Larry Rosen
Tim Olson wrote:
for each.
or
or
> receiving...
>> Dick Tasker
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Tim Olson
Posted: Tue Mar 10, 2009 8:06 am Post subject: Wingtip Nav question |
I may end up doing that, but the current wire wouldn't reach and
I'd have to extend it in the conduit to the wingtip.
The other variable that I didn't mention is that the current location
for my MB antenna...the one that I'd move to put in the ADS-B UAT
antenna, is also right next to my APRS antenna. So I COULD
end up moving 2 of them. I'm not sure I'll worry about the APRS
and the UAT interfering much though, as the APRS only transmits
intermittently. It would be easier to move if needed, too.
The current Marker Beacon location is really a great one ofr
the UAT antenna.
Larry Rosen wrote:
Tim,
Larry Rosen
> for each.
> or
> or
> Tim Olson - RV-10 N104CD - Flying
>> receiving...
>>> Dick Tasker
Posted: Tue Mar 10, 2009 8:25 am Post subject: Wingtip Nav question |
Good Morning Larry,
I mentioned this yesterday, but if I may repeat, why would anyone want a marker beacon receiver?
The only approach I can think of that uses a marker beacon to supply a lower MDA is the LOC-D at KSEE, Gillespie Field, San Diego. The fan marker there is called GRIGG and it has been out of service awaiting repair parts for several years. Those who have an IFR legal GPS can use it to locate the GRIGG intersection in lieu of the failed fan marker.
Even the KSEE LOC-D approach could be executed without the marker or a means of determining it's position, but it would be to a higher MDA
If you have any GPS, even a VFR one, it can supply situational awareness much better than a marker. An IFR approved GPS with a current database, can be legally used in lieu of any still functioning marker beacon.
The FAA removed the marker beacon as a required portion of the ILS several years ago. They are slowly being phased out.
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
In a message dated 3/10/2009 9:22:21 A.M. Central Daylight Time, N205EN(at)gmail.com writes:
| Quote: | Tim,
Larry Rosen
A G00126575x1219671244x1201345076/aol?redir=http:%2F%2Fwww.freecreditreport.com%2Fpm%2Fdefault.aspx%3Fsc%3D668072%26hmpgID%3D62%26bcd%3DfebemailfooterNO62"> See yours in just 2 easy steps!
Tim Olson
Posted: Tue Mar 10, 2009 9:15 am Post subject: Wingtip Nav question |
I hear ya Bob...didn't mean to ignore it. You make a good point.
The thing I can't answer is....if I have a MB receiver and
I don't put an antenna of some sort on it, could that cause
any potential problems. Probably not, but, I figure I've
already got the antenna, and the wire run, and so I may
as well terminate it somewhere. Also, even though you don't
need it to get lower minimums, it still IS an audible source
of knowing when you pass certain points, so although it has
little value, it isn't really worthless. If I were starting
over I'd probably still wire it in to a wingtip or something,
just to terminate it since I have the receiver. But, it
certainly is one of the things I'd miss the least in the panel.
Probably even less than an ADF.
BobsV35B(at)aol.com wrote:
| Quote: | Good Morning Larry,
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
630 985-8502
Stearman N3977A
Tim,
Larry Rosen
*A
See yours in just 2 easy steps!*
msausen
Joined: 25 Oct 2007 Posts: 480 Location: Appleton, WI USA
Posted: Wed Mar 11, 2009 4:27 am Post subject: Wingtip Nav question |
At the very least you will probably want to mark your PS Engineering MB lights as INOP if you disconnect your MB antenna. This is the main reason I would leave something. Another thing I have heard others do (mine is that 40" wire in the tip) is to put a 40" wire in the bottom of the cowl.
Michael
Allen Fulmer
Joined: 10 Jan 2006 Posts: 67 Location: Alexander City, AL
Posted: Wed Mar 11, 2009 10:30 am Post subject: Wingtip Nav question |
Or on the wing to fuselage lower fairing.
[quote]>>--
_________________ RV7 QB Fuselage
Eggenfellner H6 on orde
N808AF reserved
Alexander City, AL |
