jdmcbean(at)kitfoxaircraf Guest
Posted: Fri Mar 13, 2009 10:17 am Post subject: WingTanks |
Bob,
Those tanks have never been tested structurally and there are several issues with the install IMHO… not to mention weight of the install.
Fly Safe !!
John McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
matronics(at)bob.brennan. Guest
Posted: Fri Mar 13, 2009 10:45 am Post subject: WingTanks |
Hi John, thanks for jumping in on this,
Checking your parts catalogue on page 54 I see that you only have 6 gallon tanks for my model II for $440 each. My reason for perusing the wingtanks.com tanks was that I would gain 13 gallons, which is important to me; and apparently I would not be removing any struts, only a couple of drag / anti-drag tubes which look pretty weak anyway. From the pictures on their cob-website it looks like a piece of plywood more than makes up for any torsional loss from those tubes but I was hoping to exchange a few emails with them on that topic.
However, since they don't respond - I assume your 6 gallon model II tanks also fit between struts? Has anyone ever installed two 6 gallon tanks in one wing and/or can it be done?
Bob Brennan - N717GB
ELSA Repairman, inspection rated
1991 UK Model 2 ELSA Kitfox taildragger
Rotax 582 with 3 blade prop
Wrightsville Pa
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of jdmcbean
Sent: 13 March 2009 2:15 pm
Subject: RE: Kitfox-List: WingTanks
Bob,
Fly Safe !!
John McBean
Ph 208.337.5111
href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Fri Mar 13, 2009 3:29 pm Post subject: Re: WingTanks |
matronics(at)bob.brennan. wrote: | Checking your parts catalogue on page 54 I see that you only have 6 gallon tanks for my model II for $440 each. |
Bob, I see a 13 gal for the model II on page 54. It is the same price $440.
_________________ Kitfox IV-1200
Indianapolis, IN |
Posted: Fri Mar 13, 2009 4:18 pm Post subject: WingTanks |
Well spotted Ryan! I didn't look further down when I saw the "Model
4,5,6,etc". Obviously the larger tank will require removing structure,
especially a strut, but John McB seemed to imply that his tanks are
structurally designed and tested to do that. Hopefully he will add to this
thread to support that, in which case it may be my best option.
Has anyone else installed John's 13 gal tank in a finished Model II yet?
Wrightsville Pa
Posted: Fri Mar 13, 2009 4:34 pm Post subject: WingTanks |
Bob,
We have both the 6 gallon and the 13 gallon… Give us a call and I can cover the details.
Fly Safe !!
John McBean
Ph 208.337.5111
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of Bob Brennan
Sent: Friday, March 13, 2009 12:43 PM
Subject: RE: WingTanks
Wrightsville Pa
Bob,
Fly Safe !!
John McBean
Ph 208.337.5111
Quote: | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | 0123456789 Quote: | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 0 Quote: | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 1 Quote: | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 2 Quote: | href="http://www.matronics.com/Navigator?Kitfox-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com | 3
