IO-360 converted to carbureted
tompkinsl(at)integra.net
PostPosted: Tue Mar 10, 2009 7:34 am    Post subject: IO-360 converted to carbureted Reply with quote
Does anyone have experience with a 200HP IO-360 that was converted to carburetor fuel system?
It sounds like the only change was to fuel delivery, i.e., the higher compression pistons, 200HP sump and intakes were used. FI was removed and carb installed.
Other than susceptability for carb ice, are there any other disadvantages to this swap? Seems like the engine should still make 200 HP if the installed carb is not a flow restriction.
Larry
flyinwithme99(at)yahoo.co
PostPosted: Tue Mar 10, 2009 11:57 am    Post subject: IO-360 converted to carbureted Reply with quote
I'm not sure there is a carb that was jetted and tested at Lycoming for the 200HP IO-360.
I am going to check on this and more details to follow...
From: "Larry L. Tompkins, P.E." <tompkinsl(at)integra.net>
To: lycomingengines-list(at)matronics.com
Sent: Tuesday, March 10, 2009 10:28:42 AM
Subject: IO-360 converted to carbureted
Larry
[quote]h= --> http://www.matronics.com/cont================
jbr79r(at)yahoo.com
PostPosted: Tue Mar 10, 2009 1:39 pm    Post subject: IO-360 converted to carbureted Reply with quote
Why would you want to go backwards from the advantages of FI to Carb?
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Tuesday, March 10, 2009 11:56:54 AM
Subject: Re: IO-360 converted to carbureted
Larry
h= --> http://www.matronics.com/cont================[url=http://forums.matronics.com/][/url]
wbecker(at)centurytel.net
PostPosted: Tue Mar 10, 2009 8:59 pm    Post subject: IO-360 converted to carbureted Reply with quote
Having had FI and carb engines, I would always rather have the FI system.
Bill B
