donald.kesterton(at)logic Guest
				 Posted: Mon Mar 16, 2009 5:47 am    Post subject: Door Support Mechanism |
				This is  my first posting for quite some time!!
  I understand that some time  ago Ted Gladstone designed a superior door hold mechanism which largely  eliminated the distorting force of the telescopic door opener when the door is  in the closed position.
  Can anyone suggest where I  could obtain drawing/construction details please.
  Is the modification one on  the UK "approved" mods list?
  I have tried the factory  solution,  which has the merit of being relatively simple, and although the  distorting force is much reduced,  I am still getting some door distortion  which I would like to eliminate.
  Many  thanks
  Donald  Kesterton
  G-PATS
  Please help Logica to respect the environment by not printing this email  /  Merci d'aider Logica à préserver l'environnement en évitant d'imprimer ce mail /  Bitte drucken Sie diese Nachricht nicht aus und helfen Sie so Logica dabei die Umwelt zu schuetzen  /  Por favor ajude a Logica a respeitar o ambiente não imprimindo este correio electrónico.        This e-mail and any attachment is for authorised use by the intended recipient(s) only. It may contain proprietary material, confidential information and/or be subject to legal privilege. It should not be copied, disclosed to, retained or used by, any other party. If you are not an intended recipient then please promptly delete this e-mail and any attachment and all copies and inform the sender. Thank you.      [quote][b]
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
