Dale Orth
Posted: Sat Mar 21, 2009 1:03 pm Post subject: Low Fuel Pressure readings |
I have a 912S with the I-K Technologies Engine Monitor. When the Engine gets to 5,000RPM the Monitor goes down to or below 2.2lbs. & displays low pressure. When this happens the Engine continues to run great even at 5,400RPM. I installed a pressure gauge in front of the sender & when the Monitor showed less than 2.2lbs. at 5,000RPM the inline gauge showed a strong 3lbs. The Monitor Manufacturer thinks it's the sender (Westach 387-16V2-C). I thought the sender might be bad so I installed another one with the same result. MY QUESTION IS; DOES ANYONE KNOW OF A FUEL PRESSURE SENDER THAT IS MORE ACCURATE THAN THE ONE I HAVE????
Thanks, Dale
_________________ Dale
KitFox 7
Las Vegas, Nv
daleorth@embarqmail.com |
