Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Fri Mar 20, 2009 6:59 pm Post subject: Section 11 |
Just wondering if I should attach the horizontal and vertical or wait until the plane is closer to being finished. Also should I wait for the fiberglass tips too. I just finished my tailcone and my wing is already here. I would think Van's would put it off until the end if it was more convenient.
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
pascal(at)rv10builder.net Guest
Posted: Fri Mar 20, 2009 8:53 pm Post subject: Section 11 |
numerous ways to look at this.
What I did was "built" the vertical and horizontal but did not match drill
the fiberglass parts. Now that I am at the finishing kit about to put the
gear on, I went back and finished off the fiberglass pieces with the added
experience of the canopy and doors.
With that said here are the ways to look at this
1) if you have time waiting for the next kit and you're ready to do it,
finish off all but riveting on the fiberglass.
2) If you have the next kit and are ready to keep going, come back to it
later , if it's in a garage do it before raising the fusellage up on the
gear
3) You can do it at the hangar when all is done and you are finishing up
everything
As far as convenient, you need to decide how accessible everything is now-
if you can readily work on the parts on a bench that would work, having it
on the fusellage worked better for me, height wise, having it on the gear
would have had it higher and been more difficult to reach as I did while it
was lower, plus at the end of the build I didn't see wanting to have to get
this done, one main reason is the fiberglass requires some work to make it
fit the way I want it and waiting for flox, plys, etc to cure is not
something I wanted to do at a airport that is 1 hour away from me.
I have seen and talked to numerous builders each did section 11 and 12 at
different times, it really doesn't matter, do it when it's best for you.
Pascal
#40720
Sent: Friday, March 20, 2009 6:59 PM
Subject: Section 11
convenient.
A&P, ATP
typed CE-525(s), CE-500
RV-10 emp started!!!!
N801VR reserved
http://forums.matronics.com/viewtopic.php?p 35463#235463
Strasnuts
Posted: Sat Mar 21, 2009 10:31 am Post subject: Section 11 |
Thanks Pascal, That is the info I needed.
780 Hours
