		peteohms
				 Posted: Thu Mar 26, 2009 6:46 am    Post subject: 912 charing problem. |
				Can someone walk me  through diagnosing a charging problem?  Last week my volt meter was showing  a charge between 25% and 50%.  A couple days ago I went out to fly around  the pattern to see if I could figure out the problem. On the ground it was  showing 25% charge but in the air it was down in the red with no charge.   What steps do I need to take to determine the cause?
  Pete
  III/912/Grove
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
		kerrjohna(at)comcast.net Guest
				 Posted: Thu Mar 26, 2009 7:19 am    Post subject: 912 charing problem. |
				Not an unusual problem usually requiring the replacement of the voltage regulator.  When mine failed it was intermittent, cutting short a trip in the back country of Idaho.  I got outa Dodge without delay and had a wingman along side until reaching civilization, relatively, over Hailey.  A 30-second conversation with Lockwood got a quick response and a new regulator, not cheap, on the way.  No problem since.
 John Kerr
 Classic IV, 912ul, 875 hours
		Dick Maddux
				 Posted: Fri Mar 27, 2009 5:50 am    Post subject: 912 charing problem. |
				Pete, This probably won't work but it is cheap to try. I was having an overvoltage problem with mine so I removed the voltage regulator and cleaned all the connections. I did have a small amount of corrosion. That did it and it is working fine now.
   Also, I think some of the guys are using voltage regulators other than the original Ducatti units. I think they are cheaper and if they work OK I would be interested myself .
                                                   Dick Maddux
                                                   Fox4
                                                   912
                                                   Pensacola,Fl
  Feeling the pinch at the grocery store?  Make dinner for $10 or less.
		peteohms
				 Posted: Fri Mar 27, 2009 1:12 pm    Post subject: 912 charing problem. |
				Can someone please elaborate on "...some of the guys are using  voltage regulators other than the original Ducatti units."
  Pete
  [quote]   ---
Leander, TX
		peteohms
				 Posted: Fri Mar 27, 2009 4:49 pm    Post subject: 912 charing problem. |
				My research found some writings by Peter Sherman regarding  using Honda Motorcycle rectifier/regulators from the Honda CB250/400 or CX500 in  his Ducati mc.
  Look here:  http://www.geocities.com/750paso/paso/voltageregulator.html
  [quote]   ---
Leander, TX
		Fox5flyer Guest
				 Posted: Sat Mar 28, 2009 3:13 am    Post subject: 912 charing problem. |
				That's a very good option, if you have a source for them.  There are  other options also, including Aircraft Spruce, but they're pricey.  Take a  look at the link below.  It will help you understand how the system works  and my lead to making a good choice.  The bottom line is that the stock  Ducatti regulators were very troublesome and tended to cause many problems,  especially over voltage.   One thing that is important with them is  that they required a constant load to convert AC to DC.  A common  replacement was the Key West regulator, but you'll have to search around to find  who sells it.  Aircraft Spruce used to sell it, but I don't see it  now.  Might have changed the name.  http://www.800-airwolf.com/pdffiles/ARTICLES/Part%2049%20-%204%20page.pdf
  Good luck.
  Deke Morisse
 Mikado Michigan
 S5/Subaru/CAP 402+ TT
 "The aim of an  argument or discussion should not be victory, but progress."
 - Joseph  Joubert
  [quote]   ---
