Windshield question.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List
raymondj(at)frontiernet.n
PostPosted: Sun Mar 22, 2009 2:32 am    Post subject: Windshield question. Reply with quote
Greetings,
The airplane I'm designing will probably have a windshield shape similar to
the Tailwind. Can someone tell me what the dimensions of the material used
for the windshield, including thickness. I see some people are using lexan,
which will be my choice. Anyone using other materials and can offer pros
and cons of the various choices? My gas fill will not be near the
windshield so exposure to gas is not a big issue.
Thanks very much in advance.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
- The Matronics Tailwind-List Email Forum -
http://www.matronics.com/Navigator?Tailwind-List
eschlanser(at)yahoo.com
PostPosted: Thu Apr 02, 2009 6:40 pm    Post subject: Windshield question. Reply with quote
Raymond,
The plans call for 1/8" plexiglas. Many builders now are using 3/16". Plexi and lexan each have good and bad points. I am building with 3/16" tinted and coated polycarbonate(lexan). The coating improves the fuel/chemical resistance. Plexiglas is cheaper and will also do the job. Eric
PostPosted: Thu Apr 02, 2009 8:42 pm    Post subject: Windshield question. Reply with quote
Eric,
Thanks for the reply. Can you tell me what the dimensions of the
windshield are and is the brace I see running down the middle helping to
strengthen the windshield?
Raymond Julian
Kettle River, MN
"Hope for the best,
owenld(at)earthlink.net
PostPosted: Thu Apr 02, 2009 8:59 pm    Post subject: Windshield question. Reply with quote
I welded little tubes with small crutch tips midway up the diagonal tubes.
Lou N6PJ
[quote] [Original Message]
To: <tailwind-list(at)matronics.com>
Date: 4/3/2009 12:45:17 AM
Subject: Re: Windshield question.
Eric,
Raymond Julian
Kettle River, MN
"Hope for the best,
planecrazzzy
PostPosted: Fri Apr 03, 2009 4:11 am    Post subject: Windshield question. Reply with quote
In a bird strike.... Plexiglas would shatter like glass....
Not a good feature for a windshield...
  Gotta Fly...
[quote] --> Tailwind-List message posted by: eschlanser(at)yahoo.com (eschlanser(at)yahoo.com)
Raymond,
Mytyweav(at)earthlink.net
PostPosted: Fri Apr 03, 2009 5:37 am    Post subject: Windshield question. Reply with quote
Funny how Plex has worked for many many airplanes for many many years........... It's still a viable way to go. However, Eric's using perhaps the "best" size and material for the application. It also costs more.......
Weav
Mike & "Jaz" wrote: [quote]
Gotta Fly...
Raymond,
PostPosted: Fri Apr 03, 2009 8:49 am    Post subject: Windshield question. Reply with quote
The center brace is absolutely needed to strengthen the 47 inch long windscreen. The Cougar has about half that length and uses no center brace. The width is about 39 inches. I don't have the plans in front of me. Some builders also add clear plastic blocks or other supports above the diagonal frame tubes directly behind the windscreen in order to add bracing strength.
Paul Baron lost his 1/8" windscreen in a high speed dive. He survived, but increased the thickness from 1/8" to at least 3/16" when he made the replacement. He also had to change his underwear.
--- On Fri, 4/3/09, raymondj <raymondj(at)frontiernet.net> wrote:
[quote]From: raymondj <raymondj(at)frontiernet.net>
To: tailwind-list(at)matronics.com
Date: Friday, April 3, 2009, 12:38 AM
[quote]--> Tailwind-List message posted by: "raymondj" <raymondj(at)frontiernet.net> Eric, Thanks for the reply. Can you tell me what the dimensions of the windshield are and is the brace I see running down the middle helping to strengthen the windshield? Thanks, Raymond Julian Kettle River, MN "Hope for the best, but prepare for the worst." do not archive ---
PostPosted: Fri Apr 03, 2009 9:00 am    Post subject: Windshield question. Reply with quote
Eric,
Thanks for the info. I will be putting in 3/16 lexan with braces unless
they find something tougher before I get around to it.
Thanks again,
Raymond Julian
Kettle River, MN
"Hope for the best,
Pat Reilly
PostPosted: Thu Aug 06, 2009 3:06 pm    Post subject: Re: Windshield question. Reply with quote
This is 4 months late, I just found the forum. A fellow out of MI has heat formed a windshield out of plexi on his Cougar. It is one piece with a 90 degree bend to form each the 2 sides. It eliminates the metal corners on the windshield. Sweet looking. I'm not sure but it looked like 3/16". I will build one for my rebuild project this winter. I don't think you can heat form lexan very easily, so I'll have go with plexi.
Pat Reilly
W10 0290 Rebuild
Rockford, IL
planecrazzzy
PostPosted: Thu Aug 06, 2009 3:23 pm    Post subject: Windshield question. Reply with quote
Plexi Glass shatters like glass.... Birds will go right thru it... and cut you to pieces...
There's a reason to stick with Lexan.... We don't like it because it scratches so easy...
It's because it can take the impact....
Not to mention how the plane it going to fly now that it's a big SCOOP for all the air...
    Gotta Fly...
      Mike & "Jaz" , sticking with Lexan
Buttercup - STOL - Aircraft
http://groups.yahoo.com/group/Buttercup-STOL/
Firestar I&II - STOL - Aircraft
http://groups.yahoo.com/group/Kolb_Firestar/
My Web Site:
http://www.geocities.com/planecrazzzy/Planecrazzzy.html
Sometimes you just have to take the leap and build your wings on the way down...
Date: Thursday, August 6, 2009, 6:06 PM
--> Tailwind-List message posted by: "Pat Reilly" <patreilly43(at)gmail.com (patreilly43(at)gmail.com)>
Pat Reilly
W10 0290 Rebuild
Rockford, IL
http://forums.matronics.com/viewtopic.php?p=256429#25642= - The Tailwind-List Email Forum -
.com/Navigator?Tailwind-List" target=_blank>http://www.matronics.com/Navi= - MATRONICS cs.com/" ; -Matt Dralle, List Admin==========
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Tailwind-List All times are GMT - 8 Hours
