Kelly McMullen
Posted: Fri Mar 27, 2009 4:17 am Post subject: Fuel & Oil line torque values - help ??? |
Aviation 37 degree flare fittings should need no sealant.
On Thu, Mar 26, 2009 at 10:05 PM, AirMike <Mikeabel(at)pacbell.net> wrote:
I was told to use a high temp permatex thread sealer on the fuel and oil lines (VA190, VA135 etc) to the oil cooler and fuel pressure monitor hoses.
What are the torque values on these aeroquip hoses (fuel & oil)????
Also - Alert note......................I got my FWF kit in the summer of '07. My VA190 hose was of the wrong diameter. I would suggest that people who got their FWF kits about then check the hose to make sure that it was right. I sent back the defective hose and Gus very kindly sent me the proper one. The VA190 takes a 7/8 wrench to turn. If you have a smaller exterior nut - it is the wrong size.
OSH '08 or Bust (busted) be there in "09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 36318#236318
A&P/IA, EAA Tech Counselor
KCHD |
pascal(at)rv10builder.net Guest
Posted: Fri Mar 27, 2009 8:49 am Post subject: Fuel & Oil line torque values - help ??? |
http://www.vansaircraft.com/pdf/Torque_Spec_Aluminum_Fittings.pdf
Pascal
Sent: Thursday, March 26, 2009 7:05 PM
Subject: Fuel & Oil line torque values - help ???
hoses.
wcurtis(at)nerv10.com Guest
AirMike,
I've had the below page up since before 2007 and while I love to support
Vans, builder should EXCLUDE all the hoses from the Vans FWF kit and
instead order the all Teflon hose kit with integral fire-sleeve from
aircrafthose.com. You get much better hoses for less than or about the
same price as the non fire-sleeve hoses in the Vans kit.
http://nerv10.com/wcurtis/20Engine/hose.html
William
bkbrown(at)minetfiber.com Guest
Posted: Fri Mar 27, 2009 9:52 am Post subject: Fuel & Oil line torque values - help ??? |
That is really helpful, Mr. Curtis! Thanks!
What I'm still searching for...just so I can get them in advance are Teflon
lined hoses to run from the tunnel bulkhead fitting outboard to the wing
tanks...is there ANYBODY out there that can give me a dimension? This is
one of those lengths that (I'm pretty sure) can't vary much...but I had
planned on running a hose there instead of the 3/8" alumninum line. Help
anyone?
Bob Brown
Posted: Fri Mar 27, 2009 10:03 am Post subject: Fuel & Oil line torque values - help ??? |
No disagreement in having the firesleeve hoses, however, just to clarify,
the price gap is very significant when all added up- close to $200 on $569
of Aircrafthose.com hoses.
That difference in based on the webstore and not the kit credits one would
receive, so there may be an even larger gap.
Van's runs the hoses they have in the kit in their own aircraft. They have
shown no issues thus far, with that said if someone thinks manifold and oil
cooler hoses need the extra firesleeve protection that is money well spent
going with the aircrafthose.com setup.
Here is the breakdown on my numbers:
PHT
Van's price
VA119/ 111417-4S0214 30.76 17
VA-102/ 124J001-4CR0154 68.36 15.50
VA-133/ 124J001-4CR0272 79.12 18.25
VA-138/ 124J001-6CR0140 78.14 63.30
VA-189/ 124J002-6CR0254 104.96 100.50
VA-135/ 124J001-8CR0164 95.68 64.40
VA-190/ 124J001-8CR0270 111.92 97.65
total
$568.94 $376.60
Delivery is 2 to 3 days
Van's hoses page:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1238176072-388-450&browse=engines&product=hoses
Pascal
Sent: Friday, March 27, 2009 8:42 AM
Subject: re: Fuel & Oil line torque values - help ???
AirMike,
William
rene(at)felker.com Guest
Posted: Fri Mar 27, 2009 10:14 am Post subject: Fuel & Oil line torque values - help ??? |
I made my own hoses for the fuel lines from the tank to the valve. You can
have some variance. I put one end on. Routed the line, marked, pulled the
line and then put the other end on. Between the turn in the tunnel and the
s turn in the wing root, these can be some slop.
I did not find making the lines all that hard.
Another alternative, is just go down to your local hose shop and have them
make them up. Measure long, have them put one end on. Route in airplane,
mark and then have them put the other end on.
I bought my hose, connectors and tool from Vans.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
LarryRosen
Posted: Fri Mar 27, 2009 10:20 am Post subject: Fuel & Oil line torque values - help ??? |
For flexible stainless steel wrapped teflon fuel lines talk to Brett at Bonaco
Bonaco Inc. Hose and Fittings / Brake Lines 1846 W. 11th. St.
Unit I
Upland, CA 91786 Phone: 909 - 985 - 3429
Fax: 909 - 946 - 5625
Email: bonacoinc(at)bonacoinc.com (bonacoinc(at)bonacoinc.com)
Shop Hours - Weekdays 9am - 5:30pm PST
1-866-239-6442
www.bonacoinc.com
Larry
Bob and Karen Brown wrote: [quote] [quote]--> RV10-List message posted by: "Bob and Karen Brown" <bkbrown(at)minetfiber.com> (bkbrown(at)minetfiber.com) That is really helpful, Mr. Curtis! Thanks! What I'm still searching for...just so I can get them in advance are Teflon lined hoses to run from the tunnel bulkhead fitting outboard to the wing tanks...is there ANYBODY out there that can give me a dimension? This is one of those lengths that (I'm pretty sure) can't vary much...but I had planned on running a hose there instead of the 3/8" alumninum line. Help anyone? Bob Brown Do not archive --
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jcumins(at)jcis.net Guest
Posted: Fri Mar 27, 2009 12:38 pm Post subject: Fuel & Oil line torque values - help ??? |
Ok here is my 2 cents worth. All hoses fwd of the firewall that transport
flammable liquids must have fire sleeve. I have seen when a fire starts with
out fire sleeve and it is a lot worse then hoses with fire sleeve. And the
additional cost for Teflon hoses with fire sleeve is the best way to go.
There longer live and do not require a time in service change like the
rubber hoses do.
I have seen several rubber hoses break due to people not changing them and
it usually means a off air port landing not a good thing.
My butt and the airplane is worth the difference in Teflon - vs- rubber
hoses and always include fire sleeve on all fluid hoses.
We all will have over $100k invested in our projects why scrimp on something
that has the potential of causing loss of aircraft or loss of life.
That's just plane stupid.
OK That's my 2 cents worth
John Cumins
A&P
Horz stab assy.
N864FN reverved
Posted: Fri Mar 27, 2009 12:52 pm Post subject: Fuel & Oil line torque values - help ??? |
Pascal,
I won't dispute your math but in Aug '07 I received a $584.60 credit from
Van's for excluding the hoses in the Firewall Forward kit and then paid
$450 to aircrafthost.com for the better hoses in their RV-10 kit. This
amount excluded the VA-189 hose since this was included with my
TMX-IO-540.
These were the prices then, I guess Van's has reduced the prices on the FWF
kit hoses considerably. IMHO, the kit from aircrafthose.com is still much
better and arguably worth the additional $200.
IE VMP INSTALL KIT FITTINGS/HOSES
(VA-119, AN924-4D, ED SPACER, PT 094X156) $55.00
VA-102 FUEL PRES. HOSE 15.5 $51.00
VA-133 OIL PRESS. HOSE 27.25 $61.00
VA-135 OIL COOLER HOSE 16.5 $83.00
VA-190 OIL COOLER HOSE 27" $130.00
VA-138 FUEL SUPPLY HOSE 14.0 $78.50
VA-189 FUEL LINE IO-540 25.5 $126.10
Ya pays your money and ya takes your chances.
William
Kelly McMullen
Posted: Fri Mar 27, 2009 1:02 pm Post subject: Fuel & Oil line torque values - help ??? |
If you have worked with fuel and oil hoses of both varieties, there is
no comparison. The integral firesleeve are worth it for any hose that
should be firesleeved. One could debate with regard to MP hose. I
don't think there is any debate for fuel or oil hoses. I have the PHT
Parker 124J hoses in my Mooney right now.
On Fri, Mar 27, 2009 at 2:02 PM, pascal <pascal(at)rv10builder.net> wrote:
KCHD |
Posted: Fri Mar 27, 2009 1:11 pm Post subject: Fuel & Oil line torque values - help ??? |
.. Just making sure no one was shocked at the difference in prices is all.
Pascal
Sent: Friday, March 27, 2009 12:47 PM
Subject: Re: Fuel & Oil line torque values - help ???
Pascal,
TMX-IO-540.
FWF
William
Kelly McMullen
Posted: Fri Mar 27, 2009 4:08 pm Post subject: Fuel & Oil line torque values - help ??? |
Do we know who makes Van's hose kit and how high quality the assembly
is? When I was buying new hoses for my Mooney to complete install of
fresh engine, the cost difference for all 7 hoses was a net $110 to
get 124J over 124 with firesleeve from PHT with full TSO tagging.
... Just making sure no one was shocked at the difference in prices is all.
Pascal
> Pascal,
> TMX-IO-540.
> FWF
> William
KCHD |
Posted: Fri Mar 27, 2009 6:44 pm Post subject: Fuel & Oil line torque values - help ??? |
Brett does not have the length for this hose assembly, we have discussed this…and that is what he and I are asking here.
Bob
Do not archive.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Larry Rosen
Sent: Friday, March 27, 2009 11:19 AM
1846 W. 11th. St.
[b]Unit I
Upland, CA 91786[/b]
[b]Fax: 909 - 946 - 5625
Email: bonacoinc(at)bonacoinc.com (bonacoinc(at)bonacoinc.com) [/b]
1-866-239-6442
www.bonacoinc.com
Larry
Bob and Karen Brown wrote: | Quote: | | --> RV10-List message posted by: "Bob and Karen Brown" <bkbrown(at)minetfiber.com> That is really helpful, Mr. Curtis! Thanks! What I'm still searching for...just so I can get them in advance are Teflonlined hoses to run from the tunnel bulkhead fitting outboard to the wingtanks...is there ANYBODY out there that can give me a dimension? This isone of those lengths that (I'm pretty sure) can't vary much...but I hadplanned on running a hose there instead of the 3/8" alumninum line. Helpanyone? | 01234[quote]--
