MS25041 PTT Lamp
hammer408(at)comcast.net
PostPosted: Sun Mar 29, 2009 7:54 am    Post subject: MS25041 PTT Lamp Reply with quote
Bob:
I'm installing a couple of these Lamps in my 9A - 1 for Oil Pressure and 1
for Low Voltage Protection. Now, I've researched these lamps and proper
circuit runs for a couple of months both on Aeroelectric and other homebuilt
sites. There is "some" info out there, some of which is confusing and some
that make sense.
What I've done is attach a drawing ( a jpeg & word doc)of what I determine
to be the circuit layout for Oil Pressure and Low Voltage. Can you please
take a look at these and let me know if they're correct and or make
corrections where needed.
Appreciate your input.
Henry
 Filesize:  184.54 KB
 Viewed:  5343 Time(s)
PTT_Switch.doc
 Filename:  PTT_Switch.doc
 Filesize:  956.5 KB
 Downloaded:  627 Time(s)
PostPosted: Sun Mar 29, 2009 11:06 am    Post subject: MS25041 PTT Lamp Reply with quote
At 02:58 PM 3/29/2009, you wrote:
Bob:
that make sense.
Henry
What you have illustrated will work fine.
( -Thomas Paine 1776- )
PostPosted: Sun Mar 29, 2009 11:34 am    Post subject: MS25041 PTT Lamp Reply with quote
Thanks Bob
Appreciate it...
