coop85(at)bellsouth.net Guest
Posted: Sun Apr 02, 2006 8:54 am Post subject: Prop Governor arm |
I have the baffling just about finished and need to modify the MT prop
governor actuation arm location so the cable will work properly (currently
the arm rotates from vertically straight down to aft, it should start with
the arm pointing forward and be pulled down from what I can tell). I'm not
sure what needs to be rotated 90 degrees though. It appears the base needs
to stay in the same location and the outside ring moves in 60 degree
increments, not 90 and I don't know if there is any kind of calibration
associated with it so am hesitant to undo all the safety wire???????
Thanks for any help,
Marcus
40286
flysrv10(at)gmail.com Guest
Posted: Sun Apr 02, 2006 9:17 am Post subject: Prop Governor arm |
You need to undo the safety wire from the screws and rotate the ring
around the body so that the arm is pointing to about 10-11 oclock
postion viewed looking to the right of the plane. You do not need to
remove the ring, just rotate it. This position is for the high RPM.
push the prop cable to the firewall and adjust the connection to the
governer accordingly. I have not adjusted my final RPM but I believe
that the final adjusments, if needed. are done with an adjument screw
at the properller nose.
Rob
Marcus
40286
LessDragProd(at)aol.com Guest
Posted: Sun Apr 02, 2006 9:19 am Post subject: Prop Governor arm |
For a single lever MT Governor:
Remove the safety wire from the six screws around the top ring on the governor.
Loosen the six screws. They do not need to be removed.
Rotate the lever arm assembly to the desired position.
Tighten the six screws. (They are small, so don't overtighten them.)
Install safety wire.
For the earlier MT Governor with two levers:
Bend back the ears on the safety tab of the single screw on the outer lever.
Remove the single screw from the outer lever, and slide the lever off of the spline shaft.
Slide the lever back onto the spline shaft in the location you want the lever.
Install the single screw with safety tab into lever.
Bend the tabs against the screw head.
This is in the governor manual provided, but I had to be forced to read it.
(Stinking instructions. Who needs stinking instructions. )
Jim Ayers
Less Drag Products, Inc.
An FAA certified MT Propeller Repair Station
www.lessdrag.com
jim(at)lessdrag.com (jim(at)lessdrag.com)
In a message dated 04/02/2006 9:55:59 AM Pacific Daylight Time, coop85(at)bellsouth.net writes:
Quote: | --> RV10-List message posted by: "Marcus Cooper" <coop85(at)bellsouth.net>
Marcus
40286
Tim(at)MyRV10.com Guest
Posted: Sun Apr 02, 2006 12:21 pm Post subject: Prop Governor arm |
You're right about the rotation. I think I have some good photos
of my install on my site. You loosen the 6 screws if I remember
right and then it rotates easily. I re-saftied mine. I don't think
you need to loosen them much. The orientation is so the lever faces
forward and goes up and down toward a hole in the baffle ramp below
it. Again though, I think you'll find some good photos on my site
that show it. I don't think you also have to remove the 6 screws...
I think it's just loosen and rotate. I'm not 100% sure though,
as I'm getting fuzzy, but I think that's what Anh told me back
when I had the same question.
Marcus
40286
