dave
Posted: Wed Apr 01, 2009 1:22 pm Post subject: Full Lotus FLoats, Safety warning video |
If you use full lotus Floats you had better watch this
http://rotaxaircraft.com/forum/viewtopic.php?f=11&t=100
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
akflyer
Posted: Wed Apr 01, 2009 3:43 pm Post subject: Re: Full Lotus FLoats, Safety warning video |
LOL.. this is old news Dave. It is called condensation.. You want to get rid of the issue, fill them with an inert gas. Water does not "leak" into the bladders, water from the compressed air is introduced to them. Has he used a water trap on his air pump every time he fills them.. of course not. Neither do I. I know a guy that dumped about 15 gallons out of his after he did not bother to check them for 5 years on a set of 2250's. I check and drain mine every season.
Another issue he may have in the future. Does he have the old zipper style hull caps? if so, did he lace them up with the cord supplied by full lotus years ago? I think it was about 8 or 10 years ago) when they had the issue with them. We came in for a landing with them on a PA 12 and the right hull cap separated from the hull starting at the front... that is a full on attention getter right there. Thought we were gonna go over. Turns out the sewing was not real good and there were areas that the stitching ran off the zipper and hull cap, then would weave back on to it. The fix full lotus came up with at the time was to lace the caps on so the zipper was the primary fastening and the lacing was backup if the zipper gave way. They have since re-designed and now bolt the hull caps on.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
