paulsteger(at)hotmail.com Guest
Posted: Wed Apr 01, 2009 6:48 am Post subject: Nsi Suburu ignition module failure |
My worst fear has come true. I lost one of the ignition modules from out-of-business NSI and now have only single ignition. Does anyone know if any of these modules are available from anyone? Were they a custom designed part from NSI C or an off-the shelf item? It appears that they took some electronic components and then totally encased them in epoxy C so repair or even seeing what's inside there is impossible. Any help would be appreciated. Paul
Rediscover HotmailŪ: Now available on your iPhone or BlackBerry Check it out. [quote][b]
Fox5flyer Guest
Posted: Wed Apr 01, 2009 7:33 am Post subject: Nsi Suburu ignition module failure |
Paul, they're made by Electromotive and I think they're called HPV-1 modules and are used on race cars. More than likely your module is OK, just one of the coils has probably gone bad. They're just standard GM coils available anywhere.
Deke
Paul A. Franz, P.E.
Posted: Wed Apr 01, 2009 10:38 am Post subject: Nsi Suburu ignition module failure |
On Wed, April 1, 2009 6:47 am, Paul Steger wrote:
| Quote: | It appears that they took some electronic components and then totally encased
them in epoxy, so repair or even seeing what's inside there is impossible. Any help
I don't believe that stuff is epoxy. It is called "potting compound". It is removable
by either melting with heat or a solvent. Google is your friend.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
If a nation expects to be ignorant and free,
.. it expects what never was and never will be.
-- Thomas Jefferson
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Wed Apr 01, 2009 1:58 pm Post subject: Re: Nsi Suburu ignition module failure |
From pouring hundreds of gallons of different potting compounds for my work, I can attest that more likely any heat or solvent that would soften/remove this compound will destroy any electronics contained in it. That is it's primary function, protection from contaminates and vibration.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
Lynn Matteson
Posted: Wed Apr 01, 2009 2:07 pm Post subject: Nsi Suburu ignition module failure |
...and maybe prying eyes?
Lynn Matteson
Jabiru 2200, #2062, 622.1 hrs
Sensenich 62x46
Status: flying
On Apr 1, 2009, at 5:58 PM, Av8r3400 wrote:
> vibration.
Av8r3400
Currently between planes, but not for long...
http://forums.matronics.com/viewtopic.php?p 37294#237294
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
