Aircraft Tool Supply Oil Filter Prices
n1cxo320(at)salidaco.com
PostPosted: Thu Mar 30, 2006 2:19 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
I received a "spring flyer" for some of Aircraft Tool Supply's offerings.
One item that caught my eye was Champion Oil Filters...pretty standard units ... Aircraft Spruce lits them for $16.25 in my 2005 catalog, but ATS is offering them for the
"Retail Price" of $33.90, but offering 20% reduction, so you can get all you need for only $27.46 each.
Wow! what a deal !!
klwerner(at)comcast.net
PostPosted: Thu Mar 30, 2006 2:29 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
A filter is there to clean, and these clean your pocket !!! Couldn't resist that one. do not archive
dan(at)rvproject.com
PostPosted: Thu Mar 30, 2006 3:03 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
http://www.rvproject.com/pricewatch.html (send me updates if you got 'em)
FWIW, I switched from Champion CH48110-1 to Kelly Aerospace ES48110 oil
filters and have been using them exclusively for a few hundred hours now --
and I plan to keep using them. $12.65/ea from Spruce. Saving a few bucks.
I did a photographic comparison of the Champion vs. Kelly oil filter
element. There are physical differences, particularly fewer pleats on the
Kelly. But nothing (imho) that's significant. I'm a cheapskate wherever I
don't feel there is a safety risk.
Photos toward the bottom of this page:
http://www.rvproject.com/20050613.html
Spruce used to sell another even cheaper oil filter, maybe Challenger? I
forget the name. It was like another 2 bucks cheaper than the Kelly. I
figured...baby steps.
)_( Dan
RV-7 N714D (843 hours)
chaztuna(at)adelphia.net
PostPosted: Thu Mar 30, 2006 4:27 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Dan,
You might want to reconsider that move. In 2004, Aviation Consumer did a comparison of the Champion and Kelly oil filters (Volume XXXIV Number 9). The Kelly has 20% less filtering area. Bottom line was they recommend spending the extra money for the Champion. I can email you a scan of the article if you like.
Charlie Kuss
)_( Dan
PostPosted: Thu Mar 30, 2006 4:33 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Charlie,
That's in line with what I photographed. Less filtering area. I don't
personally think it's all that critical for a plane that is flown regularly,
oil changed every 25 tach, oil+filter changed every 50 tach. I'm not trying
to convince anybody of anything, like to use Kelly over Champion, just
saying that I use Kelly to save a coupla bucks and don't believe I'm taking
a measurable risk.
)_( Dan
PostPosted: Thu Mar 30, 2006 6:34 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Dan
It's your engine and airplane. I could understand saving on the
Kelly filter, if you were changing the oil and filter every 25 hours.
Changing the filter that often, I doubt that a 20% reduction in
filter area would make any difference. The problem with clogging a
filter, is that the bypass valve in the filter then opens. Once that
happens, the filter is effectively gone. The oil moves through the
system unfiltered.
I see the same thing with auto manufacturers who specify full
synthetic motor oil and 10,000 mile oil changes. The oil can go that
distance. Often, however, the filter will clog much sooner. The
benefit of using a superior oil is lost, if it's not being filtered
the last 3-5 thousand miles of each oil change interval. I recommend
that folks who use synthetic oil/long drain periods, change out the
oil filter mid way through the extended drain period.
50 hours means 50 X 160 mph = 8000 miles. That's a long way to go
without changing the oil filter.
Charlie
Charlie,
a measurable risk.
)_( Dan
PostPosted: Thu Mar 30, 2006 6:55 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
I don't necessarily disagree with you. But lemme put it this way -- if it
gets so bad that the filter bypass is in use, 20% more filter area ain't
gonna do diddly...I would have MUCH BIGGER problems than just that!
I appreciate your concern, though.
)_( Dan
rocketbob(at)gmail.com
PostPosted: Thu Mar 30, 2006 7:19 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Guys,
I use Napa Gold 1068 filters, or Wix 51068. $5.96 at the local Napa. No
safety nut but who cares, if you torque it down it isn't going to come off
in flight. A few RV's in my area fly with these filters with no problems.
I can't remember exactly what the burst pressure on these filters is but its
somewhere in the 400 psi neighborhood. My oil analyses have come back good
with less than average metal content for an O-360. A big advantage of this
filter is that it has an anti-drainback valve, which keeps oil in the filter
when the engine is shut down so that the top end quickly gets oil during
start-up. When I cut these filters for inspection, I have measured 1/2 qt.
of oil out of them even after standing it up on its end. Why pay $18 for a
filter design that is 40 years old.
Bob Japundza
RV-6 flying F1 under const.
wgill10(at)comcast.net
PostPosted: Thu Mar 30, 2006 8:42 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Skygeek price:
<http://www.skygeek.com/ch48110-1.html> ChampionR CH48110-1 Oil Filter
$17.10
George McNutt
PostPosted: Fri Mar 31, 2006 10:47 am    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Hi Charlie
Educate me, - is filter clogging on a good engine something to actully
consider? I change filters at 50 hours and cut them open for inspection
and have observed that a good engine could probably go 10 or 20 times
longer before there would be any significant amount of contaminate
material to restrict flow through the oil filter pleats (high time 0-470
would block maybe 3% of pleats with carbon). I am also assuming that
when filter pleats are slowly clogging with microscopic size material
the filtering capability would actually increase up to the point where
the bypass valve opens. If the bypass is spring loaded it will crack
open as a function of pressure and only some oil will bypass while much
of it would still pass through the filter pleats up to the point where
they become fully clogged. What am I missing here??
George in Langley BC
system unfiltered.
Charlie
PostPosted: Fri Mar 31, 2006 7:53 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
George,
If you are finding very little material in your filter, than by all
means use it up to 50 hours. One thing to bear in mind though. When
you loosen the filter, almost all the oil and most of the foreign
debris drain out of the filter, so your inspection may or may not be
accurate, regarding how much material was actually in the filter. I
suspect that aircraft oil filters do not have the ability to filter
down to 25 microns like automotive filters do. With the larger
clearances on our engines, super fine filtration is not as critical.
If the filter doesn't have to stop these smaller particles, it will
obviously take longer to clog.
Clogging is a relative term. The back pressure of the oil
(especially if you use straight weight oil and the oil is cold, such
as on initial start up) will open the bypass valve at much less than
fully clogged. At what percentage point this would occur, I don't
know. Is Doug Rosendahl still on this list? Doug is a petroleum
engineer and could answer these questions better.
If the bypass valve opens, a great deal of the oil will pass
through unfiltered. Path of least resistance, ya know.
Charlie
Hi Charlie
>system unfiltered.
>Charlie
Charles Heathco
PostPosted: Sat Apr 01, 2006 6:03 pm    Post subject: Aircraft Tool Supply Oil Filter Prices Reply with quote
Well for me I change oil and filter every 25 hrs, very cheep insurance. I have a 2200 hr 0-320 and its tighter than dicks hat band. Charlie Heathco
