darinh
Posted: Sun Apr 05, 2009 9:15 am Post subject: Fluctuating Oil Pressure Indication? |
Last time I went flying, about 10 minutes into the flight, my oil pressure indication went to 12 psi then to 45 psi then back to 15 psi and it continued like this until I got back on the ground about 10 minutes later. When I shut down, my EIS still indicated oil pressure without the engine running. I had just purged the oil system per the Rotax SB so there was not any air in the system. I have purged it again since and I am still getting the wildly fluctuating pressure indication. The engine only has 38 hours on it which seems a bit early for failure.
The pressure eventually went to 0 but shouldn't it be 0 anytime the engine is not running even if the engine is warm? Is my pressure sender bad? I know they have a tendency to go bad on the Rotax 912 series due to engine vibration. But is this a typical symptom of a bad sender or do they just quit indicating completely?
Lastly, does one have to spend the outrageous amount of $250 for a new "Rotax" VDO sender or will others work? If so, where can I get one of the less expensive ones? I am sick of not being able to fly on days like today and need to get this figured out. So any help or experience you may have will be appreciated.
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
akflyer
Posted: Sun Apr 05, 2009 10:47 am Post subject: Re: Fluctuating Oil Pressure Indication? |
couldn't you jump a tee in the run and put a good ole mechanical oil pressure gage in there too for back up? That would for sure tell you what the scoop is for about 25 bucks at any auto parts store. You would not have to punch a hole in the dash for it, just set it on the seat or use a clamp to hold it at the edge of the dash just to give you a warm fuzzy that the high $ sender is bad.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
darinh
Posted: Sun Apr 05, 2009 11:27 am Post subject: Re: Fluctuating Oil Pressure Indication? |
| akflyer wrote: | | couldn't you jump a tee in the run and put a good ole mechanical oil pressure gage in there too for back up? |
Yes, I thought about this and will probably end up doing it or at least trying it to verify if the sender is bad. I did just read that the VDO senders show signs of failure by rapidly fluctuating pressure indications. Based on this, I think it is safe to assume that the sensor is going bad.
Series 7
914 Turbo
Kaysville, Utah |
akflyer
Posted: Sun Apr 05, 2009 11:55 am Post subject: Re: Fluctuating Oil Pressure Indication? |
It may be a good idea to install the mechanical anyway. I wonder (out loud) if anyone has ever set a perfectly good plane down.... and balled it up, due to a faulty sender.
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Vic Baker
Joined: 11 Jan 2006 Posts: 71 Location: Carson City, Nevada
Posted: Sun Apr 05, 2009 12:47 pm Post subject: Fluctuating Oil Pressure Indication? |
My oil pressure sender failed after 30 hours total time on engine.
Indicating high (red line). Replaced it with "non aviation" unit from
Lockwood. $40 Telcon with Lockwood, not unusual for this to happen.
Note: Lockwood also recommended remove, clean threads, try again. Did not
help.
Also recommended install mechanical gauge. Have not done that.
Vic Baker
S7 912S Warp
Phase 1 flight testing
Carson City, Nv
_________________ Vic Baker
Series 7
Carson City, Nevada |
Roger Lee
Posted: Sun Apr 05, 2009 1:00 pm Post subject: Re: Fluctuating Oil Pressure Indication? |
Hi Darin,
Very first thing is get to the back of the panel and use a wire and touch the gauge ground to a know good ground. This is my first guess for what you describe, bad ground. If this is not it then my second guess is the sending unit. If the grounding doesn't fix it then you need to go to the hardware store and pick up a gauge from 0-100 psi and some 1/8" copper tubing. The oil pressure fitting threads is 1/8" NPT. Get a 1/8" NPT to a compression to come out of the oil sender port. Then come out with the tubing about 18" and put a tee in the line and continue the copper tube run until it gets well inside the cockpit. Put your oil sender gauge in the tee. Put the pressure gauge on the end of the line. When you run the engine you will be able to compare mechanical pressure with the electronic pressure. When you start the engine partially unscrew the pressure gauge until the oil starts to weep out the threads and then tighten the gauge. This will allow all the air to be purged out of the test line. These are VDO gauges and the VDO guage with the cadmium anti vibration ring cost up to $250. You can get the identical VDO gauge without the cadmium ring for $39.95. These seem to last just as long and I can replace this one a lot of times for just one of the others. Get the VDO gauge from Lockwood Aviation. Call me if you have any questions. 520-574-1080
Both of these things are very easy to do.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
darinh
Posted: Sun Apr 05, 2009 1:58 pm Post subject: Re: Fluctuating Oil Pressure Indication? |
Thanks for the input guys. As Roger recommended, I have checked the grounding and all is good. I am going to get a new sender and found them at Jegs. com for $25.99. As Roger said, they don't have the vibration ring around them but I plan to mount the sender remotely this time. Thanks again for the info.
Series 7
914 Turbo
Kaysville, Utah |
Float Flyr
Posted: Sun Apr 05, 2009 6:11 pm Post subject: Fluctuating Oil Pressure Indication? |
Thinking out loud here but that may have been what happened to Lowell.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
darinh
Posted: Sun Apr 05, 2009 7:23 pm Post subject: Re: Fluctuating Oil Pressure Indication? |
Noel, I was thinking the same thing when it happened. I thought that if I really was losing oil pressure it would be steadily decreasing to 0 but it kept jumping all over the place so I was pretty sure this wasn't an actual oil pressure problem but rather an indication problem. I did have the Brigham City airport about 4 miles ahead but opted to turn back towards Ogden - my home base. I have located another sender (summitracing.com) and ordered the hose and fittings to go to a remote setup so I can get rid of the vibration issues common to senders mounted directly on the engine. Got the sender, hose, insulation sleeve and fittings for under $100 which is much better than the $250 I thought I was going to spend.
Series 7
914 Turbo
Kaysville, Utah |
lcfitt(at)sbcglobal.net Guest
Posted: Sun Apr 05, 2009 8:02 pm Post subject: Fluctuating Oil Pressure Indication? |
Noel,
For a long time, I wondered if it was the pressure sender or frankly, if I
had mistaken the temp gauge as the pressure gauge as the temp senders had
failed fairly regularly. It wasn't until several months later that I got a
call from the FAA and they wanted to see me at the FSDO. It was then that
they showed me the black glob that they found in the oil tank with the
string that had melted off the glob that was sucked into the pick up tube.
I don't know if it was a relief to find that there was indeed a correct
reading on the oil pressure gauge, because I then had to think how something
like that could have been introduced into the oil system - most likely by
me. I still haven't figured that one out.
Lowell
Dick Maddux
Posted: Mon Apr 06, 2009 4:17 am Post subject: Fluctuating Oil Pressure Indication? |
It might be better to run a hose with a fitting off of the engine to read the pressure if you elect that method. As I recall, a copper tube can become brittle and break under vibration. If you do decide to use the copper a suggestion would be to put a coil in it to help absorb the vibration. That is the method the "old timers" always told me to do it.
I believe John McBean mentioned in one of his posts, that he has a remote oil pressure sensor kit available. I don't know anything about it but I have been meaning to contact him about this as my oil pressure sensor has failed once and I am sure it will again.
Dick Maddux
Fox 4-1200
912 UL
Pensacola,Fl
Feeling the pinch at the grocery store? Make dinner for $10 or less.
Float Flyr
Posted: Mon Apr 06, 2009 5:57 am Post subject: Fluctuating Oil Pressure Indication? |
Don't forget to cover the line inside the cockpit in case it holes. You
won't want hot oil spraying over your legs!
Noel
Kitfox III-A
Float Flyr
Posted: Mon Apr 06, 2009 6:11 am Post subject: Fluctuating Oil Pressure Indication? |
I had a Rover TC 2000 many years ago. After finally getting it fixed a and
running like a Swiss watch one day it suddenly seized just after starting.
When I took the head off I found little pieces of carbon hard steel imbedded
into all four of the cylinder heads and of course all my valves looked like
pretzels. I took a few of the pieces, which I had identified as pieces of a
compression ring, to all the auto dealerships and finally to a heavy
equipment dealer. It turned out the pieces were from the main compression
ring of a D 9 Caterpillar tractor. The engine being side draft with two
carbs couldn't have ingested the particles so the only way they could have
gotten into my engine was they had to be intentionally put in there through
the spark plug holes. I still don't know who may have done this.
In your case I was thinking some of the oil bottles have the little plastic
retainer rings which I have seen fall off some bottles. This could have
happened to your engine if the glob you mentioned was plastic or it could
have been part of a rag inserted in a hose to keep bits and pieces out.
Noel
Kitfox III-A
Roger Lee
Posted: Mon Apr 06, 2009 6:19 am Post subject: Re: Fluctuating Oil Pressure Indication? |
I don't mean for him the go fly with this setup. Everything you need to do can be done on the ground and you use copper or stainless because it is less likely to split over plastic lines and that is why you use a very small I.D. line to reduce any volume issue in case of a problem, plus there is no need for big lines when testing pressure only. Copper is just easier and cheaper to work with. You should have no leaks or rupture issues with only the Rotax oil pressure of 35-60 psi from the engine. You only need to run the engine for a couple of minutes to diagnose your problem. The problem is there or it isn't, no long run times needed. This is a very simple and telling procedure. [/u]
Tucson, Az.
Cell 520-349-7056
darinh
Posted: Mon Apr 06, 2009 7:20 am Post subject: Re: Fluctuating Oil Pressure Indication? |
I am making a remote setup using -4 Aeroquip Socketless hose and fittings and will mount my sender to the firewall. I am going to install a tee at the sender so I can connect a simple analog gage and compare the two readings, I can then cap the unused side of the tee and be done with it. This will allow for future diagnosis if needed.
Series 7
914 Turbo
Kaysville, Utah |
