Jim Feldmann
Posted: Sat Mar 28, 2009 6:38 pm Post subject: Near disaster |
I had an engine failure on takeoff today. Fortunately it was a long runway and it happened at 10 feet altitude. No injuries, no damage, and no idea why it happened.
Actually, the engine (Rotax 912 ULS) did not stop. It was running smoothly during taxi and warm up. Mag check was fine. I held short for 5 minutes or so for incoming traffic, running the engine from 2500 to 4000 for short periods. No problems. On takeoff, the engine pulled cleanly to 5000+ for the 5 or 6 seconds it took to break ground, then suddenly started running very rough and dropped to 2500 rpm or so. I immediately pulled the throttle to idle and landed.
While taxiing back to the hanger it ran fine, I tried full throttle again a couple of times and it ran perfectly. So what I have is an intermittent or one time problem that could be deadly.
I don't think it was ignition related, because if it was a failure of one "mag" it would have run much better than it did, and if both failed, it wouldn't have run at all. That leaves fuel or mechanical.
The carbs have recently been rebuilt. After I calmed down, I checked the float bowls, they are clean, the gascolator is clean and the fuel pump is putting out 4.5 psi., right on spec. Fuel is flowing freely through all of the inline filters and the header tank is full. I did recently drain all of the fuel out of the airplane to fix a leak in the header tank. Then I simply refilled the tanks from the top. Could there have been air in the fuel line between the header tank and the gascolater? The engine had been run for half an hour or so since then, but mostly at low throttle.
I have checked the throttle linkages also. No problem there. The plugs look good too, but my runups on taxi back would have obscured the evidence anyway.
My A&E suggested that it could be sticky valve.
Has anyone experienced a similar problem? Any thoughts on what to look for? I'm very hesitant to fly it again until I know what caused the problem
_________________ Jim Feldmann
Kitfox IV Speedster / 912 lost to prop failure
Building a Kitfox 5 Voyager |
Tom Jones
Posted: Sat Mar 28, 2009 6:52 pm Post subject: Re: Near disaster |
| Quote: | | Actually, the engine (Rotax 912 ULS) did not stop. It was running smoothly during taxi and warm up. Mag check was fine. I held short for 5 minutes or so for incoming traffic, running the engine from 2500 to 4000 for short periods. No problems. On takeoff, the engine pulled cleanly to 5000+ for the 5 or 6 seconds it took to break ground, then suddenly started running very rough and dropped to 2500 rpm or so. I immediately pulled the throttle to idle and landed. |
This sounds like a fuel flow problem. Alao, a problem soon after maintenance often has some relation to the maintenance. Were fuel lines to the header tank removed and/or replaced?
How about the rest of the fuel lines?
Any chance the fuel had a slug of water in it?
_________________ Tom Jones
Classic IV
Ellensburg, WA |
propellerdesign(at)tele2. Guest
Posted: Sat Mar 28, 2009 11:07 pm Post subject: Near disaster |
I agree with Tom ? possibility of Carb Ice.
Jan
leach(at)infogen.net.nz Guest
Posted: Sun Mar 29, 2009 1:08 am Post subject: Near disaster |
Jim, This sounds like a classic case of carb ice to me. On cold humid
mornings my 912 has almost stopped several times while taxiing. I pull the
carb heat on and the engine immediately runs perfectly. I then give the
engine a really good warm up and apply carb heat for 30 seconds or so before
applying full power for takeoff, and have never had a problem. If your
engine quit on a cold humid day and you don't have carb heat I would bet you
had carb ice.
Brian Leach
New Zealand
Avid 912 taildragger.
Lynn Matteson
Posted: Sun Mar 29, 2009 2:50 am Post subject: Near disaster |
Maybe vapor lock. You ran the engine for 5 minutes on ground at up to
nearly full throttle, so something might have gotten hotter than it
would in flight, and heated up a fuel line that wouldn't normally
have gotten that hot before. Look for high points in the fuel system,
or places that exhaust heat might be too close to the fuel lines.
Good save, Jim.
Lynn Matteson
Jabiru 2200, #2062, 622.1 hrs
Sensenich 62x46
Status: flying
On Mar 28, 2009, at 10:39 PM, Jim Feldmann wrote:
<feldesign(at)earthlink.net>
landed.
caused the problem
Jim Feldmann, 3rd owner
1994 Kitfox IV Speedster / 912
Working on my Sport Pilot Certificate
http://forums.matronics.com/viewtopic.php?p 36597#236597
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
marwynne(at)verizon.net Guest
Posted: Sun Mar 29, 2009 4:52 am Post subject: Near disaster |
Look at the carburetor boots. I had one with a crack in it cause the same
type of problem..
Marwynne
Roger Lee
Posted: Sun Mar 29, 2009 5:26 am Post subject: Re: Near disaster |
Carb ice wouldn't make it suddenly lose 50% of its rpm. Now maybe a vapor lock issue might have. Just something to consider in your diagnostics.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Sun Mar 29, 2009 5:34 am Post subject: Near disaster |
I wouldn't rule out vacuum lines.
Sent: Saturday, March 28, 2009 10:39:02 PM
Subject: Near disaster
--> Kitfox-List message posted by: "Jim Feldmann" <feldesign(at)earthlink.net (feldesign(at)earthlink.net)>
http://forums.matronics.com/viewtopic.php?p=236597#236597http://www.matronics.com/Navigator?Kitfox-List
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
mikelaundy(at)yahoo.co.uk Guest
Posted: Sun Mar 29, 2009 6:51 am Post subject: Near disaster |
Jim,
I had an engine cut during ground runs, I had previously drained all the fuel and refuelled the wing tanks with fresh fuel after the winter layup.
I discovered the header tank was empty as there was an airlock in the vent line. Blowing through the port tank filler cap pitot tube with the starboard tank fuel valve off, forced fuel into the header tank and cleared the airlock allowing the header tank to fill. Since then no problems. (In my aircraft the header tank vent goes to only the starboard tank).
My header tank vent line is also secured by nylock ties, if any of them are too tight it could restrict the header tank venting.
Mike Laundy
Kitfox III, Rotax 582
Cornwall
England
Date: Sunday, 29 March, 2009, 3:39 AM
--> Kitfox-List message posted by: "Jim Feldmann" <[url=/mc/compose?to=feldesign(at)earthlink.net]feldesign(at)earthlink.net[/url]>
http://forums.matronics.com/viewtopic.php?p=236597#236========================http://www.matronics.com/Nav= - MATRONICS cs.com" bsp; -Matt Dralle, List Adontribution" target="_blank">http://www.matronics.com/contribution
darinh
Posted: Sun Mar 29, 2009 8:34 am Post subject: Re: Near disaster |
Jim,
I had a very similar thing happen to me in my Kitfox (914). I figured it was something with the turbo as it would run fine up to about 4000 rpm. After re-adjusting the waste gate several times and tinkering with virtually everything else, I found that my final fuel filter was 95% coated with a pasty coating of something. At lower throttle, my pumps could force just enough fuel through to keep the engine running as it should but when I hit take-off power the fuel flow was not enough and the engine would cough and sputter. What that "something" was is still a bit of a mystery and some will argue with me but I am 100% sure I had an incompatibility between my fuel and mil6000 fuel hose. I have 3 filters in my system, two of which are connected to the tanks via aluminum tubing...my last filter was the only one with the mil6000 hose and was the only one that was plugged. I have replaced the filter and lines and the new filter is clean as the day it went in.
You said your gascolator is clean...do you have any other filters in the system that may be plugged?
_________________ Darin Hawkes
Series 7
914 Turbo
Kaysville, Utah |
Jim Feldmann
Posted: Sun Mar 29, 2009 8:46 am Post subject: Re: Near disaster |
Thank you all for your replies and suggestions. I will check into all of them.
Tom; yes, I removed the header tank, corrected a slow leak in the bottom fitting and then reinstalled the tank using the original fuel and vent lines, which are about a year old and in good shape.
The possibility of water in the fuel or carb ice are remote. It was 2:30 PM on a clear and dry, Sunny California day. Ambient temp 78 degrees, humidity about 50%. I don't know the dew point, but it would have been low. I checked for water in the gascolater before the flight and found none. (I have never found even a drop in either tank or in the gascolater.)
I will carefully check the entire fuel system for contamination. If anyone has any new thoughts, please add them to the list.
Jim Feldmann
Posted: Sun Mar 29, 2009 9:09 am Post subject: Re: Near disaster |
Darrin: I have filters in the lines from the wing tanks to the header tank. There is no filter on the header tank vent line, which goes to the right wing tank. I'm thinking that the header tank could still vent, giving 15 minutes or more of gas at full throttle, even if both filters were plugged. There is no filter between the header tank and the gascolater.
I will check the filters anyway. Thanks.
thesupe(at)hotmail.com Guest
Posted: Sun Mar 29, 2009 11:24 am Post subject: Near disaster |
I had a problem with my Avid MK IV when it had the 582 in it. The plane has an about 1 1/2 quart header tank. I took off and when I got to about 450' it started to spit and sputter and would only hold about 4500 RPM. I ended up landing in a neighbors hayfield with no damage. I also had filters between the tanks and the header tank. I was just using one tank at the time. Turned out that the filter was plugging enough to restrict the flow to where I wasn't getting enough fuel at full throttel to keep up to the demand of the engine. When the header tank started to run out C it started to miss and spit. Steve Winder at Airdale/Avid said to never have a filter in a gravity flow area as it doen't take much to restrict the flow C it the filter is between the header tank and the fuel pump C the header tank may catch some of the junk in the lines that would otherwise get to the filter and also the fuel pump with help the flow rate. Just another thought. Take care C Jim Chuk
| Quote: | Subject: Re: Near disaster
Date: Sun C 29 Mar 2009 10:09:30 -0700
Darrin: I have filters in the lines from the wing tanks to the header tank. There is no filter on the header tank vent line C which goes to the right wing tank. I'm thinking that the header tank could still vent C even if both filters were plugged. There is no filter between the header tank and the gascolater.
Jim Feldmann C 3rd owner
http://forums.matronics.com/viewtopic.php?p=236677#236677
Express your personality in color! Preview and select themes for HotmailŪ
Tom Jones
Posted: Sun Mar 29, 2009 12:08 pm Post subject: Re: Near disaster |
| Quote: | | Tom; yes, I removed the header tank, corrected a slow leak in the bottom fitting and then reinstalled the tank using the original fuel and vent lines, which are about a year old and in good shape. |
When the flexible material lines are pushed on to fittings the fitting can cut a little flapper on the inside of the line that works like a check valve when the flow increases. Also make sure there are no kinks. You probably have checked this already.
Classic IV
Ellensburg, WA |
Fox5flyer Guest
Posted: Sun Mar 29, 2009 12:16 pm Post subject: Near disaster |
Glad to hear that you had that hay field below you, Jim. I tend to agree with Steve. By putting filters into the wing tank feeder lines it not only adds additional choke points, but also more places to leak and clog up. The header tank is designed to sit in the low point of the fuel system and makes a great gascolator. I have my filter, and the only filter I have (a high flow sintered bronze unit by Earls Performance Products), on my firewall as the last line of defense. I also used 3/8 ID fuel line all the way to the engine. It's my belief that, within reason, the bigger fuel line equals better flow due to less restriction which equals fewer problems.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Float Flyr
Posted: Sun Mar 29, 2009 1:47 pm Post subject: Near disaster |
Strainers go before a pump, filters after and the gascolator at the lowest
point. I know some disagree with that statement... That's ok.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dafox(at)ckt.net Guest
Posted: Sun Mar 29, 2009 5:54 pm Post subject: Near disaster |
I had the same problem three years ago. Changed all the fuel lines, checked
needles valves in carbs, checked fuel flow ( 10 gals an hour ) also
installed inline fuel pump, everything checked Ok, still the same problem. i
nstalled a new fuel pump, and that was the problem, the engine has been
runing perfect ever sence, and that was three years ago. You might think
about installing a new fuel pump.
David Yeamans
Kitfox 4 1200
Rotax 912 UL
Roger Lee
Posted: Sun Mar 29, 2009 6:23 pm Post subject: Re: Near disaster |
David has a very good point. You should get a low pressure gauge
(10 psi max) and put it in line after the fuel pump and double check the fuel pressure on a tie down at full throttle. This is fairly easy to do and you don't need any special test gauge.
Tucson, Az.
Cell 520-349-7056 |
darinh
Posted: Sun Mar 29, 2009 7:16 pm Post subject: Re: Near disaster |
I agree with Deke...there is no need for filters before the header tank. When I say I have 3 filters, I am including my finger strainers as one. I have an Earl's filter before the pumps and a final filter forward of the firewall just before it goes into the pressure regulator. Had my final filter not been there, all that disintegrated hose material would have ended up in my pressure regulator and carbs so it did serve a purpose. After changing the hose, it is probably overkill to have the last filter but it is there.
Series 7
914 Turbo
Kaysville, Utah |
Posted: Mon Mar 30, 2009 5:02 am Post subject: Near disaster |
After I had the problem with my plugged filter C I got rid of the filters that were before the header tank. I then mounted another filter in parallel with the other one under the instrument panel. I put in another valve that I could close off the second filter with. I allways opened the valve for takeoff and would close it once I got above 500' or so. My thinking was I then had a backup filter if the engine started to spit and miss from a plugged filter. Jim Chuk Avids C Kitfox 4 Mn
[quote] Subject: Kitfox-List: Re: Near disaster
Date: Sun C 29 Mar 2009 20:16:53 -0700
--> Kitfox-List message posted by: "darinh" <gerns25(at)netscape.net>
I agree with Deke...there is no need for filters before the header tank. When I say I have 3 filters C I am including my finger strainers as one. I have an Earl's filter before the pumps and a final filter forward of the firewall just before it goes into the pressure regulator. Had my final filter not been there C all that disintegrated hose material would have ended up in my pressure regulator and carbs so it did serve a purpose. After changing the hose C it is probably overkill to have the last filter but it is there.
Darin Hawkes
Series 7
914 Turbo
Kaysville C Utah
http://forums.matronics.com/viewtopic.php?p=236799#236799
Quick access to Windows Live and your favorite MSN content with Internet Explorer 8.
