		tc1917(at)bellsouth.net Guest
				 Posted: Thu Apr 09, 2009 2:35 am    Post subject: vibrations |
				For those that have not been privy to my harmonics on my 912, here is the
 following.  The first thing I thought was wrong was the prop not being set
 "right" so I developed a laser that sits on the tip of my blades, one at a
 time, while I set them so they are near perfect.  The blades themselves were
 all different weights, one a different length and two had what looked like
 cloth bumps showing.  I sent them back and they came back better but still
 not the same.  One has a different twist at the middle and now has a smaller
 tip.  This is what WD thinks are good blades.  I believe I have a set of
 reject blades all thrown together.  My personal belief.  I sent them back
 twice but they are still basically the same.  I have been balancing large RC
 props for thirty years and have never seen blades like these.  I super
 balanced them.  Same problem.  I super tuned the carbs -- three times!  Not
 the problem.  I changed the angle of my titan exhaust outlets -- twice!  I
 added some angle sections to my pipes so the exhaust would not hit the
 blades directly -- no joy.  I have stainless tubes with holes on the ends of
 my pipes and they do reduce the noise a bunch but I still have the
 harmonics.  I have taped the wing fabric top and bottom and checked all the
 fittings, pieces and mounts for loose or dangling fabric.  I changed my gap
 seal three times.  I started with no spacer, spent $450 for a four incher,
 no help.  That changed my balance where it was not desirable, dont know why.
 I took it off and put a two inch spacer on and that seems to work good
 except the harmonics are still there.  I changed spark plug gaps and then
 spark plugs.  nothing helps.   This harmonic sound does not increase in
 beat, just intensity to the point where it actually beats on the back of my
 helmet.  My anr removes most of it so I can tolerate this noise.  It is
 noticeable from the ground as a rum rum rum sound like it out of tune.  A
 friend has a new set of WD props like mine down in Florida and I will try
 them as soon as I get down there.  If that makes it better then you can bet
 I will call WD with the 'proof' and see what they will do.  Right now I just
 live with it.  As far as changing type of prop -- well, how many of you have
 an extra grand or more to just 'try' another prop?  I dont.  I should not
 have to.  I paid my money and should have a good prop.  Like I said, I have
 not absolutely proven it is the prop yet but I will.  By the way, one blade
 really shows the cloth weaving and I believe it is the culprit.  Ever hear a
 digery do or however it is spelled?  That hum hum is what I am talking
 about.  Thought WD would replace it last time but they didnt.  Not exactly
 the service I would expect from such a reputable dealer.  Guess I dont have
 enough 'fame' to get good service from them.  My life as it is.  At least my
 rum rum is accompanied by zoom zoom and that makes it worth it.  Ted Cowan,
 Alabama, Slingshot 912 UL.   p.s. I still have a fifty buck reward for
 someone with a cure.  (something we have not already thought of or done)
 Hauck is the first one for the blades being bad.
		lucien
				 Posted: Thu Apr 09, 2009 5:18 am    Post subject: Re: vibrations |
				 	  | tc1917(at)bellsouth.net wrote: | 	 		  For those that have not been privy to my harmonics on my 912, here is the
 Hauck is the first one for the blades being bad. |
 Well I do have to defend WD a little bit here. Yeah it's wierd if they're not fixing malformed blades for you, but I can't say their service has been any problem for me.
 After all, my plane does have that big ol "Experimental" sticker plastered onto the side of it. So ultimately, the plane is an experiment, so I have to keep in mind and take that responsibility. Things are just going to come up if I have to make changes.
 In my case, I'm just going to have to keep "experimenting", that's just how it is with experimental.  Its on me to do the work here and I can't expect everyone else or even WD to know exactly what's wrong with my setup. I kind of have to take the bull by the horns and get to work on things for which others might not have ready answers. That's kind of how life is in general in fact, and is no reflection on anyone else...
 If this particular prop wont' work, it just wont work and that'll just be a consequence of my particular setup.
 It sure isn't the fault of the prop. I've used WD before (on my FSII) and it was a superb prop. This one I have is impeccably made and I sure can't argue with the performance.
 But I am going to try different prop types. At this point I've exhausted most other things to try tho there are still a couple more things to try. But that's just how it goes with our flying machines...
 LS
  _________________ LS
Titan II SS |
				 Posted: Thu Apr 09, 2009 5:34 am    Post subject: vibrations |
				Ted
 I have chased noise issues with my VW over the years and think that the
 engine mount is the area that you may want to look into. Try softer
 vibration dampers or move them around so that they isolate engine/prop
 vibrations better and still control the position of the engine/prop.
 My VW high mount had the lowest noise in the cockpit and lest vibration
 transmitted to the airframe. The redrive I was using at that time would
 vibration crack engine parts quite regularly yet the noise level in the
 cockpit was so low that sometimes I could take my headphones off for short
 periods of time in flight. The engine was real loose on the mount allowing
 the engine to visibly twist away from the torque applied to the prop. After
 about a hundred hours the vibration dampers were destroyed.
 When I designed the lower VW engine mount I used a damper system that placed
 the dampers further apart to better control the engine and extend the life
 of the dampers. It worked but the noise and vibration in the cockpit
 increased so much that I had to use ear plugs under my ANR headsets. Since
 then I have reduced the vibrations a bunch and the noise a bit with a
 smoother redrive. I'm now on a quest for softer damper bushings.
 Food for thought and as always worth what you paid for it.
 Rick Neilsen
 Redrive VW powered MKIIIC
		robcannon
  Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
				 Posted: Thu Apr 09, 2009 5:34 am    Post subject: Re: vibrations |
				Ted - I took some training last summer in a Rans S 12 in preparation for my Kolb first flight. (it was the only high thrust line pusher around).  It has the same harmonics you describe (annoying in the cockpit, and annoying on the ground) It has a Rotax 912 with a three blade "kool"prop. They have over 1700 hours on this plane and motor, and they have accepted this thrum thrum thrum and part of the package. When I flew it I just chose a throttle setting that minimized it the most.
   Don't get me wrong here, if I were in your shoes I would not give up untill I had a explanation/solution, but it may not be the warp drive that is the culprit.
 good luck, Rob Cannon
 ps: Rans has probably sold more 912 pushers than most - I would call up their tech support guy and see what he says.
				 Posted: Thu Apr 09, 2009 5:50 am    Post subject: vibrations |
  	  | Quote: | 	 		   about.  Thought WD would replace it last time but they didnt.  Not exactly
  have enough 'fame' to get good service from them.  My life as it is.  At
  least my rum rum is accompanied by zoom zoom and that makes it worth it.
  Ted Cowan, Alabama, Slingshot 912 UL.   p.s. I still have a fifty buck
  reward for someone with a cure.  (something we have not already thought of
  or done) Hauck is the first one for the blades being bad.
 I've offered several suggestions since Ted C has had the harmonic problem.
 Guess none of them worked.
 Also offered to try my WD off my airplane.
 I believe the place to start is remove the suspect prop and hub.  Put
 another WD prop on from a setup that has no problem.  Test it.  If it
 developes the same problem, then it is not the prop.  If the problem
 disappears, then you have more ammunition to go back to WD and get a
 replacement prop.
 I also recommended contacting Daryl to request another prop and hub to use
 for a test.  I have a good feeling he would do that to see that his
 customers are satisfied.
 I don't think 'fame' has a thing to do with getting good service from WD.
 This company has been in business for many years, and not because they
 mistreated their customers or because they sold inferior products.
 While I am recommending, highly recommend you give Daryl a call at
 1-800-833-9357.  I reminded him of your problem.  He would be glad to
 discuss it with you.
 mkIII - 60 west of Ted Cowan's airstrip.
  _________________ John Hauck
Titus, Alabama |
				 Posted: Thu Apr 09, 2009 6:10 am    Post subject: vibrations |
				Ted, borrowing other props for comparison would be my first choice
 too.  I know I wouldn't
 be happy if I had paid for new blades and got blades that didn't even
 look cosmetically perfect.
 The "proof" approach is the way to go.
 I also have a rum rum but I have noticed that some of it may be my
 hearing.  I hear it just walking up the driveway, in time with my
 heartbeat.
 Something to go along with my tinnitus.
 If you have a two blade WD hub that would be a good thing to try.
 That reminds me
 to order a two blade hub for my powerfin.  I sure would like to be
 able to keep the
 70" two blade WD on my suzuki because it gives me what seems like 10
 hp  better performance than the
 3 blade 65" powerfin I had on before.
 Mix match and compare.
 BB
		The BaronVonEvil
  Joined: 23 Jun 2006 Posts: 76 Location: Walla Walla, WA.
				 Posted: Thu Apr 09, 2009 12:46 pm    Post subject: vibrations |
				Hi Ted,
 While I dont have any personal experience with a 912, I do have a few
 suggestions of a general nature.
 Check the gearbox oil of your engine to see if every thing is okay. Perhaps
 there is a bearing or gear that is causing your grief. Any metal in the gear
 oil is not a good sign and warrants a tear down of the gearbox.
 Check the runout of the propeller drive flange to see that it is running
 true. Also check  to see if there is any  play or slop in the drive that
 shouldn't be there. In general terms, some gearboxes have preloads and no
 play while others require a small amount to operate properly. The Rotax
 manuals may call out the details for your gearbox.
 Have you checked the compression of the cylinders to see if they are okay?
 Uneven compression maybe causing harmonics in your engine.
 A fixed pitch wood prop would be less costly alternative to a composite if
 you have to purchase one for testing.
 Again these are a few general items I would look at  if I was having your
 troubles.
 Good Luck and let us know when you have found the problem.
 Best Regards
 Carlos G
 AKA
 BaronVonEvil.
		JetPilot
				 Posted: Thu Apr 09, 2009 1:34 pm    Post subject: Re: vibrations |
				We have a couple MK III's here at my field, and both of us have had to do a mod to reduce the noise inside the cockpit.  Built by the plans, there is an open space from the prop that makes the cockpit act like a resonant bell, the noise was HUGE !   My " Neighbor " put a piece of clear lexan behind the seats, where a headrest would be if he had one.  This simple, one piece of flat lexan made a huge difference in making his cockpit noise tolerable.  His noise reduction worked so well, that I went a lot of steps further and enclosed the entire cabin of my plane, above and rear, and put sound dampening in the lower fabric in the cage behind the seats where it faces the prop. I also have sound dampening on the rear lexan windows.  In other words, I put sound dampening in any part of my cage on my plane that " Sees " or faces towards the the prop at anything less than a 90 degree angle.  John Haucks MK III is pretty much like this, with all rear areas enclosed.  This made a huge reduction in the noise level.  I use ANR headsets, but don't need any earplugs.  I wonder if you have a typical loud hum hum that would be hardly noticeable with some noise prevention measures.  Its hard to tell how severe this is, or if its typical without hearing it first hand and comparing it to other Kolbs with a similar setup.
 My warp drive prop is perfect.  Did you check the tracking on the tips of your prop, all three blades should be within 1/16 of an inch or so.  My Rotax 912-S / prop is as smooth as silk, smoother than any other piston engine I have flown behind.  I can barely feel it running if I place my hand on the cage tubing.  I have had several occasions to deal with Warp Drive, and they have always been more than fair, and gone the extra mile as far as I am concerned.  There are lots of warp drive props on experimental airplanes, it is very rare to hear anything bad about them.  It is possible to get a combination of equipment that will not work well together, but there are such a huge number of Warp Drive / 912-S combos flying, that I don't believe this should be problematic combo.  Maybe time to look more at the airframe ??
 P.S.   Going from a 4 inch spacer to the two inch spacer you have now is a such very small change of CG, I don't see how this could possibly have any meaningful impact on the flying qualities of the airplane.  You must have miscalculated something or not have a full understanding of effect this has on CG.   Anyways, the 4 inch spacer on the prop is far better than a two inch spacer, for a number of reasons.  I would most definitely use the 4 inch spacer...  Just off the top of my head, I think two extra inches on the prop spacer would equal less than one pound of weight added to the nose IF you wanted to keep the same CG..  Thats a rough guess off the top of my head, it would be easy to calculate given your WB information and prop weight.  In other words, its negligible and I would not even bother with such a small change.  The longer spacer is much better for a pusher setup like found on our Kolbs.
 Gook luck chasing this down, like Lucien said, we did sign up for Experimental aviation, and it can make you want to beat your head against a wall sometimes.
 Mike
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		lucien
				 Posted: Thu Apr 09, 2009 3:18 pm    Post subject: Re: vibrations |
				 	  | JetPilot wrote: | 	 		  We have a couple MK III's here at my field, and both of us have had to do a mod to reduce the noise inside the cockpit.  Built by the plans, there is an open space from the prop that makes the cockpit act like a resonant bell, the noise was HUGE !   My " Neighbor " put a piece of clear lexan behind the seats, where a headrest would be if he had one.  This simple, one piece of flat lexan made a huge difference in making his cockpit noise tolerable.  His noise reduction worked so well, that I went a lot of steps further and enclosed the entire cabin of my plane, above and rear, and put sound dampening in the lower fabric in the cage behind the seats where it faces the prop. I also have sound dampening on the rear lexan windows.  In other words, I put sound dampening in any part of my cage on my plane that " Sees " or faces towards the the prop at anything less than a 90 degree angle.  John Haucks MK III is pretty much like this, with all rear areas enclosed.  This made a huge reduction in the noise level.  I use ANR headsets, but don't need any earplugs.  I wonder if you have a typical loud hum hum that would be hardly noticeable with some noise prevention measures.  Its hard to tell how severe this is, or if its typical without hearing it first hand and comparing it to other Kolbs with a similar setup.
 Mike |
 For what it's worth, according to Daryl, the tracking need only be within about 5/16" max. 1/4" is typical, my current one and the one I had on my FS II were about 1/4" off (the one on my FS II was smooth as glass).
 I'd personally try to keep the spacer as short as possible. A long spacer adds a signficant amount of arm to the Coriolis forces the prop imposes on the prop shaft. Every little bit helps to preserve our gearboxes even tho they're still strong as stink.....
 My FSII was unbelievably loud in the cockpit and sure enough it was open at the rear. Wish I'd had my telex ANR headset back when I had that plane......
 LS
Titan II SS |
		lcottrell
				 Posted: Thu Apr 09, 2009 4:03 pm    Post subject: vibrations |
				[quote]   My FSII was unbelievably loud in the cockpit and sure enough it was open    at the rear. Wish I'd had my telex ANR headset back when I had that    plane......
 LS
 LS
 Titan II    SS
 For what its worth, on my trip to Texas    with Arty, I used the full enclosure on my Firestar. That is the full    windshield and the fabric with the convertible type window in it. It cut my    maximum speed to 60 MPH. Without it and using the full windshield I gained 7    MPH. It might be quieter, but I am not willing to take the cut in top    speed.
    Larry C
		zeprep251(at)aol.com Guest
				 Posted: Fri Apr 10, 2009 1:53 am    Post subject: vibrations |
				Larry,
      I ran into the same speed problem with my FS2 full enclosure.When I tried to pick up speed by lowering the nose a little,the enclosure tore loose from the right side of the windshield former  tube and entered the propeller arc.I was lucky enough to drag it back into the cabin and continue to my field.It put 1 big gash in the clear vinyl part of the enclosure but it was repairable and a lesson was learned.I have no idea why it did not wad up in the prop and create the scenario that is going thru your mind right now,I really don't.
                       G Aman former FS2 driver.It's still my favorite Kolb.
